Spotlight Question
Started May 6, 2005 | Discussions
Scott Rullmann Junior Member • Posts: 30
Spotlight Question
All TIGER users...
The spotlight feature of Tiger is very intruiging. However, I have been trying to find an answer to this question:
Is ther anyway to associate the same keyword to multiple files at one time?
I have been thinking of getting a portfolio type program to help me organize all my images. However, if I can do this keyword "loading", I could use Tiger and spotlight.
Thanks for any info you can provide,
Scott
SlideShowBob Contributing Member • Posts: 766
Re: Spotlight Question
Did you try Automator? You could use the "Add Spotlight Comments to Finder Items" workflow. Would that do the trick?
Scott Rullmann wrote:
All TIGER users...
one time?
Scott
OP Scott Rullmann Junior Member • Posts: 30
Interesting idea. I will look into it later.
Kendall Helmstetter Gelner Forum Pro • Posts: 20,587
That totally works, great idea
Hey, that was a great idea! That totally works, I created an automator workflow with just the "Add spotlight comments" action and drug a few files into it. I fed in my own unique string and right after running it spotlight found those files I had tagged.
The interesting thing about this is that just a few days earlier I had tried to do the same thing using extended attributes (for the same reason as the original poster), and the xattr command obtained from the Ars Technica review. I figured that any extended attributes I had added would be picked up by Spotlight - sadly not so! Perhaps only certain extended attributes are picked up.
After running the Automator action to add comments, I tried listing extended attributes of the file and it found one:
com.apple.FinderInfo
But this appeared to have no value - I imagine it really just has a value the command line utility is not fond of returning but that Finder can read, which is a little sad as I would like to be able to tag files from the command line (but I'm sure there is a way).
I'm not sure what the downside is to using this finder comments deal, it does seem like if you tag it wrong it's a bit annoying to fix. You can always have the comment overwrite if you like though so I guess that's a way to fix it.
Thanks again for the great idea, and for piking my curiosity enough to load Automator for the first time.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
