D200 Predefined "Optimize Image" Settings
Started Dec 21, 2005 | Discussions
Jim Kaye Senior Member • Posts: 2,817
There are 7 options in the Optimize Image menu: Normal (NO), Softer (SO), Vivid (VI), More Vivid (VI+), Portrait (PO), Custom (pencil icon), and Black-and-white (BW). With Custom you can specify 5 settings: Image Sharpening, Tone Compensation, Color Mode, Saturation, and Hue Adjustment. The choices for sharpening, tone comp, color mode, saturation, and hue adjustment in the Custom menu are well documented in the D200 manual, but I couldn't find any description of what choices were being made for each of the first 5 "Optimize Image" Settings.
As read by the "Shooting Data" in Nikon software they are as follows:
NO:
Sharpening Auto, Tone Comp Auto, Color Mode I, Saturation Auto
SO:
Sharpening Low, Tone Comp Low contrast, Color Mode I, Saturation Auto
VI:
Sharpening Medium high, Tone Comp Normal, Color Mode III, Saturation Enhanced
VI+:
Sharpening High, Tone Comp High contrast, Color Mode III, Saturation Enhanced
PO:
Sharpening Med low, Tone Comp Auto, Color Mode I, Saturation Auto
(None of these settings changes the Hue Adjustment from 0 deg.)
Of course wherever "Auto" is the selection, one still can't be sure exactly what the camera is doing on a particular shot.
I should also note that I had Adobe RGB selected as the color space when I looked at this, so Color Mode II was available and apparently isn't what the camera chooses for any of the predefined Optimize Image settings.
In case you were wondering...
Jim Kaye
PBase supporter
 Jim Kaye's gear list:Jim Kaye's gear list
Nikon D7500 Nikon D500 Fujifilm X-Pro2 Nikon D850 Nikon Z7 +3 more
Jrobe Regular Member • Posts: 447
Nice post.
Thanks you.
Kevin Roczey Senior Member • Posts: 1,136
Re: D200 Predefined "Optimize Image" Settings
Jim,
Thanks for taking the time to document that, very nice post.
Kevin R.
Janet Zinn
Janet Zinn Veteran Member • Posts: 4,467
this is really good to know
I have it set up for RAW with Custom settings but I could see that it would be useful to have "Bank B" set up for JPGs with one of these options (VI most likely for my use). Just in case I ever want to shoot Jpgs. Thanks!
Janet
D 2 0 0
D 1 0 0
F 1 0 0
C P 5 7 0 0
http://www.jczinn.com
 Janet Zinn's gear list:Janet Zinn's gear list
Nikon D500 Nikon D850 Fujifilm X-E3 Fujifilm X-T30 Nikon Z7 II
OP Jim Kaye Senior Member • Posts: 2,817
Re: this is really good to know
I also prefer using raw and custom settings but sometimes shoot JPEG and then the predefined modes are more attractive.
Auto sharpening in the NORMAL mode could be a "gotcha" -- might be nasty at high ISOs, depending on how the camera chooses its sharpening setting in the face of some noise. (Have to look at that sometime...)
Jim Kaye
PBase supporter
PAR1967 Contributing Member • Posts: 812
nice post, thanks.
Paul R.
Mark D. Contributing Member • Posts: 551
This is a great post, Thanks!
Katherine Lud Regular Member • Posts: 376
Shamelessly bumping this.
This was great info for me and I just found it.
Thanks, Katherine
Thanks, Katherine (nt)
Jim Kaye
jcnjcn Regular Member • Posts: 449
Where is the 'As read by the "Shooting Data" in Nikon software'? Is it NC?
Jean Claude
Yes, Jean Claude, it's in Capture, also Nikon Browser...
If you open the "Shooting Data" field just under the toolbar in the Browser part of Nikon View (click the little triangle on the left) you can see all the settings relating to the "Optimize Image" options. You can also look in the Advanced Raw tool in Capture to see what the settings were for a particular image and to change them if you want (assuming you were shooting RAW).
Jim Kaye
'I believe that the electronic image will be the next major advance. Such systems will have their own inherent and inescapable structural characteristics, and the artist and functional practitioner will again strive to comprehend and control them.' -- Ansel Adams, 1981
nikonsrme Senior Member • Posts: 1,462
Excellent post Jim, Thanks.
'There is nothing worse than a sharp image of a fuzzy concept.' - Ansel Adams
http://www.pbase.com/nikonsrme
 nikonsrme's gear list:nikonsrme's gear list
Nikon D300 Nikon D810 Nikon AF-S Teleconverter TC-14E II Nikon AF-S Teleconverter TC-17E II Nikon AF-S Nikkor 24-120mm F4G ED VR +1 more
