Raynox HD-6600-55
Started Nov 19, 2005 | Discussions
reggy New Member • Posts: 3
Raynox HD-6600-55
This wide angle convertor lense (for the FZ30) is supposed to be released this month. Has anyone seen any ads or pricing for it yet?
Reggy
lovelife Senior Member • Posts: 2,683
Re: Raynox HD-6600-55
Reggy
I will let you know on Monday when I speak to the importer.
You must see with your vision, if you have time see mine at
http://lovelife.smugmug.com/
jcuknz Senior Member • Posts: 1,994
Remember that often you can take two or more
shots and stitch them with the Arcsoft stitcher supplied free on the CD which came with the camera ... works well .. lot cheaper than buying more glass.
Now a tele adaptor ... that is a different matter completely ... I have the x2.2
 jcuknz's gear list:jcuknz's gear list
Rokinon 7.5mm F3.5 UMC Fisheye CS
Ching-Kuang Shene
Ching-Kuang Shene Veteran Member • Posts: 5,894
Nobody, Asian countries included, has it. Just wait a little longer. It will come as Raynox Japan firmly confirmed that this lens is being tested and will be released in November (although I suspect some delay is always possible).
CK
http://www.cs.mtu.edu/~shene/DigiCam
Nikon Coolpix 950/990/995/2500/4500/5700, Panasonic FZ-10 and Canon A95 User Guides
 Ching-Kuang Shene's gear list:Ching-Kuang Shene's gear list
Olympus D-600L Nikon D7100 Nikon Z7 Nikon AF-P 70-300mm F4.5-6.3G
fmoore Veteran Member • Posts: 7,669
Parsons in South Dakota USA is listing the hd6600pro55 at $149 See http://www.don-sara-parsons.com/raynox/panasonic.html (Scroll down to FZ30) Give them a call and find out what the situation is.
Fred
FZ5 & FZ1v2
http://www.ishots.net
2 in stock
From email: "this lens was specially made for the Panasonic FZ30 camera though it is optically the same lens as the DCR-6600PRO" $149 includes shipping
Fred
FZ5 & FZ1v2
pmjwright Forum Member • Posts: 71
Re: 2 in stock
It may be designed for FZ-30 but with 55 mm threads, no doubt it's suitable for all FZs. I'll be one of many awaiting test reviews.
rstieg Forum Member • Posts: 83
I'm very curious about what's different about this new version? Apparently the thread size, for one. I have an FZ20 and a DCR-6600PRO, which I like a lot. I'm thinking of upgrading to the FZ30 and hoped I could use the DCR-6600PRO with a step ring or different adapter. Does anyone know - is that not a viable option?
Rich
http://richstieg.smugmug.com
genece Forum Pro • Posts: 15,437
Lovelife was going to sell an adapter for that but maybe thats been put on hold.
This is a work around and totally eliminates the dark corners as on the FZ20.
Gene
From Western PA.
Panasonic FZ-10 and FZ 20 and FZ30
B300
T Con 17 --two Tcon 14Bs -- Raynox 2020 pro -- DCR 6600
http://imageevent.com/grc6/toshareonnet
Just trying to learn and it's slow going!
 genece's gear list:genece's gear list
Panasonic Lumix DMC-FZ30 Nikon D50 Nikon D7000 Nikon D7100
Raynox DCR6600 on the FZ30
Rich
I will be selling a special ring for the DCR6600 when installed on the FZ30. It will produce the same results as the HD6600 on the FZ30. I expect my supply in 2 days.
