Bernard Languillier
Dear all,
I am seeking advice for what appears to me like a rather difficult situation.
First, being mostly a landscape shooter, I have no experience with lighting/interior besides reading a few books on the topic, and do currently only own 2 Nikon flashes (SB600, SB800).
A friend starting to seel Chinese furniture is asking me to help her shooting some images of these for promotion purpose. The idea is to show the furniture in a away as to show how it can integrate in a non Asian interior and contribute to the life style of the person.
The situation I am facing:
1. Is there anyway to cover a subject like this one using Nikon strobes only (I could buy a few more SBs),
2. Knowing that I have been considering buying into lighting equipment for some time now, what would be the best set up to cover both this extreme situation (probably a rare case) while being normally more aimed at portrtait shooting. The criterias would be:
5. What is the best way to produce nice reflections in black lacker furniture when shooting the whole room? Shooting the furniture alone would make it possible to control the environment, but it isn't the case here.
Thank you in advance for your kind help.
Best regards,
Bernard
- the place where it has to be shot is a pretty dark room facing north. The garden isn't very deep, and tall trees filter most of the natural light. A second floor balcony further worsen the problem. My guess is that the natural light will be little, and a bit greenish,
- a very un-attractive neon light source on the ceilling is the main artificial light source in the room (it is a whitish thing with 4 neons in it),
- the flooring is made of reflective wooden floring that has character but appears to be likely to induce more un-wanted reflections,
- the furniture itself is mostly black lacker and are typically pretty large, up to 2 m wide by 2 m tall. Diffuse reflection should contribute little, it seems that a good usage of direct reflections would be best,
- max 3000 US$,
- powerful enough for such cases,
- transportable without a car (but no need for batteries),
- compatible with US and EU voltages.
- the window, neon and possible flash heads will all have different color temparatures. I can probably filter the flash heads to produce neon cast, but how about the windows?
- my guess is that my locating the furniture far enough from the window, it should be possible to have the neon and window light mix in such a way that the whole piece is lit by uniform light, which I would then color correct with a white balance click. On the other hand, the window light is pobably the best source for direct reflections in the black lacker, and I do therefore not really want to locate it too far from the windows.
- Would it make sense to re-inforce the window light by locating a strobe outside shooting through the window? This could be a way also to better control the color temperature of the window light, right?
Best regards,
Bernard
