I scratched my LCD :(
Started Aug 13, 2005 | Discussions
Ben78 Regular Member • Posts: 359
Put camera in bag today and the front of the filter on my fa50 has a knurled section and I now have a nice scrape on the screen....
Ben
Nth NSW Australia
*ist DS w/Sigma 18-125, FA50mm f1.4, FA100mm f2.8 Macro
Sony DSC-P72 - don't mind if it gets dirty camera...
racehorse in the desert Veteran Member • Posts: 4,103
Re: I scratched my LCD :(
Yep, it can happen. When I first got my D I noticed some small scratches on the screen withing the first week and put a Hoodman protector on it. Just becasue you wrote this, today I am going to buy a PDA type protector and cut it to fit my DS.
John Power
Racehorse in the Desert
Links to Common Past Pentax Forum Threads and some Exceptional Images are at: http://www.solutns.com/pages/pentaxforum.html
John Bean (UK) Forum Pro • Posts: 18,035
Try polishing it with brass polish, it works surprisingly well if the marks are not too deep.
John Bean
PAW 2005 Week 32:
See: http://waterfoot.smugmug.com/paw
 John Bean (UK)'s gear list:John Bean (UK)'s gear list
Sony FE 28-70mm F3.5-5.6 OSS Sony E 18-135mm F3.5-5.6 OSS
Rod1429 New Member • Posts: 5
You can buy something called Displex which is a scratch removing cream, it works on mobile phone screens & the like.
I have not used it on my DS as i have been fortunate not to scratch it yet!! but it may be worth a try - you can pick it up on ebay for a couple of pounds.
David E. Forum Member • Posts: 55
You're right about the Brasso..
Great tip.. it did work for me. Sensor cleaner, anybody.
Johnist New Member • Posts: 15
Re: You're right about the Brasso..
if the scratches are deeper you could try wet and dry sandpaper (used wet) ending up with the finest grain available. Then finally with Brasso or similar metal polish
johnist
Yes, I've done that too. Works a treat
I'm more careful these days. The last time I used that technique was on a scratched-up Sony WatchMan TV - anybody remember those? Pocket sized B&W TV with "folded" 2" flat CRT display. Early 80s technology, before LCD.
John Bean
PAW 2005 Week 33:
John W. Senior Member • Posts: 2,190
Information on polishing
This may help http://www.cityplastics.com.au/polishing.html
John W
The only normal people are the ones you don't know very well....!!!
AZ Bob Regular Member • Posts: 219
I have a friend in the jewelry business who frequently uses toothpaste as a polishing compound for jewelry and for plastic display panels on watches which are like those on our cameras.
You don't need to get fancy with things like whitening agents and so forth and no gels...
Use a small amount on a damp cloth and work in a circular motion.
It does work.
Ian Loveday Regular Member • Posts: 233
All interesting as I have a couple of scratches on mine... however what I did was get hold of a replacement LCD screen from Pentax (its just a cover really, a piece of plastic held on with double sided tape!) actually I got two, just in case.
I have not fitted it yet as I figured I'd get a bit more mileage out of the scratched one. Has anybody else had experience of changing it themselves raher than going back to their dealer? it can't be rocket science.
IML
A camera is for life, not just for Christmas.
OP Ben78 Regular Member • Posts: 359
Cool, I thought that may be the case when I was looking at it. I will give the polish a go and if that doesn't work, order a new screen and a hooded protector.
Thanks all!!
Ben
Nth NSW Australia
