What does " Meter: 13.9 EV" mean?
Started Oct 18, 2005 | Discussions
JohnK Veteran Member • Posts: 7,169
While looking at Phil's gallery of preproduction R1 photos I see that for each photo he lists the camera information, such as this, for photograph #13, "Info: Focal len: 32 mm, Shutter: 1/400 sec, Aperture: F8, Meter: 13.9 EV, ISO 160". I understand all the terms therein, except "Meter: 13.9 EV". I'm used to thinking of EV in terms of plus or minus two or three, but 13.9 EV has got me stumped. Would someone kindly explain Meter: 13.9 EV?
JohnK
I like to see what things look like photographed.
 JohnK's gear list:JohnK's gear list
Sony Alpha NEX-5 Sony Alpha NEX-5N Sony a6300 Sigma sd Quattro H Canon EF 17-40mm f/4.0L USM +20 more
SMC2002 Veteran Member • Posts: 3,357
Re: What does " Meter: 13.9 EV" mean?
Hiya John,
From the settings used, the "EV" values equate perfectly with the chart, which also gives foot candle and lux equivilants, at the bottom of this webpage.
http://www.fredparker.com/ultexp1.htm
Steve
chris33 Contributing Member • Posts: 642
GREAt info Steve! Many thanks!
Chris
SMC2002 wrote:
Hiya John,
Steve
Doug Kerr Forum Pro • Posts: 20,899
Ev (exposure value) designates exposure
Hi, Jihn,
Ev ("exposure value") is the APEX (logarithmic) designation of exposure. It reflects the combined effect of the shutter speed and aperture.
A shutter speed of 1/400 sec and an aperture of f/8 together represents an Ev of 14.6. That is 2/3 stop less exposure than Ev 13.9 (a larger Ev represents a lesser exposure.).
I'm not sure that the "meter" Ev actually means. It could be that the meter, left to its own devices, would have called for an exposure of Ev 13.9 but that exposure compensation (the value you associate with "Ev" notation) was set to -2/3, which would cause the camera to actually use for the shot an exposure 2/3 stops lower than the metering system was inclined to use (that is, Ev 14.6).
The APEX system of notation is discussed in detail in my tutorial article, "APEX - The Additive System of Photographic Exposure", available here:
http://doug.kerr.home.att.net/pumpkin/index.htm#APEX
Best regards,
Doug
Visit The Pumpkin, a library of my technical articles on photography, optics, and other topics:
'Make everything as simple as possible, but no simpler.'
imbsysop Veteran Member • Posts: 4,963
tis very forum will tell you ..
http://www.dpreview.com/learn/?/Glossary/Exposure/Exposure_01.htm
if needed, email me at : imbsysop@yahoo.com
Horum Omnium Fortissimi Sunt Belgae !
C912G6H1
 imbsysop's gear list:imbsysop's gear list
Sony Cyber-shot DSC-H5 Sony RX100 II Canon EOS 400D Sony a6000 Sony a7 II +8 more
