Doug Kerr
wrote:
Here is another list of what's new in the Canon EOS 30D (compared
to the 20D), from the Rob Galbraith site:
angle
Parameters menu of the 20D
for a Canon entry-level or midrange digital SLR
ISO 100-1600 is now selectable in 1/3 stop increments
ISO can be set without taking one's eye away from the viewfinder
Increased burst depth: 11 frames for RAW CR2 shooting, 30 for
Large Fine JPEG and 9 for RAW+JPEG
A more-durable shutter that's rated for 100,000 cycles
A slightly-shortened mirror blackout time of 110ms; Canon's
specification for shutter lag remains the same as the 20D at 65ms
Lock (FEL) indicator
(3 fps) frame rate settings are now included
An Auto setting in the Long Exposure Noise Reduction Custom Function
The ability, like several more-pricey Canon digital SLRs, to
simultaneously apply long exposure noise processing to one picture
while capturing another
The addition of a 3.5% spot metering mode
0.15 second camera startup time
A more-precise 4-increment battery charge indicator
Reduced energy compensation, for a promised improvement of 10%
more frames per charge
folder can hold 9999 photos
rotated on the rear display but appear rotated in compatible
browser software on the computer
The ability to zoom in on a photo in Quick Review mode
During playback, the image+shooting data screen will display
either an RGB or Brightness histogram, file size and will
optionally display AF markings
rear LCD monitor (in addition to the top LCD panel); the camera
settings information screen will also display Images Failed to
Transfer when the WFT-E1/E1A is in use and a transmit error occurs
protocol
Professional (DPP) 2.1, EOS Utility 1.0 (a new image transfer,
camera settings and camera control application), Image Browser 5.6
(Mac) and ZoomBrowser EX 5.6 (Windows); DPP adds user-settable
noise reduction and support for RAW files from the Canon EOS D2000
and D6000
dedicated direct print/image transfer button)
Note that a 3.5% metering spot would be expected to have 62% the
diameter of the 9% ("Partial") spot.
For those who missed it elsewhere, the pixel dimensions are the
same as on the EOS 20D, as is apparently the burst rate.
Note also that. wlthough the ISO sensitivity value appears in the
finder as it is being set, it does not appear there at other times.
This new machine is indeed "the 20D N".
Best regards,
Doug
Visit The Pumpkin, a library of my technical articles on
photography, optics, and other topics:
http://doug.kerr.home.att.net/pumpkin
'Make everything as simple as possible, but no simpler.'
