Test FZ30 Macro..zoom...DOF (pics)
Started Feb 13, 2006 | Discussions
Dave In LA Veteran Member • Posts: 5,057
Did a little DOF/zoom test this evening with the FZ30 and Leica Elpro#2 closeup, a +4.9 diopter. We had a thread recently discussing backing off on zoom for macro. This shows the effects on DOF and edges falloff at effective 200mm and 300mm zoom. Focus is on the 6 1/2" line, at least it's supposed to be. Not too scientific, but it gets the point across that backing off zoom has rewards in DOF
200
300mm
What did I learn today?
When shooting macro with closeup lens, f11 is far superior to wider apertures and that zooming 200-300 is a good range, with 200mm being less edge distortion than 300mm.
Dave in NW Louisiana
FZee30, TeeCon17, Elpro 2 &4, Sunpak 3eight3
Unda Covalava Veteran Member • Posts: 7,154
Re: Test FZ30 Macro..zoom...DOF (pics)
I actually use full zoom macro for the opposite effect - to decrease the DOF and isolate the subject. Nice set-up. The measuring tape appears to be vertical, but I'm sure it's slanted otherwise the test results wouldn't make sense.
OP Dave In LA Veteran Member • Posts: 5,057
actually Unda, the shot angle was between 30 and 40 degrees.
So true DOF is not as much as shown on the rules
