Finding serial number ...
Started Jun 16, 2005 | Discussions
Dound Regular Member • Posts: 149
Is it possible to get the serial number of your camera from Canon if you have registered the product with them? I have all the information I registered with, but would like them to send me the serial number. Any help would be appreciated. Thanks ...
~ Dound
tominboston Senior Member • Posts: 1,914
Re: Finding serial number ...
Why not just look on the bottom of your camera?
kcwan Senior Member • Posts: 1,780
Because it's probably gone
350D serial number disappears after a while, usually in less than a week :-S
Well that's a nice feature :^(
I don't suppose it would be on the box somewhere? On my 300D it's on a little metal plate on the bottom of the camera. On my 1DMkII it's etched into the camera body.
Tom
week :-S
Yorkie Contributing Member • Posts: 604
Re: Well that's a nice feature :^(
Hi,
Use Canon DPP and right click on any thumbnail, select info, and the serial / body number is at the bottom of the list.
Yorkie
OP Dound Regular Member • Posts: 149
Thanks a ton -- will try that out now.
~ Dound
Worked, thanks. Looks like when I process the RAWs with CS2 and save copies in JPG and DNG, the body number is stripped from the EXIF data for reason. Luckily, I had a few of the first pictures I took when I got the caemra (with full auto) so the body # was still attached to the original JGG output. Thanks again.
~ Dound
Habemus_Canon Senior Member • Posts: 2,437
week :-S
Not all of them. Just some of them in certain serial number ranges.
Here's the Canon tech notice:
April 15, 2005
We discovered that, for some of the EOS 20D and EOS
Digital Rebel XT models that were produced during a
certain period of time, the body number printed on the
label had worn off following use of the product. This
problem affects some products in the following serial
number ranges:
EOS 20D:
Body No. "0910400001 - 0910402496",
"0920400001 - 0920407771",
"0930400001 - 0930417770"
EOS Digital Rebel XT:
Body No. "0310100001 - 0310112966",
"0320100001 - 0320105992",
"0330100001 - 0330127407"
The body number becoming faint or wearing
off does not affect the product functionality.
It also does not affect warranty service since
the body number is recorded as data in the
product. Please contact your local service center
if you encounter this problem.
 Habemus_Canon's gear list:Habemus_Canon's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD600 Canon PowerShot S90 Canon EOS 350D Canon EOS 7D +14 more
It's on the side of my 350D box, with a barcode just above
the UPC barcode.
biggus01 Regular Member • Posts: 123
I had the same problem. I e-mailed Canon U.K. eventually they arranged for the camera to be collected from my home address and returned to me by UPS. They added a new number and updated the software. They even updated the sticker on the side of the box with the new number.
All this was after I pointed out that it was a manufacturing fault. Initially they wanted me to pay for the cost of getting it to them.
On the plus side the whole process took about a week.
dibber Regular Member • Posts: 409
Was it the original number they put on it or a different one?
sounds like a new one
"They added a new number and updated the
with the new number. "
Dave Lewis Forum Pro • Posts: 10,425
I accidentally rubbed one off in a camera store a while back, just two rubs with my thumb.
Dave Lewis
