Dragan effect 10 step tutorial file
Started Apr 2, 2005 | Discussions
Zulabarr Forum Member • Posts: 53
Does anyone know where I can find this? I've searched the forum, and none of the links mentioned are currently working. If someone could email it to me, I'd appreciate it. Thanks.
danmurrelljr Senior Member • Posts: 1,058
Re: Dragan effect 10 step tutorial file
I was wondering too. I did find this tutorial with google though, it says it could be extended to create Dragan-like effects.
http://www.thelightsrightstudio.com/DigitalDarkroom/LearningGalleries/LowKeyLightingEffect/LowKeyLightingEffect.htm
Dan
 danmurrelljr's gear list:danmurrelljr's gear list
Canon EOS M50 Canon EOS RP Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
Bill_Turner Veteran Member • Posts: 7,532
Here:
Please don't kill my website!
http://www.wmdturner.com/10steps10-25-04.psd
It's almpst 7MB so it may take a bit to download. Save it to your favorite folder then open it in Photoshop.
(afka Wile E. Coyote)
Bill
PSAA
Equipment in profile.
If you can visualize it, then create it in the camera, finish it off with the print that matches your mind's eye then you are, most likely, a master...
joe325 Regular Member • Posts: 281
There is an action available here
http://www.atncentral.com/download.htm
Joe
Doesn't work in PSE3. However, I have the original file converted now if anyone needs it.
http://www.mutantsoup.com/10steps.zip
I'll keep it there for a while unless it gets so many downloads that my bandwidth usage starts costing extra.
DonaldS Contributing Member • Posts: 615
Re: Here:
Hi,
Thank you.
I downloaded it quickly (cable modem) and have been trying to figure out how to run it, ever since.
As you may have gathered, I am not the brightest bulb in the socket.
DonaldS
chuxter Forum Pro • Posts: 21,714
Thanks, Dan...I've been looking for it for a LONG time. Now that I have it, can you tell us "dim bulbs" how to use it in PSE3?
TIA
Charlie Davis
CATS #25
'I brake for pixels...'
 chuxter's gear list:chuxter's gear list
Nikon D810 Nikon D500 Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004) Sigma 24-105mm F4 DG OS HSM Tamron SP 150-600mm F5-6.3 Di VC USD +2 more
OP Zulabarr Forum Member • Posts: 53
Thanks, everyone! (n.t.)
I look forward to giving it a try.
I just got it yesterday myself, but I did a quick run through. Apparently in the Photoshop version of the file, there are two layer sets- one shows the result of each step with instructions, the other is a layer of each step. A separator layer was inserted between those two sets of layers after unrolling them into normal PSE-compatible layers. Basically, locate that layer separator, turn off all the layers above it, then start turning on each layer from the bottom up starting at that separator. Each layer has instructions on the right side describing what to do with your own images.
Dan
Hmmm...
images.
When I open YOUR "10step.psd" file in PSE3, a "New" box appears:
So I give it a name, like "Dragan10Step" and then PSE3 opens with a big 2000x3000 pixel pic of a white piece of foam core. There is only one background layer, as far as I can tell. Wasup?
Charlie Davis
CATS #25
freelancer54 Contributing Member • Posts: 966
Hi,
I was surprised to see this thread, sorry I didn't see it earlier.
I still have the psd file at an email account that can be forwarded to those who email me.
There are 2 different files, one for photoshop and one for elements. The file in both cases is approx. 7 megs. Please make sure your email provider supports large attachments.
You can email me at:
dpreviewfreelancer54(at)yahoo.com
Please let me know if you'd like the ps or elements version.
freelancer
Never mind...
chuxter wrote:
When I open YOUR "10step.psd" file in PSE3...
After my 2nd cup of coffee, the bulb brightened a bit. I was trying to open your zipped file. Duh...
I got it now. Thanks.
Charlie Davis
CATS #25
Thanks, Laura. I finally got the one that Dan has...
Charlie Davis
CATS #25
amitis Contributing Member • Posts: 526
Click on Layers and expand (nt)
(nt)
NickB. Contributing Member • Posts: 741
Re: Here:
Just open with PS, hide the copyright layer, and then start revealing the layers step-by-step. I'd never seen a tutorial like this before either, but it's quite effective once you learn how to work it.
Cheeers,
Nick
Re: Never mind...
Hehe, yeah I zipped it to save a little on my bandwidth and 56k users' time...
Dan
PhotoBobbie Regular Member • Posts: 153
Thank you, I was looking for a way to do this in PSE.
checknumber96 Junior Member • Posts: 49
Hi freelancer , unable to email you for the psd file , dont know wether it because I am AOL, keeps returning my mail from that address, cheers
 checknumber96's gear list:checknumber96's gear list
Olympus E-M5 II Olympus PEN-F Olympus 40-150mm F2.8 Pro Olympus 12-100mm F4.0
Hi checknumber96,
I emailed you the file. It's very old, but I hope you find it useful.
Search dpreview, many members have since developed techniques that are quite nice.
regards, freelancer
