ISO comparison, Nikon D80 vs Sony a100 !
Started Aug 10, 2006 | Discussions
ArtFedorov Regular Member • Posts: 249
As this thread has only 7 posts over 45 minutes, means nobody realised that it has link to site comparing iso noise on D80 vs a100 (up to ISO 1600)!
http://forums.dpreview.com/forums/readflat.asp?forum=1034&message=19530324
Keep in mind that Alpha's pictures are underexposed compared to D80's. Info from Japanese site. Thanks to takaJ for link.
OP ArtFedorov Regular Member • Posts: 249
Re: ISO comparison, Nikon D80 vs Sony a100 !
uuronl Senior Member • Posts: 1,672
Wow, I'm really impressed
I'm super impressed. The detail is very good even at ISO 1600, and the color holds up and doesn't wash out. It also appears to have all the shadow detail of the lower ISO shots. This is truly an upgrade compared to the existing 10Mpxl + Nikon offerings in the noise department.
 uuronl's gear list:uuronl's gear list
Sony Alpha NEX-5N Nikon D800
Direct comparison
Here, I prepared two files:
Nikon D80 200/1600 ISO (jpeg saved at 92% quality)
Sony a100 200/1600 ISO (jpeg saved at 92% quality)
EXIF:
D80 @ ISO 200, f/3.5, 1/2
D80 @ ISO 1600, f/3.5, 1/20
a100 @ ISO 200, f/3.5, 1/8
a100 @ ISO 1600, f/4.5, 1/40
a100 underexposes quite a bit, but look at detail retention in D80! It's fantastic, never seen anything like that in 1600 shot, even from my D50! (well, maybe I haven't ever looked at iso 1600 at 100%)
bobmax Veteran Member • Posts: 6,380
That's Dramatic.... Wonder how..
It will compare in high ISO w/the D50.... As the D50 does a great job of high ISO.
Bob
BobNIK
Direct comparison - Shadow noise
Ok, the same image, the WORST shadow noise I could find
Nikon D80
Sony a100
Obviously, details are lost in D80, but look at Sony!
Bill Karadimos Veteran Member • Posts: 4,675
D70 iso 800
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming - ' Wow! What a ride!'
Ronnie T Contributing Member • Posts: 573
Re: Direct comparison - Shadow noise
To be fair to Sony, the Sony pics are underexposed so it shows the noise more.
I will still want to see a fair comparison. I hope they will include the D200 too!
noise more.
Yep, but look at first pic, ISO 200 vs 1600 on D80, no noise and almost all details are there! Remarkable!
I hope too Phil would hurry with review.
Steve Bingham
Steve Bingham Forum Pro • Posts: 27,678
Wow. Pretty dramatic difference!
Thanks for the post. The D80 has a LOT LESS noise than the Sony. I wonder how come as they are both using the same chip. Very interesting!
Steve Bingham
http://www.dustylens.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon Coolpix 990 Sony RX100 VII Nikon D810 Nikon D7200 Nikon AF Nikkor 85mm f/1.8D +33 more
brianhare Senior Member • Posts: 1,677
Thanks for the link,i've been staying out of these threads,lot of negativity about a camera we know almost nothing about,i think a pile of people will be in reflection on their previous posts when a good solid review finally hits,can't wait till Phil gets a full review up,there is an awful lot of new/better additions to this camera,i expect it'll sell beyond everyones belief,,the low noise is no suprize to me,i pretty much guessed that it would at least be close to or equal the D50.The D50 shows they are hard at work on this issue,,and that processing can do a lot in alleviating it to a large extent.I'll now sit and patently await the reviews and go from there,looks like i may be upgrading about a year sooner than i expected..
Brian
D50,Sigma 70-200 EX HSM,Sigma EX APO 1.4,DX6490,TCON17,,One dog
http://photobucket.com/albums/v147/brianhare/
Quest21 Senior Member • Posts: 1,873
Very clean high iso.
Looks like I might get this camera after all...
LiveM Veteran Member • Posts: 3,835
That's not a direct comparison, that's overexposed versus normally exposed. Of course there is more noise with lower exposure.
What a ridiculous post.
EXIF:
 LiveM's gear list:LiveM's gear list
Samsung NX1
First, it's normally exposed versus underexposed
Second, you don't understand the point of comparison. It's about detail retention under 1600 ISO in D80, Sony's shots are given for information purposes only, it's clearly written, because of underexposure.
For those who interested, I've calculated exposure for both high-iso shots It's 3.7 EV for D80 and 5.1 EV for a100. Sony underexposes for 1.4 EV, take it FWIW.
Smearing
Detail smearing on high ISOs in D80 is still present, crops taken from the near-corner of the frame. Remeber, it's shot with pre-production D80.
Bernard Languillier Veteran Member • Posts: 4,672
Obviously...
... no camera currently delivers the same image quality at base and high ISO.
What people are raving about is the fact that the gap is fairly small.
There is indeed some degree of smearing, but a lot of detail is still preserved and prints should look really good IMHO.
Bernard
AdamT
AdamT Forum Pro • Posts: 61,750
No Antishake = better cooling?
CCDs get warm almost instantly, the Antishake platform on the A100 means that the CCD can't be heatsinked to provide cooling - maybe this has something to do with it? .. Also the Signal Amps in the Nikon maybe lower noise ..
producing a 10Mp DSLR with AS and all the boxes ticked for £569 with an 18-70 lens included, something has to give, component quality (CCD amps etc) may have been part of the cost cutting..
Also in-cam NR has a lot to do with this also, I'd expect that Sony would use the most as all their other cams such as the R1, T series, H series, P200 etc are absolutely Loaded with it even at lowest ISO but Nikon could have upped theirs at higher ISOs ..
the only way to check for noise is to run all the cams through ACR with the Lum NR full OFF and compare, the R1 produces pretty heavily mottled blue skies even at lowest ISO, you can see a small amount of noise at ISO200 on the Canon 20D and Fuji S3 even - comparing JPG engines for noise is pointless unless you're buying a cam totally for point and print high ISO performance and for that Canon & Fuji always win as they have the best noise reduction routines
Please ignore the Typos, I'm the world's worst Typist
Canon PowerShot G7 X Nikon D3 Panasonic Lumix DMC-G5 Nikon D850 Nikon Z7
clock Regular Member • Posts: 267
the mouse ran up the
Wonderful detail at high ISO. v Good, Basil/Bill/Vassili,
Re: No Antishake = better cooling?
I guess the 1.4 EV underexposure on Sony Alpha 100 is the main explanation of the differences
Having almost one-and-a-half stop underexposure on Sony, it's pretty difficult to compare them.
kawak Regular Member • Posts: 120
+ iso 1600 on sony is actually iso 2000...just like canon
