Best way to clean lens advice required
Started Aug 23, 2005 | Discussions
BrianC1 Forum Member • Posts: 51
Hi All
I am hoping that one of the contributors to this great forum will be able to assist me. Shooting with a Zenitar fisheye on my D last week end on the cliffs about 200 feet above the sea. Windy but no obvious sea spray etc. Later I noticed spotting on the lens which I suspect was salt spray. After blowing and brushing lens to ensure no grit etc, I used a lens pen. The lens surface now appears to have a oily apearance. Problably does not effect picture quality but it is a worry. Can anyone advise me how to safetly clean the front element of the lens to get it back to its pristine condition. TIA.
Brian
shane gerrish
shane gerrish Veteran Member • Posts: 5,967
Re: Best way to clean lens advice required
i cleaned my zenitar with kodak lens cleaning fluid and lens tissues several times on my 4 week holiday, while still wet i had to polish dry with a clean dry lens tissue to avoid streaks.
Ds user in the advanced stages of LBA
John Bean (UK) Forum Pro • Posts: 18,035
If you have a microfibre cloth use that.
If you're going to buy something I recommend Pec pads and Eclipse fluid for both sensor and optics cleaning. No smears
John Bean
PAW 2005 Week 34:
See: http://waterfoot.smugmug.com/paw
 John Bean (UK)'s gear list:John Bean (UK)'s gear list
Sony FE 28-70mm F3.5-5.6 OSS Sony E 18-135mm F3.5-5.6 OSS
racehorse in the desert Veteran Member • Posts: 4,103
I usually use the "huff and puff" method. Breathe or blow on the lens to fog it and then clean it gently with a piece of Kodak lens tissue. I have learned to look at the lens more often, like every time I use a camera. I got some prints back from an event and there was a light spot in the same place on some of the images. Upon inspection it appeared that a small piece of gooey food was on the lens, from a dinner I attended.
John Power
Racehorse in the Desert
Useful Links to Past Pentax Forum Threads and some Exceptional Images are at: http://www.solutns.com/pages/pentaxforum.html
tissue.
I'll happily breath on it if I have no Eclipse handy, but lens tissue? No way - it's like fine wet'n'dry. It probably won't hurt a modern hard coating as easily as some of the older ones but I'd rather use well-washed cotton than lens tissue. Pec Pads are great, whether you use breath or Eclipse on lenses. Wouldn't recommend breathing on sensors though
Unusual. I ask for a doggy-bag...
John Bean
PAW 2005 Week 34:
itev
itev Contributing Member • Posts: 504
I use a little water and microfibre cloth Essilor.
itev
*istD
 itev's gear list:itev's gear list
Fujifilm X-T20 Fujifilm X-T2
tissue.
I too use a blower and eclipse and pec pads for the sensor. I would never blow into the camera. but, I don't like putting any liquid on the lens, just personal preference. I use the Kodak lens cleaning paper very gently and have never had a problem in over 20 years.
Ha-ha. No, it wasn't me. I was taking photos near the buffet line and I think I got splashed.
John Power
Marcos_ Contributing Member • Posts: 805
Can you point some link from where can i get those, John? Much appreciated!
This site has lots of information on the subject and liknks to suppliers in various parts of the planet:
http://www.cleaningdigitalcameras.com/index.html
John Bean
PAW 2005 Week 34:
structuresguy Senior Member • Posts: 1,560
Has anyone tried the Pentax cleaning cloth? I bought one from B&H but it is a very odd fabric. Almost a rough texture, like a fine cotton which was washed without fabric softener, then let to air dry. I am actually afraid to use it on any of my lenses. It is nothing like the normal microfiber cloths I usually use.
Lance B Forum Pro • Posts: 30,921
Brian,
You will need to use a special lens cleaning fluid from your camera store and the lens tissues specially formulated for lenses. Only use the lens pen after you have cleaned it with the fluid/tissues. The lens pen is an excellent "finishing" off device which leaves the lens clear and streak free but only once you have removed the major contaminants of dust, dirt and grease etc. The lens pen will only remove slight finger prints, and the smears left by some lens fluids and of cousre your breath.
I use the lens pen in this manner and it is a great tool once you have removed the large contaminants.
Lance B
 Lance B's gear list:Lance B's gear list
Nikon D500 Nikon D850 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Teleconverter TC-17E II +14 more
rke21 Regular Member • Posts: 468
years.
That's serious stuff. I cap my lens with an uv filter. I usually clean it with something convient like my t-shirt. I've tried using napkin, toilet paper, paper towel and my workout towel. they seem alright. the toilet paper leaves a lot of dust/lint. Sometimes, they just smear things out. Like when you have fingerprint, and you're wiping it with shirt. Sometimes smears it out. Chamois work pretty good though. Dish washing sponge is pretty good when it's wet. There's no damage or anything. These things are tough!
frank
frank Veteran Member • Posts: 6,961
Bought those Pec Pads and Eclips fluid for my lenses several months ago. Now I don't use my microfibre cloth anymore. The best lens cleaning kit by my limited experiences. Just bought another pac of Pec Pads (100 pieces), should last for a while.
Cheers!
Frank
 frank's gear list:frank's gear list
Fujifilm XF1 Pentax K-3 Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +1 more
OP BrianC1 Forum Member • Posts: 51
Thanks to you all for your most useful advice and particular thanks to John Bean for the link which enabled me to track down the Australian distributor of Eclipse and Pec Pads. I've got my order in. As always a most helpful and friendly group.
Cheers
Brian
shane gerrish
who is the aussie distributor ?
Cheers
Brian
Joele Veteran Member • Posts: 4,633
Pec Pads
I don't clean my lenses that often... Although salt is something I would been keen to clean off
I keep a zip lock bag with some Pec Pads in my camera bag and I use eclipse foro cleaning my sensor, but I don't carry it around I have a little pump bottle with Kinetronics MC safe cleaninng solution...
Joel - *ist DS/P30n/SFX
http://www.pbase.com/joele
 Joele's gear list:Joele's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Panasonic Lumix G 14mm F2.5 ASPH +3 more
Pec Pads
Shane try http://www.nulab.com.au . A Melbourne based company.
Cheers
Brian
itev
this can help:
http://www.minstrument.com/assets/abduke.pdf
itev
*istD
itev
I read that Leica recommended simply to use water as liquid of cleaning
itev
*istD
The microfiber cloth cleaning method concerns me becuase it seems that it could accumulate dust, or whatever you are removing from the lens, and over time become somewhat abrasive. How often should it be replaced? Or somehow cleaned? I have seen them for sale in camera stores, but have not purchased one for that reason.
John Power
