Windows XP slow to open folders
Started May 2, 2006 | Discussions
Steve_Horn Senior Member • Posts: 1,568
Why is Windows XP so slow to open folders in Windows Explorer sometimes?
I built my wife a machine built on 2.8 Ghz dual core Pentium and Windows XP to replace her old 600 Mhz Pent 2 running Windows 95. She has folders with sub folders that contain lots of small files. Opening these folders for the first time after boot up with the new machine is painfully slow. With her old machine and Windows 95, the folders containing the same files open more or less instantly.
I set the new hard drives to NTFS. Would FAT32 have been better? I have tried turning on and off the 'Indexing service" for the drives but it does not seem to make any difference. Any ideas to speed things up?
Torsten Hoff Veteran Member • Posts: 3,660
Re: Windows XP slow to open folders
Check if the Windows Explorer option to cache thumbnails is on or off.
It is also possible that a program that provides a shell extension (antivirus, compression, even some spyware) is slowing down Explorer.
AmanitaM Veteran Member • Posts: 5,686
I do not know how much time your wife has spent on the new computer, and you definitely should consider the points made by the above poster. However, I just installed XP on a new hard drive and was amazed to find that certain folders, like My Computer and the Control Panel took over 5 seconds to open. However, several days and many reboots later, this problem has completely abated. And I have no idea why. So, time may also factor in here.
RickMac Forum Member • Posts: 90
I had a problem like that.. it was the folder marked for video or music, so it was continually looking for files to display. took a while for it to complete. do you see a music note on the folder background or a film clip in the folders background? I have to right click on the folder for that directory that was slow and click properties, and change it to data. that cured mine.
Shaun Ivory Junior Member • Posts: 42
I have found this helps:
1. Open "My Computer" properties
(here is a shortcut: Win+Break on your keyboard)
2. Select the "Advanced" tab
3. Click the "Settings" button in the "Performance" section
4. Scroll down the list until you find "Use common tasks in folders."
5. Ensure it is not checked (it is on by default)
6. Click OK in the "Performance Options" dialog
7. Click OK in the "System Properties" property sheet
Let me know if this helps you! Not only is it faster, but you reclaim some useful space.
  • Shaun
carl english
carl english Veteran Member • Posts: 9,182
Thanks a lot for that information Shaun, had a dramatic effect on my PC.
Carl
 carl english's gear list:carl english's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-FZ200 Panasonic FZ1000 +1 more
SteveB Veteran Member • Posts: 3,087
5 seconds down to 1.5s for me. Thanks.
Ferenc MOGOR Veteran Member • Posts: 5,625
Two more tips...
Hi,
Here are two more tips:
1. In case you have QuickTime installed on your machine you should check if is installes itself upon start-up. It's a real resouce hog, it slowed down my PC significantly.
Here's how to do:
Go to - Start- Run-type in "msconfig" - go to "Start up" tab - look for "qttask",...if it's there make sure to uncheck it!
2. Here's a goodie: Advanced WindowsCare
You may d/load it from: http://www.iobit.com/WindowsCare.htm
I use it and run it twice a week and it keeps my Windows XP Pro in perfect shape. Licence is free!
Good luck!
Cheers, Feri
'I can look at a fine photograph and sometimes I can hear music. Ansel Adams.'
There's some stuff that XP schedules to run a few days after the installation, as well as periodically thereafter. You can force it to run immediately by using Start -> Run and entering
%windir%\system32\Rundll32.exe advapi32.dll,ProcessIdleTasks
More information on idle task processing can be found here:
http://www.microsoft.com/whdc/system/sysperf/benchmark.mspx
OP Steve_Horn Senior Member • Posts: 1,568
Thanks everyone
I'll try some of these suggestions.
I don't think it a background task that is slowing things down. It consistent, first opening of a folder after bootup - very slow, subsequent opening OK. It is worst on folders that contain sub folders that contain large numbers of small files.
tko Forum Pro • Posts: 12,578
also disable Window indexing
Windows XP indexes every file on every hard drive by default, so later searches are supposedly faster. Doesn't seem to work very well, but it better just to turn of indexing. From memory, right click on a drive or folder, go to properties, then uncheck file indexing, and check apply to all subfolders.
This might fit in w/your problem - the first time is accesses the folder it indexes it, if nothing changes it's good for next time and fast.
DavidMS Forum Member • Posts: 75
If it's slow to open "My Computer" it might be a network issue. If you were connected to a network drive, it will try to reconnect to it, and if its not there will keep trying until it times out. Once it's open, look at the drives under "My Computer" and if any of the network drives show up as disconnected right click on the icon and select the "disconnect" option. (Yes, I know that disconnecting a disconnected drive sounds odd - I didn't write it!)
D
JJMacks
JJMacks Forum Pro • Posts: 10,516
If you are running Photoshop 7 there is a problem
The way to fix the problem is to get into windows explorer right click on a Jpeg thumbnail and click on properties. This will open the Properties Window. This window will have tabs across the top. There is one labeled Photoshop. In the Photoshop Tab uncheck let Photoshop generate Thumbnails then click OK.
JJMack
 JJMacks's gear list:JJMacks's gear list
Canon EOS-1D Mark II Canon EOS-1D Mark IV Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm f/2.8L IS USM Canon EF 180mm f/3.5L Macro USM +3 more
