[pics] Hartblei Super-Rotator 80mm/2.8 Tilt/Shift
Started Jan 7, 2006 | Discussions
JensR Forum Pro • Posts: 17,885
Hi!
After the more technically oriented thread
http://forums.dpreview.com/forums/read.asp?forum=1036&message=16584412
here are some pics. All full-frame resizes, so no cheating
First, playing around with throwing stuff out of-focus:
Then, getting things in focus despite narrow DoF:
Just first tries. I had my DS on a tripod. It's not very easy to get angled objects into focus. You can see the focus plane running through the image if you look closely at the background.
Cheers
Jens
Member of LBA (Lens Buyers Anonymous), M-fourty-two section
'LBA knows no bounds, and seeks no justification...' (Jim King, 2005)
http://www.jr-worldwi.de/photo/index.html - Photography, Tech and Geek stuff :}
'Why is everyone answering rhetorical questions?' (Me, 2005)
mickdann Regular Member • Posts: 262
Re: [pics] Hartblei Super-Rotator 80mm/2.8 Tilt/Shift
I can't wait until you take some shots outdoors ! Looks like a lot of scope for some bizzare compositions
How does the Hartblei compare (cost & quality) to the 80mm T$S listed at Rugift ?
http://www.rugift.com/photocameras/mc-80mm-tilt-shift-lens-pentax.htm
I only ask because that also list a 35mm T&S - more versatile for bigger things outdoors.
Keep the pictues coming.
Mick
OP JensR Forum Pro • Posts: 17,885
Hi Mick!
When the weather is ok, this might happen tomorrow!
listed at Rugift ?
It costs less and it offers more functionality: Being a SuperRotator means that tilt and shift axis can be freely positioned. Also, the Arax design shown on rugift is reportedly a pain to mount: The squarish bottom only fits underneath the flash housing if you shift the lens from side to side while turning. As Richard reported, the Hartblei as a bit of a flare problem due to unpainted party inside the lens. Not sure how well the Arax does...
I agree. I had this one on my mind, too, but Richard found some pages indicating that its quality is not up to the same standard, probably because it does not use a medium format lens: This means that more of its image circle, including the bad parts, are used when the lens is shifted/tilted. And as I grew more and more interested in using a T/S lens for product photography and macros, I opted for the 80mm.
Cheers
Jens
John Kami New Member • Posts: 22
OT: Hartblei Super-Rotator 80mm/2.8 Tilt/Shift
This is way OT but I had to say that I love the Audi Quattro car model that is the centre of focus in your first photo. Thanks for posting the photo. Looks like a fun lens to use
Thanks for the info..
Looks like the one you have is a better bet, all things considered......fingers crossed for some good weather tommorow
Mick
Re: OT: Hartblei Super-Rotator 80mm/2.8 Tilt/Shift
Hi John!
Thanks! But I don't think this is OT: You commented on one of my shots.
Kind regards
Jens
daimesu Contributing Member • Posts: 506
Hi Jens:
Bokeh and color looks good. But what I am really interested in are those make-a-city-into-a-toy shots! I hope the weather will be pleasant tommorow for you.
