Apple patent hints at super resolution camera mode
Optical image stabilization systems are great for counteracting shaky hands and keeping things smooth when shooting video. However, shifting sensors or lens elements can also be used to take two or more images at slightly offset angles and merge them to one exposure with a higher pixel-count. The idea is not entirely new, for example the Olympus OM-D E-M5 II mirrorless system camera uses a sensor-shift system to capture 40MP images with a 16MP sensor. The brand new Pentax K-3 II applies a similar concept to produce images with greater color resolution.
Apple has also patented a system that uses the actuators of an optical image stabilization system to move the optical path, as 9to5mac.com has found out. However, the basic concept is the same, as several exposures are merged into one to create a larger image. After HDR and night modes this is another interesting application of multi-frame modes that can help improve the image quality of smartphone cameras. The limitation in this case is that like most multi-frame modes, the Apple system would be mostly suited for static scenes as moving subjects could cause ghosting and other artifacts.
As usual there is no way of knowing if the system will ever make it into a production model but it's good to know smartphone manufacturers are looking at innovative ways of improving image quality that don't require the use of a larger sensor. Due to the laws of physics, a bigger sensor would almost certainly also result in increased device dimensions. Currently the iPhone 6 Plus is the only Apple smartphone with optical image stabilization. This patent could be an indication that we'll see more Apple devices featuring the technology in the future.
Source: USPTO | Via: 9to5 Mac
Apr 20, 2018
Apr 19, 2018
Apr 19, 2018
Apr 16, 2018
Sony has just released a trio of impressively small, light, ultrawide lenses for APS-C. These lenses are designed for vloggers, so Chris decided to film himself and find out how they perform.
Holy moly, this thing is tiny! We take the adorable Sigma 16-28mm F2.8 DG DN Contemporary around Calgary to see how it performs.
The Fujifilm X-H2S is the company's latest APS-C flagship, using a 26MP Stacked CMOS sensor to deliver the fastest shooting, best autofocus and most extensive video specs of any X-series camera yet. Here's what's new and what we think so far...
We've been able to spend some quality time with Fujifilm's APS-C flagship, and we have plenty of opinions!
How do you make weird lens even weirder? Put a periscope on it! We check out the new Laowa Periprobe 24mm F14 2X and explore some of the creative things you can do with such a bizarre lens.
What’s the best camera for around $2000? These capable cameras should be solid and well-built, have both speed and focus for capturing fast action and offer professional-level image quality. In this buying guide we’ve rounded up all the current interchangeable lens cameras costing around $2000 and recommended the best.
If you're looking for the perfect drone for yourself, or to gift someone special, we've gone through all of the options and selected our favorites.
Most modern cameras will shoot video to one degree or another, but these are the ones we’d look at if you plan to shoot some video alongside your photos. We’ve chosen cameras that can take great photos and make it easy to get great looking video, rather than being the ones you’d choose as a committed videographer.
Comments
