Epson 2400 Advanced BW
Started Sep 16, 2005 | Discussions
AJMIII Junior Member • Posts: 25
Just received my printer and tried the Advanced BW setting. My first impression is that it overrides the my paper profile. Anyone with experiece with this?
AJM
Chris the tech guy Senior Member • Posts: 1,401
Re: Epson 2400 Advanced BW
actually you need to use "Printer Color Management" (CS2) or "Same as source"(PS7-CS) as opposed to using a profile if you select the advanced black and white mode
Webmaster and Tech Support guy at
http://www.inkjetart.com/
OP AJMIII Junior Member • Posts: 25
Hi Chris,
So which way would you recommend- a custom profile for a paper or the Epson Advanced BW? For example I am using Hann. Photo Rag and was planning on using your profile.
AJM
doubleAron Regular Member • Posts: 467
I have done it both way, using the profile as if it were a color print except selecting ABW mode in the driver raher than ICM and letting the driver do the CM and using ABW mode.
Try both, I have a paper that I like to use the profile on and another that I don't. I think the way you are actually supposed to do it is without the profile though.
Aaron Winters
http://studion6.com
I second: try both (nt)
aIexander Junior Member • Posts: 43
Chris, this is an old thread. but your reply is something I was looking for, so thank you!
a.
