On 7D flash synch speed
Started Nov 7, 2004 | Discussions
Geir Ove Veteran Member • Posts: 3,115
Hello,
There was a thread covering this subject some time back. I have been contemplating the subject for a while, and thought I would share my insights:
The 7D has a synch speed of 1/160 sec if I am not wrong. From the tables in the Minolta 5600 HS(D) manual, we can read (indirectly) on page 76 that the max flash duration of the 5600 must be less than (or equal) to 1/250 sec.
A flash will deliver its power (guide number) through its brightness and flash duration. For a camera to fully utuilize this light its shutter speed must NOT be faster than that flash duration. So for the 7D, we could have had a flash synch speed of 1/250 sec. to fully utilize the power of the 5600.
( The HSS mode allows us to use faster shutter speeds, but at the cost of reduced guide number. The effective guide number will be
G / Sqrt(S/250) where S the selected shutter speed larger than 250.)
So why doesn't the 7D synch at 1/250 sec? That one I am not sure of, but I see 2 possibiities:
a) Technical limitations in the cameras design
b) Maybe KM wanted us to be able to utilize Flashes that are slower than 1/250 sec at their max Guide Number: Studio flashes or 3. party flashes?
Geir Ove
My album at: http://objective.bitfikler.com/geirove/web/
 Geir Ove's gear list:Geir Ove's gear list
Huawei P30 Pro +1 more
Desmond Lim Veteran Member • Posts: 3,255
sync speed
Hi Geir,
No, if spec given sync speed of 1/160, any shutter speed greater than that will result in incomplete exposure unless HSS is enabled. Nice articule for reading..
X-Sync
http://www.photozone.de/3Technology/flashtec4.htm
HSS
http://www.photozone.de/3Technology/flashtec5.htm
Cheers!
Geir Ove wrote:
Hello,
share my insights:
party flashes?
Geir Ove
Des
'Charter Member of the Konica Minolta 7D Adoption Society'
OP Geir Ove Veteran Member • Posts: 3,115
Re: sync speed
Yes, I agree with that. But that is beacause of the curtain synch problem, and not the flash speed. I looked at it from the flash performance point of view.
Geir Ove
Desmond Lim wrote:
Hi Geir,
PerOP Regular Member • Posts: 247
Re: On 7D flash sync speed
The actual duration of the strobe (full output) is probably a bit shorter than 1/250sec. I have not been able to find the figures for the 5600HS(D), but the 5400HS has duration times from 1/50000 to 1/600, and the 5600 should not be far off.
In an earlier interveiw (sorry can't find the link) a KM engineer explained that they had to design a completely new shutter for the 7D, and as a consequence of the integration with AS had to limit the sync speed.
So I guess the answer to your question is:
Rgds PerOP
Geir Ove wrote:
Hello,
share my insights:
party flashes?
Geir Ove
 PerOP's gear list:PerOP's gear list
Sony a6300 Sony a7R III
Alex Escada Regular Member • Posts: 291
Re: On 7D flash synch speed
Sync speed is a limitation of the shutter, expensive shutters are faster. Nikon can achieve 1/500 because the CCD can "simulate" a shutter.
Geir Ove wrote:
Hello,
share my insights:
party flashes?
Geir Ove
Patrick H Lockwood Contributing Member • Posts: 612
Re: sync speed
Desmond Lim wrote:
Hi Geir,
Not necessarily. Sometimes X sync is a conservative number.
Although my E1 has a reported X sync of 1/180, and the dedicated flash unit, when communicating to the camera, will not allow faster than this, unless HSS, I can sync at 1/320 with third party flashes. You just have to try it with a non TTL or non communicating flash to see what the real X xync potential is.
Patrick
JackRiley Senior Member • Posts: 1,136
I think it because KM had to use weaker springs in the shutter mechanism in order to avoid vibration, vibration that would interfere with AS at slower shutter speeds.
Geir Ove wrote:
Hello,
share my insights:
party flashes?
Geir Ove
Thanks Per. I thought it would be interesting to shed some more lights on this subject: Thanks for your insight.
Geir Ove
the sync speed.
Rgds PerOP
Geir Ove wrote:
Hello,
share my insights:
party flashes?
Geir Ove
This is not entirely correct. As I said in my original post, the shutter speed cannot be faster than the duration of the flash in situtations where you want to fully utlize the power of the flash.
Geir Ove
I gather you meant:
interfere with AS at FASTER shutter speeds.
Then I understand and agree
Geir Ove
Geir Ove wrote:
Hello,
share my insights:
party flashes?
Geir Ove
No...
No, I meant slower speeds. Slower ambient light speeds, no flash.
That's why the top speed is only 1/4000. The spring tension has been set lower.
Evidentally this is one of the technical hurdles KM had to overcome. If they put the kind of shutter that was in the film version, shutter vibraton at any speed could interfere with AS. Thus, a lower tension spring was used. A by-product or indirect result of this is the slower sync speed.
Geir Ove wrote:
I gather you meant:
Geir Ove
Geir Ove wrote:
Hello,
share my insights:
party flashes?
Geir Ove
Actually, the shutter speed cannot be faster than the speed at which the entire sensor is uncovered for a time. Any faster speeds would involve a moving slit across the image plane. Unless of course if you are using an FP flash mode.
That speed that I refer to above, is evidentally 1/160 of a second. For instance, my 20D gets sync at 1/250. I contend that the springs used in the D7 shutter are not strong enough to produce an uncovered sensor at speeds faster than 1/160. And I believe, from what I've read, is due to a decision on KM's part to not use a stronger shutter spring, because the result is shutter vibration that interferes with the AS.
Geir Ove
Although the largest duration of the flash (full power) can be very long (1/200s or so), with less power the duration falls drastically. But the idea is to make a flash where the duration of light is the smallest possible.
The need for high-speed syncs is mainly for fill in where the flash power is reduced most of the times.
Expensive shutters normally can sync faster - by the way the fastest focal plane shutter it's in Minolta SLRs (9xi and 9) with 1/300s.
Geir Ove
santoguapo Senior Member • Posts: 1,674
I highly doubt the main difference between the shutters on the D70 and the 7D is price. In fact, the shutter on the 7D could very well be more expensive than the one on the D70 because they had to basically start from scratch on it to figure out how to minimize the vibrations. This was most likely not a concern on the D70. In addition, the D70 could easily use the shutter from an earlier film body.
This being said, I salute both companies. 1/500 sec flash sync is quite impressive! Kudos to Nikon. Also, somehow making AS work at the expense of some sync speed must have been quite a feat. Kudos to KM as well!
1/300s.
Geir Ove
Cheerio...
Rich
Re: sync speed
Hi Patrick,
You may be right, but I don't bet on that since max sync is given manufacturer is the "safety guideline".
I've tried setting shutter speed beyond my film 7 max sync little (can't remember the exact speed anymore) with studio light. As expected, I got back only half the frame.
Cheers!
Patrick H Lockwood wrote:
Desmond Lim wrote:
Hi Geir,
Patrick
Des
nickclicks Regular Member • Posts: 119
D70 lowest iso 200
If you are comparing the D70 1/500 flash sync to the D7D you have to remember that the D70's lowest iso is 200 ISO this is one stop higher than the D7D which means in the same lighting situation if you were shooting with the D70 you might have 200 ISO F5.6 1/500 sec where as the D7D would be 100 ISO f6.1 1/160 sec this is only half a stop difference . I can live with that.
SQLGuy
SQLGuy Forum Pro • Posts: 12,664
Re: D70 lowest iso 200
I was thinking about this the other day, re: the faster synch of cameras like the Nikon D1 series, Nikon D70, and Canon EOS 1D.
This is something that Nikon and Canon did where there were able to implement an on-sensor electronic shutter that was faster than the mechanical shutter, so, in reality, they could actually do even faster than 1/500th synch. However, when they moved to 10MP CCDs, this wasn't possible anymore, and newer cameras lost this feature. Someone on the digital photography technology forum thought it was probably because the older CCDs stored data between rows in the sensor, trading off vertical resolution for on-sensor buffer.
The Nikon D70 had a 6MP Sony CCD. The KM 7D had a 6MP Sony CCD. The KM7D was released after the D70 (and well after the D1 and 1D). I wonder why KonicaMinolta didn't implement a similar electronic shutter to what was used in these other cameras.
A7R2 with SEL2470Z and a number of adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Canon PowerShot S100 (2000) Sony Mavica FD-91 Sony Cyber-shot DSC-S70 Sony Cyber-shot DSC-V3 +45 more
