Total light, smaller sensors and crops
The total amount of light that goes to make up your image is the most important factor in determining image quality.
As I tried to explain (and demonstrate) in my article on equivalence, f-numbers dictate the light intensity of an exposure (light per unit area). However, this ignores the sensor size. To understand how much total light is available to make up your image, you need to multiply this light per unit area by the area of your sensor.
Do this and you'll discover that sensor size is much more important than pixel size.
Why do you say a smaller sensor sees less light?
Because, with the same f-number, it does.
This diagram represents the light being projected by a full frame lens onto a full frame sensor. The second image shows what happens when you mount that same lens (and hence the same f-number) on an APS-C sensor: the smaller sensor can only see the inner, bronze-colored cone of light, the rest of the original yellow cone of light is no longer available for capture.
It's not condensed down onto the smaller sensor (if it were, then you'd still get the same field-of-view), it's just lost.
1) Full Frame lens on Full Frame Sensor
2) That same Full Frame lens on APS-C sensor
3) APS-C-specific lens of the same focal length on APS-C sensor
4) Full frame lens giving the same field-of-view as the APS-C sensor sees (The 'equivalent' FL lens)
What about APS-C-specific lenses? Well those simply never project the extra, outer cone of light. This means they can be smaller, but they still don't get access to that extra light.
Prove it!
The assertion that a smaller sensor sees less total light and is, therefore, noisier (since it receives less light, and hence has a worse signal-to-noise ratio because of shot noise), is contentious. This is understandable, as it means thinking in terms of the whole image, not the individual pixels or the light intensity per unit area that underpins the f-number/ISO system of exposure (that is specifically designed to work independently of sensor size).
However, while it may seem heretical to anyone strongly attached to the conventional exposure model, it is, nonetheless, demonstrably true.*
Same sized pixels
A question we've regularly seen is: What about taking an APS-C crop image on a full frame camera? Surely that'll have the same noise as an APS-C camera would, so how can you say the full frame image has less noise?
Let's see, shall we?
Below are our standard studio test shots from the Nikon D810 and the Nikon D7000, shot from around the same distance, framed in the same way and using the same shutter speed and f-number for each ISO setting.
These two cameras were chosen because they have different sensor sizes but very, very similar pixel sizes**. Then, in addition to this, we've shot the D810 in crop mode using the same lens as was used on the D7000.
When compared at 1:1 level, these crops from the images show exactly the result you might expect:
ISO 200
D810 whole frame [Raw File] D810 APS-C crop [Raw File] D7000 [Raw File]
ISO 400
ISO 800
ISO 1600
ISO 3200
ISO 6400
ISO 12800
All these shots were taken with the at the same f-number and shutter speed for each ISO, so experienced the same intensity of light. And, since their pixels are very similar in size and they feature similar technology, the pixel-level performance is essentially identical across all three cameras.
However, if you make the (I believe) reasonable assumption that most people won't insist on viewing or printing their images in proportion to the sensor size they were shot with, then it becomes relevant to consider the whole image and try viewing the images at a common output size (16MP).
ISO 200
D810 (resized: 16MP) [Raw File] D810 APS-C crop [Raw File] D7000 [Raw File]
ISO 400
ISO 800
ISO 1600
ISO 3200
ISO 6400
ISO 12800
Now we see the effect of all the extra light captured: the outer cone in the diagram at the top of the page. The APS-C camera and APS-C crop still look the same but the extra sensor area (all exposed to the same light intensity) allows the full frame image look better overall.
Note that the full frame sensor performs better than the APS-C sensor, even though its pixels are not bigger. If you were to take full frame camera with the same pixel count as the APS-C one (and so have bigger pixels), the result would still be very similar indeed.
In the next page, we'll look at two cameras with the same sensor size but different pixel counts (and, therefore, different pixel sizes). There are differences, but they're mainly in the shadows and at high ISOs.
The effect of pixel size on noise >
*To be clear, I'm not advocating abandoning the current ISO-based exposure model (though there are strong arguments for why that would make sense). Instead, I'm suggesting putting it to one side for a moment to consider the factors that it ends up masking. Looking at exposure in terms of 'total light' gives a clearer picture of why large sensors perform better (and its not larger pixels). [Jump back to text]
**The Sony IMX071 used in the D7000 has 4.8µm pixels, while the IMX094 that is very likely to feature in the D810 has 4.88µm pixels (less than a 2% difference). [Jump back to text]
