Macro shots taken with the EF18-55mm lens?
Started Jan 13, 2005 | Discussions
amourantha New Member • Posts: 9
Hey. My first time on the boards here.
I'm seriously considering getting a Canon 300D. I would just like to know how good the supplied lens is for macro shots (seeing as I'll be spending a lot of time doing macro and portrait photos).
I'd be very grateful if someone could show me some uncropped/unedited macro shots taken with the Canon 300D and it's EF18-55mm lens.
Thanks very much,
Samantha
dougsmit Senior Member • Posts: 1,362
Re: Macro shots taken with the EF18-55mm lens?
While the kit lens focusses reasonably closely (.9 ft) it is not good for true macro. It will do fine for whole flowers but you will need help to do insects etc. I don't have 'uncropped and unedited' to post here (the files from this camera are much too large to post without altering) but this is just reduced to fit:
DSPographer Senior Member • Posts: 2,464
The kit lens as is has max magnification of 0.28x so the min landscape format subject width is 82mm or a bit over 3 inches. You can get more magnification with a close up lens (get a double element one like the 250D or Nikon's) or an extension tube. A 12mm extension tube would be the best length for the kit, it gives a magnification range of 0.23x to 0.81x. Check to make sure the tube fits before buying a third party one since the EF-S type lens mirror bumper may not fit.
EF18-55mm lens.
Thanks very much,
Samantha
 DSPographer's gear list:DSPographer's gear list
Canon PowerShot G7 X Canon EOS 5D Mark II Canon EF 24mm f/2.8 Canon EF 28-135mm F3.5-5.6 IS USM Canon EF 50mm f/1.8 II +4 more
Yohanes Mangitung Regular Member • Posts: 350
Taken with the kit lens and DReb / EOS 300D. It's a truly decent or should I say great starter lens. Hope these help!
http://www.pbase.com/mangitung/image/30586811
http://www.pbase.com/mangitung/image/30586808
http://www.pbase.com/mangitung/image/30761163
http://www.pbase.com/mangitung/image/30761323
Sincerely,
Yohanes N. Mangitung
Tom Hole Regular Member • Posts: 249
Samantha,
The kit lens is a good value. Other lenses are sharper, but I have taken to recommending that folks decide for themsleves. I decided to upgrade because I thought the kit lens was not sharp. Turns out, my workflow was the problem, and maybe not the lens. I haven't gone back to verify this, so I could be wrong.
Anyway, here are a couple macro shots. Unedited, uncropped. A little USM goes a long way on macros. If you want to see the edited versions, there are here (EXIF is there as well):
http://tomhole.com/Focus%20Comparison%20Page.htm
I think I would be happy if all I had between 18-55mm was the kit lens. I might re0install it for a better evaluation now that I have had other lenses for a while.
Tom
Digital Rebel, Canon 17-40 L, Sigma 18-50 2.8 EX, EFS 18-55, 28-135 IS, 80-200 2.8L, 75-300 IS
EF18-55mm lens.
Thanks very much,
Samantha
OP amourantha New Member • Posts: 9
Wow! Absolutely beautiful photos! Thankyou very much for sharing them!
Thanks very much for sharing! Lovely pictures.
Tom Hole wrote:
Samantha,
Tom
EF18-55mm lens.
Thanks very much,
Samantha
Martin Ocando
Martin Ocando Veteran Member • Posts: 6,054
You can check my macro gallery at http://www.ocando.net/gallery/macro.htm
Here are just a few samples. Some are taken with a +4 close up adapter, and some others with a nikkor 50mm MF lenst inverted over the 18-55mm with a male to male adapter ring.
You can also check my tutorial at http://www.ocando.net/macrolight_en.htm for the macro setup I've been using.
Martin Ocando
 Martin Ocando's gear list:Martin Ocando's gear list
Olympus E-M1 Olympus E-M5 II Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +10 more
John A Richmond Regular Member • Posts: 199
As others have said, it's a close up rather than macro lens. It's not as sharp as a macro lens would be, nor can it focus as closely. Having said that, it seems to do a pretty reasonable job for close ups.
Here's a Camellia I shot in my garden today:
and here's a 100% crop of the central boss of stamens.
The original was shot at ISO 200 in shade, 1/30sec at f8 and is uncropped. Parameter 2 and USM in Photoshop of 300, 0.6, 2. Apart from resizing I used no other post processing on the original JPEG.
Hope this helps
John Richmond
Thankyou so much for that!
Marcus Beard Senior Member • Posts: 1,159
Nice pics!
Good test of what the kits lens can do - I have been pleasanty surprised by the kit lens for close ups too.
Marcus
 Marcus Beard's gear list:Marcus Beard's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Canon EF 300mm f/4.0L IS USM Canon TS-E 24mm f/3.5L II Carl Zeiss Distagon T* 2/35 +6 more
Mercurio New Member • Posts: 14
Hi
Here are a few closeups shot with the kit lens.
Mercurio
http://www.bistrom.nu/Vaxter/index.html
EF18-55mm lens.
Thanks very much,
Samantha
Thankyou very much! The photos you provided were very helpful.
ups.
Hope this helps
John Richmond
pineapple Contributing Member • Posts: 817
Re: Fantastic photos from you all
I would like to say thanks also for showing all your photo's in this thread.
I am also interested in taking these sort of photo's and only purchased my 300d in November, so this has been very useful for me too, as I havent had a huge amount of time yet to experiment with it, but spring is just around the corner
In time I hope to get a macro lense, although not just yet as I had to get a telephoto first, so it is very nice to see these pics taken with the standard lense. Thanks!
P
gio14 Regular Member • Posts: 103
please, can you explain me the meaning of inverted???
I mean how to do and which benefits you get
proto23 Junior Member • Posts: 29
This isn't exactly what you're asking for - it's been cropped slightly, resized for the web, and sharpened a bit, but you can easily do this with the kit lens and some closeup filters.
EF18-55mm lens.
Thanks very much,
Samantha
Martin Ocando
The instructions are on my site, on http://www.ocando.net/macrolight_en.htm , but is simply threadding a male/male ring on the front of the kit lens, and screwing the normal in the ring, inverted. Both lenses will be face to face, and the kit lens mounted on the camera, of course.
The benefits, are extremely high magnification. You are simply using a very high quality close up attachment lens (a 50mm) but a very fine one, high quality corrected optics. That's it.
Regards
Martin
Martin Ocando
