zoom browser problem
Started Aug 21, 2006 | Discussions
ledittmar Veteran Member • Posts: 3,495
When I click on zoombrowser (short cut) on front page, I get the message "invalid class string". I updated it a few months ago. I tried to remove the program from the canon utilities , but it failed to uninstall. How do I uninstall it? I want the old version back.
ArnieM Forum Member • Posts: 70
Re: zoom browser problem
This may be way of base, but are you running IE7 beta. I've had alot problems (strange ones) using IE7.
Arnie
VegasSil Senior Member • Posts: 1,000
what version did you install?
there is a version that has given people of problems but it can be fixed. if you know your version, do a search on that version on these forums and there may be someone that can help you.
OP ledittmar Veteran Member • Posts: 3,495
Re: what version did you install?
When I right click on it ,to check properties, it says zoom browser ex,that is all. Left click gives a critical error, invalid class string.
I fixed it , with the help of the Canon guy, took all of Canon out of computer, then re-installed the disk. Will not up-date it. Works fine now.
