Olympus expands its digital OM lineup today with the Olympus OM-D E-M10 II. Updates include a 5-axis image stabilization system (though not the same as the E-M5 II or E-M1's), a new 2.36 million dot OLED EVF and a 4K time lapse mode.
While retro OM styling is still alive and well in this iteration, the E-M10's body has seen a slight redesign over its EM-10 predecessor's and some controls have been re-arranged. The 16.1MP Live Mos sensor and TruePic VII of the OM-D E-M10 have been carried through to this model, as has a 3" 1.04M-dot tilting LCD. Recording at 1080/60p is offered, and the E-M10 II provides an 8.5 fps maximum burst rate as a slight upgrade over the E-M10's 8fps.
An external ECG-3 grip can be purchased separately, boasting a one-touch release lever for quick access to the battery and memory card. The Olympus OM-D E-M10 II will be available in early September for $649.99 body only or $799.99 with M.ZUIKO DIGITAL ED 14-42mm F3.5-5.6 EZ kit lens. All-black or silver variations will be offered. The external grip, also available in September, will cost $59.99.
Press release:
OLYMPUS OM-D E-M10 MARK II®: THE ADVANCED CAPABILITIES OF OLYMPUS-PIONEERED 5-AXIS IMAGE STABILIZATION NOW AVAILABLE ACROSS THE OM-D LINEUP
Capture Blur-Free, High-Quality Images and Video with a User-Friendly, Elegantly Designed High-Performance Mirrorless Camera
CENTER VALLEY, Pa., August 25, 2015 — Olympus introduces the Olympus OM-D E-M10 Mark II, a small, stylish, entry-level camera body with powerful in-body 5-axis image stabilization. As the successor to the Olympus OM-D E-M10, the OM-D E-M10 Mark II combines the award-winning power of the OM-D family, first-class quality of 5-axis image stabilization and an all-new design with improved ergonomics. The Olympus OM-D series brings flawless, professional-quality images and video to photographers of all levels.
Shoot High-Quality Images All the Time
Hailing from the cutting edge technology found in the award-winning Olympus OM-D E-M1 and OM-D E-M5 Mark II, the OM-D E-M10 Mark II’s 5-Axis Voice Coil Motor (VCM) Image Stabilization offers a hassle-free solution to image blur caused by camera shake. With up to four shutter speed steps, it allows for longer exposures and lower ISOs for crisp and clear handheld shots. The traditional 2-axis image stabilization in many DSLRs only compensates for angular shake, while the 5-axis image stabilization in the Olympus OM-D E-M10 Mark II also corrects for rolling blur that affects both low-light shooting and the horizontal and vertical shift blur that can mar macro shots. The combination of the OM-D E-M5 Mark II’s 16-Megapixel Live MOS sensor and TruePic VII image processor maximize the power of 5-axis Image Stabilization to capture sharp images and video without the need for a tripod.
User-Friendly, Elegant Design
The ultra-slim, compact size of the Olympus OM-D E-M10 Mark II adds to the camera’s user-friendly design. Not only does the body configuration incorporate the classic style found in Olympus OM-D cameras, but the elegantly machined metal dials, along with the leather textures of the grip, produce a highly sophisticated feel. The prominent thumb grip supports a stable, one-handed hold and reliable, one-handed shooting. Both the dial and button shape and layout have been adjusted for users to easily operate the camera while looking at their subject through the viewfinder.
High-Speed Performance
The Olympus OM-D E-M10 Mark II delivers an amazingly fast, class-leading shooting time courtesy of its Touch Autofocus1. With a sequential shooting speed of 8.5 fps — more than twice as fast as comparable DSLRs — short shooting lag time, fast responsiveness and a quick start-up time, users can easily capture split-second movements.
Easy-to-See Electronic Viewfinder
Armed with a built-in electronic viewfinder (EVF), the Olympus OM-D E-M10 Mark II makes it easier than ever to shoot in direct sunlight and other situations where it might be difficult to view the monitor. Thanks to 100 percent field of view, users are able to see more of the scene for precise composition. The EVF also boasts a viewfinder magnification rate of 1.23x (35mm equivalent: 0.62x) and uses a high-definition 2.36-million-dot OLED monitor for sharp, clear details. For further shooting accuracy, the new AF Targeting Pad allows the user to keep an eye on the viewfinder while tracing a thumb on the camera’s rear touchscreen to adjust focus point. The E-M10 Mark II also offers a solution for shooters who are more accustomed to optical viewfinders; the Simulated Optical Viewfinder (S-OVF) offers higher dynamic range, more in line with that visible to the naked eye.
Intuitive Video Creation
The OM-D E-M10 Mark II allows users to take advantage of 1080p Full HD Video, intuitive touch interface, variable frame rate and a new CLIPS feature which records short one-, two-, four- or eight-second clips. These clips can then be merged into a final video product in-camera, and then uploaded directly to your favorite social platform using the Olympus OI.Share app.
Creative Shooting
The Olympus OM-D E-M10 Mark II comes packed with additional shooting modes, unleashing unlimited creativity.
- Art Filters: Select one of 14 available Art Filters that match your creative vision. Art Filters can be combined with Art Effects to produce truly inspiring images and video.
- Photo Story: With five available patterns, Photo Story combines multiple photos into a single image to express the user’s story about a moment in time.
- Live Composite: Select Live Composite mode to extract and composite the brightest areas from multiple, sequentially shot images to capture thrilling light displays. With the newest version of the OI.Share app for Android and Apple®, you can make adjustments to your settings and monitor the progress of the image as it develops right on your smartphone or tablet.
- Live Bulb and Live Time: Easily capture moving trails of light with the Live Bulb and Live Time modes for stunning light painting images.
- 4K Time-Lapse: Capture up to 999 images automatically at an interval of one image every five seconds. The camera will then combine the images into a stunning, high-resolution, 4K file, all in-camera, without the need for additional software.
- Focus Bracketing: With a touch of the shutter button, multiple shots are taken with slightly different focus depths. Useful for those who shoot macro photography, users can select the image with the focus where they prefer. By using image-editing software that offers an image stacking function, users can produce images with large depth of field even while using wider apertures.
- Keystone Compensation: Perspective distortion can be corrected in-camera, live, while shooting, with the ability to see your corrected adjustments as you shoot.
Accessories
- External Grip, ECG-3: A removable grip exclusively for use with the OM-D E-M10 Mark II that enhances the hold and premium feel of the camera. With a one-touch release lever on the bottom of the grip, users can smoothly exchange the battery and memory card without missing a beat.
- Genuine Leather Strap, CSS-S119L: For added luxury and protection, the genuine leather strap has been treated with water repellent to protect against water damage.
1 According to Olympus research, August 2015.
U.S. Pricing and Availability
The Olympus OM-D E-M10 Mark II will be available beginning in early September 2015 in the following configurations:
Estimated Street Price:
Body only, available in Black and Silver
$649.99 (U.S.)
$749.99 (Canada)
Body in Black or Silver with M.ZUIKO DIGITAL ED 14-42 f3.5-5.6 EZ
$799.99 (U.S.)
$899.99 (Canada)
The External Grip, ECG-3 and Genuine Leather Strap, CSS-S119L, will be available in early September.
External Grip, ECG-3: $59.99 (U.S. and Canada)
Genuine Leather Strap, CSS-S119L: $79.99® (U.S. and Canada)
Olympus OM-D E-M10 II Specifications
Price | |
MSRP | $799 |
Body type | |
Body type | SLR-style mirrorless |
Sensor | |
Max resolution | 4608 x 3456 |
Image ratio w:h | 1:1, 4:3, 3:2, 16:9 |
Effective pixels | 16 megapixels |
Sensor photo detectors | 17 megapixels |
Sensor size | Four Thirds (17.3 x 13 mm) |
Sensor type | CMOS |
Processor | TruePic VII |
Color space | sRGB, AdobeRGB |
Color filter array | Primary color filter |
Image | |
ISO | Auto, 200 - 25600, expands to 100-25600 |
Boosted ISO (minimum) | 100 |
White balance presets | 7 |
Custom white balance | Yes (4 slots) |
Image stabilization | Sensor-shift |
Image stabilization notes | 5-axis image stabilization (yaw/pitch/roll/vertical/horizontal) |
Uncompressed format | RAW |
JPEG quality levels | Super fine, fine, normal, basic |
File format |
Optics & Focus | |
Autofocus |
Autofocus assist lamp | Yes |
Manual focus | Yes |
Number of focus points | 81 |
Lens mount | Micro Four Thirds |
Focal length multiplier | 2× |
Screen / viewfinder | |
Articulated LCD | Tilting |
Screen size | 3″ |
Screen dots | 1,040,000 |
Touch screen | Yes (Focus, shutter release, AF point selection, menus, image playback) |
Screen type | TFT LCD |
Live view | Yes |
Viewfinder type | Electronic |
Viewfinder coverage | 100% |
Viewfinder magnification | 1.23× (0.62× 35mm equiv.) |
Viewfinder resolution | 2,360,000 |
Photography features | |
Minimum shutter speed | 60 sec |
Maximum shutter speed | 1/4000 sec |
Maximum shutter speed (electronic) | 1/16000 sec |
Exposure modes |
Scene modes |
Built-in flash | Yes (Olympus Wireless RC Flash system compatible) |
Flash range | 5.80 m (ISO 100) |
External flash | Yes (via hot shoe or wirelessly) |
Flash modes | Auto, redeye reduction, fill flash, flash off, 1st-curtain slow sync w/redeye, 1st-curtain slow sync, 2nd-curtain slow sync, manual |
Flash X sync speed | 1/250 sec |
Continuous drive | 8.0 fps |
Self-timer | Yes (12 sec., 2 sec, custom) |
Metering modes |
Exposure compensation | ±5 (at 1/3 EV, 1/2 EV, 1 EV steps) |
AE Bracketing | ±5 (2, 3, 5, 7 frames at 1/3 EV, 2/3 EV, 1 EV steps) |
WB Bracketing | Yes |
Videography features | |
Resolutions | 1920 x 1080 (60p/30p/24p), 1280 x 720 (60p/30p/24p), 640 x 480 (30 fps) |
Format | H.264, Motion JPEG |
Microphone | Stereo |
Speaker | Mono |
Storage | |
Storage types | SD/SDHC/SDXC |
Connectivity | |
USB | USB 2.0 (480 Mbit/sec) |
HDMI | Yes (micro-HDMI) |
Microphone port | No |
Headphone port | No |
Wireless | Built-In |
Wireless notes | 802.11b/g/n with smartphone app |
Remote control | Yes (Optional Remote cable RM-UC1) |
Physical | |
Environmentally sealed | No |
Battery | Battery Pack |
Battery description | BLS-50 lithium-ion battery & charger |
Battery Life (CIPA) | 320 |
Weight (inc. batteries) | 390 g (0.86 lb / 13.76 oz) |
Dimensions | 120 x 83 x 47 mm (4.72 x 3.27 x 1.85″) |
Other features | |
Orientation sensor | Yes |
Timelapse recording | Yes (Up to 999 shots. Can create 4K / 5 fps video) |
GPS | None |
GPS notes | via smartphone |
Comments
