D30 Serial numbers??
Started Dec 11, 2001 | Discussions
Steve R Contributing Member • Posts: 540
Does anyone know why some D30s have all numbers, and others start with a number but then have a letter?
My first D30 (last week) had a serial number of all numbers. I had to exchange it today for a new one, and this one has a number, then a letter(B), then numbers. Both of these are USA cameras, both from Canoga Cameras, a week apart.
Does anyone know the significance of the numbering scheme?
Thanks in advance. -Steve
Steven R
Steven R
Noldar Regular Member • Posts: 381
Re: D30 Serial numbers??
The D30 serial numbering scheme is a combination of 4 hexadecimal prefix and 5 decimal numbers. The first four hex digits could range from 0000 to FFFF, hence the letters
If Canon could incorporate the serial numbering into the file numbering scheme of the D30 (thru a firmware upgrade) then duplicate file names would be avoided! It seems the 1D uses this file numbering system, and also takes into account the camera's serial number, so the numbering is different from one 1D to another 1D...!
-Arnold
OP Steve R Contributing Member • Posts: 540
Arnold
Thanks for the info, do you know what the first "4 hexadecimal prefix" stand for? From what I can I tell there is only a few D30s with a "b" in the second place?? the whole number is 1b280xxxx whereas my first one was 17280xxxx? So what does the "b" mean? anyone? Thanks! -Steven
1D...!
-Arnold
Steven R
I think the "B" doesn't really mean anything...it's just an increment! I've seen serials like these:
1235xxx, 1335xxx, 1425xxx, 1426xxx, 1536xxx, 1Axxx, 1Bxxx...so I think 1B is the latest in the series!!
-Arnold
anyone
flanker Regular Member • Posts: 173
That's right. In hexadecimal the count goes like that: 0123456789ABCDEF. Then it starts with 0 again incrementing the next position to the left in the same manner ... and so on. That's why you get different combinations of digits (0-9) and letters (A-F) in a serial number.
flanker
Thanks Arnold and Flanker for the info.-Steven
--Steven R
