which one is better? takumar wide angle..
pb908
Forum Enthusiast
Balikpapan, ID
Hi all,
after I got screw mount adapter, I am planning to have one or two takumar lens to try. I really one to have a prime wide angle, I need your opinion which one to choose..
as I know, there are 3 type takumar lens :
  • SMC takumar (newest with SMC coating)
  • Super Takumar (multicoated, not SMC)
  • Takumar (single coated)
correct me if I am wrong about this
I'am looking for a 24mm or 28 mm takumar lens,
24mm f3.5
28mm f2.8
28mm f3.5
which one should I choose?
I need your opinion on these lenses performance, sharpness, contrast, flare, etc..
Thanks for the information,
Long Live Pentax
Regards
BK
..MX is Beauty, KX is Reliability..
..DS ??? Cool !!!
I, too, have this lens. Just this weekend past I took some shots of a vase of flowers to see how it did, and I was happy with the results. Below is the resized pic and a 100% crop from the upper-right.
I don't use it too often because even at f/3.5 it is pretty dark, and 28mm isn't very wide at all on digital. I'll often defer to a 35mm when given a choice between these two.
Here you go: RAW converted with CS2, default settings, f/8 with bounced flash:
Crop (unsharpened, 100% size)
It is just a tiny bit on the warm side, but you wouldn't notice unless you shot immediately afterward with another (cooler) lens.
--Sean
