Rokinon has introduced 21mm F1.4 and 50mm F1.2 fast prime lenses, both of which are up for pre-order now. These new lenses flesh out the maker’s existing offerings for mirrorless cameras.
The 50mm F1.2 lens features an atypically long focal length equivalent of 75mm to 100mm (depending on mount) alongside a 9-blade diaphragm and a 62mm filter ring. The 21mm F1.4 lens, meanwhile, has an equivalent focal length of 31.5 to 42mm (depending on mount), 58mm front filter mount, and a trio of aspherical elements and a single extra-low dispersion element for clarity and sharpness. All of the lens’ elements feature the maker's Ultra Multi-Coating.
Both of the new lenses are available with Sony E, MFT, Canon EF-M, and Fujifilm X mount. Excepting the EF-M mount, both lenses are also available in silver or black colors. The 21mm F1.4 lens is priced at $499 USD/£329.00, and the 50mm F1.2 at $549 USD/£329.00. The lenses are listed with an expected availability date of October 7.
The same lenses will be offered with Samyang's own branding, with the 21mm F1.4 priced at £279.99/€349 and the 50mm for £309.99/€399. Versions with clickless aperture rings for videographers will be sold at £309.99/€399 for the 21mm T1.5 and £339.99/€449 for the 50mm T1.3.
