Thank you for the tips. I have an old Konica set my grandfather left me that has just been sitting up for years. The cameras have battery compartment corrosion and I have just never taken the time to fix it. I have plenty of film cameras that DO work that I am not using. And I don't use Konica.
I am working on a Konica 57mm f1.4, not the 1.2, on my project.
I am using JB Weld ( an epoxy here in the US) to create my pads .
The epoxy has not set yet, so much of this is speculation.
However, I am using the epoxy as I have used it many times in the past and am familiar with how to make a mess and not make a mess.
My goal was to replace the felt with something perhaps more sturdy and firm.
It may indeed be that the foam pads ARE the way to go with this, but I also like to experiment.
I modified the lens by removing the offending projections in the manner described on the website.
I noticed the lens only mounts with the distance markers ending up to the bottom of the camera. Inconvenient, but I know them by feel, I don't need to see them quickly.
I then marked the area on the mount with a ink marker where the camera body pin touches the lens as it is turned. That is the area where you do NOT want to put felt or anything else, again, as mentioned in the website.
Then I mixed my JBWeld and applied it in a series of caterpillar or macaroni shaped mounds in the flat areas on the lens mount, AVOIDING the lens mount screws, and avoiding the lens flange areas. I used a toothpick. Easy stuff, just go slow and a little bit at a time. Remember you can make a mess. Esily cleaned up though.
I built up the epoxy mounds to exceed the height of the outer flange on the lens. This will be sanded or razorbladed down later to fit flush with the flange until it fits the camera. We will know in a few hours when the epoxy sets. There is a 5 minute epoxy and I have used it on some projects, but I feel it will not grip the steel flange as well and that I will not have enough time to form it the way I want until it sets. It sets TOOO fast.
I did notice when the lens is mounted (before applying anything to the mount to hold it tight) that I can hear part of the flange VERY lightly touching the internal camera pins as the lens is rotated on and off. This may NOT occur however once the felt pads OR the method I am using is used as it would tend to push the lens mount further away from the pins. And of course some camera's pins may stick out further than others, who knows? Any way it is something a piece of cellophane tape would fix, or shaving that particular lens flange down by half a millimeter.
I will let you know how it comes out. I will take off the epoxy and try the felt method if this does not work well. Congrats on that 800mm. Sound like a real beauty.
By the way, I have the 14-54 and the 50-200 and a ton of OM Zuiko lenses, so it is not like I am hurting if this does not work well. I just like to play. I have my sandbox. You have yours. The trick is keeping the cats out.
