D200 and AF-S VR 105 Micro 2.8 G
Started Mar 25, 2006 | Discussions
OP Yves P. Forum Pro • Posts: 18,674
I hate mathematicians ... :-)
What I meant is the Stabilisation doesn't vary whathever the focal distance is. I agree with what you are saying about amplitude and closeness of subject but the VR doesn't vary in effectiveness in relation to the focus lenght.
Unless I am wrong or I totally missed the point.
VR on a i:i, from actual testing is very very good, not worse than on longer f dist.
AirBete wrote:
Vr is VR wether you are at long or close range.
Ok but VR effectiveness is dependent of the amplitude of the motion
blur. The problem is that motion blur is proportionnal to the focal
length of the lens AND inversely proportional to the distance
camera-subject when the latter is small. Precisely:
motion blur amplitude = k*f(d+f) d
where k is a constant, f is the focal length and d is the distance
between the subject and the nodal point of the lens.
So the question is still unanswered. How does VR perform at 1:1
reproduction ratio?
AB.
Yves P.
Share the Knowledge
PBASE Supporter
Some pictures I like:
http://www.pbase.com/yp8/root
 Yves P.'s gear list:Yves P.'s gear list
Apple iPhone 11 Pro
Darrelll Senior Member • Posts: 2,209
Re: D200 and AF-S VR 105 Micro 2.8 G
Yves P. wrote:
Lothar Wieland wrote:
Impressive, I oredered one, but still waiting.
By the way, which SW are you using to documentate your photos with
the complete exif data?
A script from photoshop.
did you write the script or download it?
Yves P.
Share the Knowledge
PBASE Supporter
My glamour gallery - Comments appreciated. Link below...
http://www.pixs.ws/gallery2/Models
Darrell
 Darrelll's gear list:Darrelll's gear list
Nikon D70 Nikon D200 Panasonic Lumix DMC-GH2 Nikon 1 J1 Nikon D800 +1 more
It is a java script someone did for me.
you can do a search on this forum.
look for print exif post by Joe Colson.
Yves P.
Share the Knowledge
PBASE Supporter
Apple iPhone 11 Pro
AirBete Contributing Member • Posts: 550
Re: I hate mathematicians ... :-)
Resalut Yves,
VR effectiveness is dependent of only one thing: motion blur amplitude, that is how far from the original position the subject is dancing on the sensor. So if you can get the subject to move the same at 1:1 than at 1:10 you'll get the same effectiveness from the VR. The problem is it is much harder to keep the image still on the sensor at 1:1 than at 1:10 (cf. my previous post). Another way of stating the previous formula is
motion blur amplitude = k* R / d
where k is a constant, R is the reproduction ratio and d the distance from the subject to the nodal point.
Moi j'aime bien les mathematiciens.
AB.
Donald David Forum Member • Posts: 92
If one is using this lens for close to 1:1 macro work on insects etc., how cand the VR be of assistance? In my experience for hand held work of this nature where the focal distance is close to the max of 12 in or so, the main problem is vertical movement, not horizontal. Help me understand how VR helps here? Why not simply use a faster shutter speed?
Matt F Senior Member • Posts: 1,666
Re: VR effectiveness at macro distances?
Yves P. wrote:
HI Matt, Vr is VR wether you are at long or close range. It is
excellent but cannot produce miracles under1/20 sec. Remember that
105 becones around 160mm in FOV.
If you are saying that you can get a sharp hand-held exposure at 1/20th, at 1:1 magnfication, then I would say that is a miracle!
With my 60 mm micro, I feel like I need to keep it in the 1/120th to 1/200th zone at 1:1 to have any chance of a sharp hand-held image.
-- Pmatt
Gallery - http://www.silentcolor.com
Michel Jarry
Michel Jarry Contributing Member • Posts: 648
Bonjour Yves,
I can see that your lens is very sharp but, to my eye, it does not seem to be any sharper than my current Micro Nikor 105 2.8 (non VR) lens. Although, the comparison may be different looking at an actual print.
If you had any experience with the old (non VR) 105 2.8 lens, I would appreciate your comments...
Naturally, the VR option on your new lens is very tempting...
Salutations,
Michel
M. J. Montreal
D2x, SB-800, 12-24DX, 17-55DX, 70-200VR, 105 Macro, TC-17, NPS and NAPP Member
 Michel Jarry's gear list:Michel Jarry's gear list
Nikon Z7 Tamron SP 150-600mm F5-6.3 Di VC USD G2 Nikon Z 35mm F1.8 Nikon Z 14-30mm F4 Nikon Z 85mm F1.8 +4 more
gonzalu
gonzalu Forum Pro • Posts: 10,435
Beautiful Image Yves...
 gonzalu's gear list:gonzalu's gear list
Sony RX100 VII Nikon D500 Nikon D850 Nikon Z9 Nikon AF-S Nikkor 14-24mm f/2.8G ED +21 more
A faster shutter speed and a good tripod if you have time and it is not windy ...
Yves P.
Share the Knowledge
PBASE Supporter
Apple iPhone 11 Pro
Michel Jarry wrote:
Bonjour Yves,
actual print.
Salutations,
Michel
Salut Michel.
First, the VR is the reason why I went this way, second, the working distance and third, the fantastic results even wide open, surprisingly as sharp as a stopped down to F4 Vr 70-200 in appearance anyways. I can't realyy talk about the sharpness compared to the actual 105 (non VR) closed down but wide open, it is a screamer.
M. J. Montreal
NAPP Member
Yves P.
Share the Knowledge
PBASE Supporter
Apple iPhone 11 Pro
Hey Matt, haven't shot a lot of Macro with it yet, I will have to go on a 1:1 test in the near future. I know I can do really good ones at 1/30 for sure ...
image.
Yves P.
Share the Knowledge
PBASE Supporter
Apple iPhone 11 Pro
Michel Jarry
Merci Yves...
Switching or not... This is a question I'll have to answer by myself...
Since I got mysellf the R1C1 Kit, I want the best possible accompanying macro lense...
My best regards,
Michel
M. J. Montreal
