Joby's MPod Mini is a tiny version of its GorillaPod tripod with a new phone cradle attached. The Grip Tight phone mount hold most smartphones with or without a case.
Accessory maker Joby is arguably best known for its range of GorillaPod tripods. With their flexible legs that bend and rotate Gorillapods can not only adjust to uneven terrain but can also be attached to lamp posts hand rails and similar objects. If you prefer an even more portable solution the company also makes the Micro Stand, which can be attached to your key ring.
Recent Videos
Combined with one of Joby's Grip Tight smartphone mounts, both GorillaPods and Micro Stand are also very useful accessories for smartphone photographers. The Grip Tight holds most current smartphones with or without case and there's and XL version for if you are shooting with a larger phablet device. Also on show is the new MPod Mini Stand which is basically a mini GorillaPod with a new phone cradle that uses elastic bands to keep your device in place. It should fit into most pockets and only weights 30 grams.
GorillaPods come in diferent sizes.
The Grip Tight XL on a Micro Stand
