new d200 spec!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Started Oct 22, 2005 | Discussions
EYANDA Forum Member • Posts: 61
US: $ 1750
UK: £ 1500
Body material Magnesium alloy
Sensor • 23.7 x 15.7 mm CCD sensor
DX format
RGB Color Filter Array
Built-in fixed low-pass filter
10.4 million effective pixels
3:2 aspect ratio
High speed cropped - NO
File formats
NEF (12-bit RAW)
NEF + JPEG
JPEG (EXIF 2.2)
Color space
sRGB (2 modes)
Adobe RGB (2 modes)
sYCC
Lens mount
Nikon F mount
Full size image: 1.5x field of view crop
High speed cropped: NO
Auto Focus
11 area TTL
Multi-CAM2000-ll ( 3 cross sensor)
AF working range: -1 to 19 EV (ISO 100, normal temperature)
AF Assist White light lamp
Sensitivity
Auto
ISO 100 - 1600
Metering modes
3D Color Matrix
Center-Weighted
Spot
Metering range
3D Color Matrix Metering: EV 0 to 20
Center-Weighted Metering: EV 0 to 20
Spot Metering: EV 2 to 20
[at normal temperature (20°C/68°F), ISO 100 equivalent, f/1.4 lens]
Meter Coupling CPU and AI (Automatic maximum aperture indexing)
AE Lock Locked using AE-L/AF-L button
Shutter
Combined mechanical and CCD electronic shutter
30 to 1/16000 sec
Steps of 1/3 or 1/2 EV
Flash X-Sync: up to 1/500 sec
Bulb
Metering TTL full-aperture exposure metering system
3D color matrix metering II
1005 segment RGB sensor
Center-weighted: Weight of 75%(8mm circle) given to 6, 8, 10, or 13-mm circle in center of frame, or weighting based on average of entire frame
Spot: Meters 3.5 mm circle (about 2.5% of frame) centered on active focus area
LCD monitor
2.5 " TFT LCD
Tempered glass coating
235,000 pixels
Backlight / brightness adjustment
Shooting modes
Single
Continuous Full image - 5 fps
OP EYANDA Forum Member • Posts: 61
Re: new d200 spec!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Viewfinder
Optical-type fixed eye-level pentaprism
Built-in diopter adjustment (-3 to +1m-1)
Eyepiece shutter provided
Eyepoint: 19.9 mm (at -1.0m-1)
Frame coverage 100%
Viewfinder magnification approx 0.86x with 50 mm f/1.4 lens
PerL Forum Pro • Posts: 14,049
How do you know?(nt)
EYANDA wrote:
Viewfinder
Frame coverage 100%
Re: How do you know?(nt)
just i heard..
EYANDA wrote:
just i heard..
There are so many rumors floating around. Can you say anything additionally that makes your info more believable?
http://www.pbase.com/interactive
Kevin Forte Contributing Member • Posts: 720
You had me until...
you said it would have the Multi-CAM2000-ll, we all know it won't have that cam, nice try though!
KF
EYANDA wrote:
US: $ 1750
UK: £ 1500
DX format
3:2 aspect ratio
File formats
NEF (12-bit RAW)
NEF + JPEG
JPEG (EXIF 2.2)
Color space
sRGB (2 modes)
Adobe RGB (2 modes)
sYCC
Lens mount
Nikon F mount
Auto Focus
11 area TTL
Sensitivity
Auto
ISO 100 - 1600
Metering modes
3D Color Matrix
Center-Weighted
Spot
Metering range
Shutter
30 to 1/16000 sec
Bulb
entire frame
focus area
LCD monitor
2.5 " TFT LCD
235,000 pixels
Shooting modes
Single
Karl Jacobs Senior Member • Posts: 1,310
mirror-lock-up?....
if this is real, looks pretty good, I'd still like 12MP, but with cam-2000 and 11-point, with the newer metering, it looks good.
of course, this is only the 45th version of the specs that have been posted...
deleted13 Regular Member • Posts: 417
Re: You had me until...
Why not?
So far the predictions seems plausible.
Now, I wonder what kind of sensor the cam has (Sony, Nikon Fuji...).
it is real.. trust me..
i can't no more coment... the source of information
Hogman Junior Member • Posts: 33
I am curious to see how fast this thread will reach 150 posts (NT)
no text
I really doubt they'd use the pro cam in the D200, I hope I'm wrong though.
KF
Kurt wrote:
Why not?
nik0n0clast Regular Member • Posts: 105
Only 10MP! Only three cross-sensors! That's it. I give up. I'm switching to Canon. No wait, Fuji. No, Leica.
Hope you're right (or in the ballpark) on price.
Marco Birri Senior Member • Posts: 1,079
If Nikon is finally following what the market wants, I'm surprised it's not the D2-series Cam2000 that is included.
The F100 had the Cam1300 back in the days and that didn't stop the F5 from selling.
If this holds true, this D200 will be a very F100-like backup to the D2x, and a wonderful primary camera for all photographers who don't need the D2x.
though.
KF
Kurt wrote:
Why not?
 Marco Birri's gear list:Marco Birri's gear list
Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.2L II USM Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm F4L IS USM +3 more
Adam Kmiec Veteran Member • Posts: 4,315
if true im done with nikon
No FF means no sale. i standy by my sig.
Currently refusing to upgrade until Nikon gives me FF.
Norwen Senior Member • Posts: 2,648
MultiCam 2000 + AF Assist White light lamp??
Doesn't sound right at all...
Je ne suis ni pour ni contre, bien au contraire!
Re: if true im done with nikon
Do you really expect D200 to be FF? If Nikon produces a FF it would probably be a more expensive model with a different naming than the successor of D100.
Antonio Rojilla Senior Member • Posts: 1,242
Will you promise this?
Will you promise this???
B. Barker Regular Member • Posts: 399
agreed, although that lamp was also on
the camera in this picture as well, which I thought was strange too.....
http://forums.dpreview.com/forums/read.asp?forum=1021&message=15500395
Bill Barker
Dallas, Texas U.S.A
http://www.pbase.com/b_barker
 B. Barker's gear list:B. Barker's gear list
Nikon D300 Nikon D800 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +3 more
Kenny Regular Member • Posts: 350
Could Multi-CAM2000-ll be the "Special Feature" ???
Since we are all speculating I am hoping the Multi-CAM2000-ll is the infamous "Special Feature" that was the talk of last month
