Using Nikon F Lenses On Pentax K Bodies (LBA Post)
Started Aug 25, 2006 | Discussions
carpents Senior Member • Posts: 1,977
Okay, I guess I'm the only one crazy enough to try this, but I helped a friend sell some camera equipment. After playing around with the old Nikon F (Non-AI) lenses and one of the Nikon F2 bodies, I couldn't resist. So I bought:
Nikon F2
20/3.5, 24/2.8, 28/3.5, 50/1.4, 55/3.5 Micro, 105/2.5, 105/4 Micro lenses.
After three days of trying, and lots of patience, I finally discovered that the F mount fits fully within the K mount...now I've been using all those old lenses on my Pentax body! The 20/3.5 is an AI lens, and it doesn't fit as nicely as the others, but the rest fit with a little turn - and the 24/2.8 and 55/3.5 even lock in!
They're nice little lenses, they're all quite sharp and have decent bokeh. I haven't had time to do any testing with them, but in 'real world' they've done quite well. Here is a picture of the gear, and I'll follow this with some pictures.
OP carpents Senior Member • Posts: 1,977
Nikon Nikkor 55mm f/3.5 shots (2 IMG)
(All taken at f/3.5)
Nikkor 105mm f/4 Micro
At f/4 - this was a neat butterfly - it had a trick end that mimicked its front. The 'antenna' even moved around!
Nikkor 105mm f/2.5
At f/2.5:
More here...
If you're interested in more, I have some shots here:
http://www.pbase.com/carpents/eq_nikons
I'll be expanding as time permits!
(PS - I fully intend to convert these to K mount, especially the 20/3.5 which doesn't fit so well, because I couldn't possibly use a Nikon camera! Actually, none of the Non-AI lenses will work AT ALL on the Nikon DSLRs because THEY CHANGED THE MOUNT...although Nikon peeps won't tell you that. Even the 20/3.5 AI lens will only meter on the D2 series, not the D50/70/80!)
Hope you enjoyed!
--Sean
xpistos
xpistos Regular Member • Posts: 329
Can you explain some more please?
So if I went and bought a pre-AI Nikkor,
it would fit on a Pentax K?
Does it need modification?
How about focusing? Does it work at infinity?
thanks
csc
 xpistos's gear list:xpistos's gear list
Fujifilm XF10 Fujifilm X-T30 Fujifilm XF 18mm F2 R Fujifilm XF 27mm F2.8 Fujifilm 50mm F2 R WR
Yes...
Yes.
No (but see below).
It does work! The register distance is slightly greater than the Pentax one, so it can still focus to infinity even though it sits a mm or so higher than it normally would.
thanks
csc
A note on fitting the lenses: You have to align the dot on the Nikon lens with about the 2:00 position as you look at the camera mount. It will slide down fully. Then, you give it a slight clockwise turn - this is where the AI lenses barely fit on but most of the Non-AI lenses turn about 1/16th of a turn which is more than enough to get a firm fit. Like I said earlier, the 55 Micro and 24mm turn far enough that they actually clear the locking pin, and they 'click' into place. None of the others fit like that, though.
It is a somewhat delicate operation at first, but as long as you don't force it - they fit.
I fully intend to swap out the mounts, but they work as-is to varying degrees.
(My 'brandrx' disclaimer - I neither support nor recommend anyone else try this crazy trick - I'm only letting you know the silly things I do!)
Sean
Lars Holte
Lars Holte Senior Member • Posts: 1,204
Re: Using Nikon F Lenses On Pentax K Bodies (LBA Post)
Great idea - great images!
 Lars Holte's gear list:Lars Holte's gear list
Pentax K-3 Pentax K-1 Pentax smc FA 50mm F1.4 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM +11 more
(unknown member) Regular Member • Posts: 362
Oh goodness, this means I can add 3 more lenses to my collection...
When I'll tell my father that I can use his Nikon F lenses on my Pentax D he'll probably think I'm joking.
Best news of the day, thank you!
Sabine
http://www.pbgphotography.ch.tc
http://digitalfrrreak.deviantart.com
btw
This reminds me, the day I chose Pentax, I definitely made the right choice
Ha ha, that's great! I'm glad I could 'help'.
Be sure to tell him that he CAN'T use them on the Nikon DSLRs (if they're Non-AI) - that will underscore how nice AND FUNCTIONAL our Pentaxes are.
Pentaxes are.
Oh I certainly won't omit that detail
JensR Forum Pro • Posts: 17,971
Hm...
Hmmmmmmmmmmmm.....
MMMMHHHH!
Nice lenses (wrong brand, but nobody is perfect... ) Nice photos and very nice manual focusing skills by you, Sean!
Cheers
Jens
'Well, 'Zooming with your feet' is usually a stupid thing as zoom rings are designed for hands.' (Me, 2006)
http://www.jensroesner.de/
Kaushik Mallick Contributing Member • Posts: 674
Re: Nikkor 105mm f/2.5
cool idea. never thought this would work. I have a couple of AI lenses. Now I gott atry them out on m Pentax.
Carpents, you are not helping this problem with LBA.
Life's Pentaxtic!
LOL
"LBA has no cure and knows no bounds."
Be warned that the AI lenses don't work so well - the have a different flange at the bottom that makes them not fit so well (at least my 20/3.5 AI is this way.) But, I'm sure the modification to full-blown K-mount isn't too terribly hard.
FYI,
Sean
JensR wrote:
Hm...
Hmmmmmmmmmmmm.....
MMMMHHHH!
That's what I said! (PS - I bought the lenses before doing this trick with them.)
Thanks! The 55/3.5 Micro is a bit dim, but it is really small and light. Pretty easy and nice to use.
Cheers
Jens
Not sure about the idea part, but thanks for the compliment on the images!
SelrahCharleS Senior Member • Posts: 2,707
Haha that is cool
Nice pictures too.
Various tags to clarify what your message is about...
HELP: having difficulty with camera
TIP: stuff you've figured out how to do and want to share
IMGP: images posted to the forum for enjoyment of all
TECH: technical talk and rumors
CHALLENGE: for all our various challenges
ORG: anything issues about the forum
CR: please critique my images
CHAT: This place is so great, I love you guys! etc.
OT: Off the Topic of Pentax DSLR photography
LINK: links to other sites
Jonas B Forum Pro • Posts: 14,596
JensR wrote:
Hm...
Hmmmmmmmmmmmm.....
MMMMHHHH!
Cheers
Jens
You put it exactly the way I would like to do. So; ditto.
Great idea, and fun, Sean!
regards!
Jonas
brandrx Forum Pro • Posts: 28,337
Hmmmmm....
Well, I don't agree with the above. You are just the first one to try this.
This is really cool Sean. Now I must get one of these lenses myself and give it a try.
The images you've shown are really good IMO. I really like the first two that were taken with the 55/3.5
Thanks for this thread. It opens up a whole new world for us.
Ron ~ Retired
