The Fujifilm X-T10 is one of the cameras to gain Raw support in this update.
Adobe has released the latest iterations of its Camera Raw plug-in and DNG converter software. In addition to adding support for more cameras and lenses, a number of useful new features have been added.
The first new feature is a 'dehaze' function that gives users a slider to remove - or add - the amount of haze or fog in an image. Next up are local adjustment sliders for whites and blacks, with gradiant filters, radiant filters, a an adjustment brush being the available tools for selecting the areas in the image that you wish to retouch.
Owners of X-Trans-based Fujifilm cameras will be happy to learn that Adobe has reduced 'color blur' artifacts that could appear in photos. Adobe says that the two companies are continuing to collaborate on improving image quality in other areas.
Finally, there's more support for a wide selection of cameras and lenses, as well as several bug fixes.
More details below:
Press release:
Camera Raw 9.1 is now available
Camera Raw 9.1 is now available through the update mechanism in Photoshop CS6 and Photoshop CC.
As mentioned here, updates to Camera Raw for Photoshop CS6 only include new camera support, lens profile support, and bug fixes. The new features listed in the release notes are only available in Photoshop CC.
New Features
Dehaze
  • Many outdoor scenes have some amount of haze due to atmospheric conditions. Dehaze is a new feature for removing/adding haze and fog from pictures.
  • The user can control how much haze to remove by adjusting a new slider in the Effects panel in the Dehaze section. This feature can also be used in the other direction to increase the amount of haze.
  • Recommended Workflow – Adjust the white balance of the image before applying the Dehaze control.
Local White and Black Adjustment Sliders
  • Available with all 3 local adjustment tools: Gradient Filter, Radial Filter and Local adjustment brush
  • Useful for fine-tuning tonality near the brightest and darkest parts of the picture. For instance, they can be used to increase the contrast of highlights.
  • Recommended Workflow – Make your global adjustments first and then use the local adjustments to fine tune. Use the clip warning indicator to help avoid clipping highlights and shadows.
New Camera Support in Camera Raw 9.1
  • Fujifilm X-T10
  • Nikon 1 J5
  • Nikon D810A
  • Panasonic DMC-G7
  • Pentax K-S2
  • Pentax K3 II (*)
    *Preliminary support. The multi-shot Pixel Shift Resolution and HDR features are still under investigation.
New Lens Profiles in Camera Raw 9.1
Mount Name
Mount Name
Canon Canon EF 50mm f/1.8 STM
Canon Canon EF 400mm f/4 DO IS II USM
Canon Tokina AT-X 11-20mm f/2.8 PRO DX
DJI PHANTOM 3 FC300S (RAW + JPEG)
DJI PHANTOM 3 FC300X (RAW + JPEG)
Leica Voigtlander VM 15mm f4.5 Super Wide Heliar III Aspherical
Nikon Nikon 1 NIKKOR VR 10-100mm f/4-5.6
Nikon Nikon 1 NIKKOR VR PD-Zoom 10-100mm f/4.5-5.6
Nikon Nikon AF NIKKOR 85mm f/1.4D IF
Nikon Tokina AT-X 11-20mm f/2.8 PRO DX
Pentax HD PENTAX-DA 18-50mm f/4-5.6 DC WR RE
Pentax HD PENTAX-DA L 18-50mm f/4-5.6 DC WR RE
Pentax HD PENTAX-D FA 150-450mm f/4.5-5.6ED DC AW
Sony Alpha Sony 16-35mm f/2.8 ZA SSM II
Sony Alpha Sony 24-70mm f/2.8 ZA SSM II
Sony Alpha Sony 70-300mm f/4.5-5.6 G SSM II
Fixed Bugs:
  • Reduced “color blur” artifacts when processing Fujifilm X-Trans raw images. In collaboration with Fujifilm, we are still investigating methods to improve fine detail rendering and overall edge definition.
  • The “Remove Chromatic Aberration” checkbox is now enabled by default for all Fujifilm cameras.
  • Fixed crash when reading some JPEG images.
  • Fixed bug where Camera Raw Filter would incorrectly show a soft-proofed image.
  • Improved quality of display color management on some wide-gamut displays when GPU acceleration is enabled.
  • HDR and Pano Merge: Cleared in-camera crop before merging rather than destructively applying it prior to merging.
  • Pano Merge: Fixed a Pano blending issue specific to Leica M9.
  • Fixed a bug with Panasonic LX100 – extended ISO 100 was too bright and Magenta Highlights have been fixed.
  • Fixed a bug with Nikon Coolpix P7800 NRW raw files that showed only Matrix as camera profile.
Download Links
Camera Raw 9 – Please use the update mechanism in Photoshop CS6 and Creative Cloud app.
DNG Converter 9.1: Mac | PC
Please note – If you have trouble updating to the latest ACR update via the Creative Cloud application, please refer to the following plugin installation:
http://helpx.adobe.com/x-productkb/multi/camera-raw-plug-in-installer.html
