Do You Use Eclipse/Pec Pads to Clean Your Lenses?
Started Jul 29, 2005 | Discussions
lefty from Saratoga Contributing Member • Posts: 613
If so, why do you think this is a good choice?
If not, why not? What do you use?
Bernie
Saratoga Lefty
http://www.pbase.com/saratoga_lefty
Paul Beiser Regular Member • Posts: 360
Re: Do You Use Eclipse/Pec Pads to Clean Your Lenses?
Hi Bernie,
Hope all is well, have fun with Ron et al in Alaska. I used to use these for sensor cleaning, but now I use the Visible Dust products.
I dont use these to clean my lenses. I use a Lens Pen, and if that does not get it clean (both ends), I use a microfiber cloth and a quick breath.
-paul
Greg Gebhardt
Greg Gebhardt Forum Pro • Posts: 25,501
Do not forget the sensor brush
While wet cleaning is always going to be required, I have found that wet cleans can be required much less if you use the sensor brush. I did not think it would work but I was wrong! An outstanding product!
Greg Gebhardt in
Jacksonville, Florida
http://www.pbase.com/greggebhardt
I don't list my equipment as it ticks people off!
 Greg Gebhardt's gear list:Greg Gebhardt's gear list
Sony Cyber-shot DSC-RX10 Leica Q Leica M9 Nikon D4
Ken Plotkin Senior Member • Posts: 1,682
Yes.
It works.
OP lefty from Saratoga Contributing Member • Posts: 613
Re: Do not forget the sensor brush
I bought the Sensor Brush to clean my sensor but I've never heard of anyone using the Sensor Brush to clean lenses???
Bernie
Saratoga Lefty
Is there any reason not to use it? Is it too harsh for the lens coatings?
Bernie
Saratoga Lefty
Hi Paul!
How's it going with you? Been on any unique photo trips lately? We had a great time in Bryce Canyon last month and I'm really excited about Alaska. I don't have the Lens Pen but I know Ron uses one. Seems kind of small for cleaning an entire lens. Is there a reason you don't think Eclipse and Pec Pads will work on the lens?
Bernie
Saratoga Lefty
redwoodroadie Veteran Member • Posts: 6,456
Don't use Pec-Pad on lenses
It just smudges the hell out of them.
I use coolmax headband and then blow the lint off for the lenses.
photogeek Senior Member • Posts: 1,392
Same experience
PecPads leave really bad smudges on the glass. The only reliable way I've found so far is to use an old white cotton t-shirt washed multiple times (to remove loose lint). Works like a charm, every time.
TartarFan Veteran Member • Posts: 3,139
AND A ROCKET BLOWER!!
John
(TartarFan)
Lens Lust Anonymous member (Less than 30 Day's clean)
http://www.TARTARFOOTBALL.COM
Re: Hi Paul!
Hey Bernie,
Thanks for the note, and I went and looked at your pbase galleries from that utah trip - you got some really nice shots, and it looked like you all had a great time! Was in the Grand Caynon for 8 days in May doing a photo workhop, and it was spectacular.
It's amazing how well a lens pens works on a large lens (esp if you use the Giotti Rocket Blower first).
It looks to me that Eclipse/Pec Pads should work great on a lens (after all, hell, we have been using that to clean our sensors, although I think the sensors have a very dense hard AA filter in front of them).
have a GREAT time in Alaska, look forward to your pics.
-paul
the lens?
Re: Hi Paul!
Paul,
Went out and bought the Hakuba Lens pen this afternoon. Was nervous to use it on a lens but I had a really bad smudge on my B+W Circular Polarizer. Hit it with the Lens Pen and bingo it's gone and the filter is clean a as can be. I'm sold. I keep UV filters on all of my lenses so I'll be cleaning them all with the Lens Pen from now on. Thanks,
Bernie
Saratoga Lefty
I have the Rocket Blower. Just got the Hakuba Lens Pen and it works great!
Bernie
Saratoga Lefty
Uh-oh. I misread the question...I'm so used to seeing Eclipse/Pec Pads talked about for sensors.
I retract my answer!! I use that combo for my sensor. But not for lenses. The stuff is too harsh, and if you use anything but a Pec Pad it leaves streaks.
I use filters over my lenses, and never have to clean them. I use breath and a tissue or pec pad to clean the filter. If I do have to clean a lens, I use breath or lens cleaner and Kodak lens tissue.
Sorry about not being alert first time around.
Ken Plotkin
Ken,
No problem; I assumed you had misread it. You really should try the Hakuba Lens Pen; I just got one today and it is very good.
Bernie
Saratoga Lefty
Lens pen sounds like something I should add in next time I order stuff from B&H or wander into a local dealer.
I actually do have a little bigger lens cleaning arsenal than breath and tissues. I've got a bottle of Clear Sight lens cleaner, a couple of microfiber cloths, and a Giotto Rocket Blower.
This thread reminds me that I should give my protective filter a careful cleaning with Clear Sight and a microfiber cloth tonight. I'm headed on the road for a couple of weeks, and I should at least start with a clean filter on the lens I'm taking. Just did a quick swab this afternoon with breath and a tissue - it deserves better.
Ken Plotkin
Ken,
So you can use lens cleaning solution with a microfiber? I guess I thought you either used the microfiber alone or you used the lens cleaning solution with lens tissues; didn't know you could combine the two??
Bernie
Saratoga Lefty
brokenz Veteran Member • Posts: 9,098
works great!
Bernie
Saratoga Lefty
Same here. There aren't many times just the Rocket Blower won't take care of it though. Sometimes I use the LensPen. I've been using them for years and have never had a scope or lens damaged. I've used Eclipse and the included PecPads without damage but it does leave streaks usually.
Banned from the 3-0-0-D forum since 6-2005.
Does not play well with others.
SteveDoubleU Contributing Member • Posts: 859
If eclipse left streaks on lenses....
then it would do so on a sensor also. Eclipse is alcohol, it evaporates to nothing.
Re: If eclipse left streaks on lenses....
Actually if you use too much Eclipse you will leave streaks behind on the sensor. I've seen streaks on my lenses after using Eclipse but I believe it was residue left over that the cleaning distributed differently.
