Fujifilm has rolled out firmware updates aimed at fixing quirks in the X100T and X-T1, improving image quality in the FinePix S1 superzoom, and improving OIS functionality in several X-mount zoom lenses.
Updates for the X-T1 and X100T are fairly minor, but concentrate mainly on fixing bugs in both cameras (see the press release below for specifics). Firmware version 3.10 is the latest for the X-T1 and 1.10 is the latest for the X100T. Fujifilm has also updated the S1 superzoom to firmware version 1.02; this new firmware aims to improve the sharpness of images when shooting in continuous mode.
Updates for X-mount zoom lenses are aimed at improving OIS functionality and affect the following pieces of glass: XF 18-55mm f/2.8-4 R LM OIS (version 3.12), XF 55-200mm f/3.5-4.8 R LM OIS (version 1.12), XF 18-135mm f/3.5-5.6 R LM OIS WR (version 1.01) and XF 10-24mm f/4 R OIS (version 1.01).
One important note, the Fujifilm website says to turn off your camera during the update process. Apparently that is a typo and to correctly update your firmware you MUST keep your camera on during the process.
Download firmware updates for all of the above products
Press release:
FUJIFILM RELEASES NEW FIRMWARE FOR X100T, X-T1, S1 AND FOUR X-MOUNT LENSES
March 31st, 2015 – Fujjifilm Corporation has released firmware updates for the following products to enhance operability and functions:
[Firmware version]
(1) X-T1 and X-T1GS: 3.10 (current 3.00)
(2) X100T: 1.10 (current 1.00)
(3) S1: 1.02 (current 1.01)
(4) XF18-55mm: 3.12 (current 3.11)
(5) XF55-200mm: 1.12 (current 1.11)
(6) XF18-135mm: 1.01 (current 1.00)
(7) XF10-24mm: 1.01 (current 1.00)
X-T1 FIRMWARE UPDATES
Improved flash functionality
When using an external non-TTL flash, it will now fire when the “MECHANICAL+ELECTRONIC” is selected in the “SHUTTER TYPE” option of the SHOOTING MENU.
If “S (Shutter-Priority)” or “M (Manual Exposure)” mode is selected, set the shutter speed to 1/180 sec. or slower.
Improved WIFI
Improved Wi-Fi communication when “FUJIFILM PC AutoSave” is used. The phenomenon is fixed that Wi-Fi communication with “FUJIFILM PC AutoSave” stops at the moment the LCD turns off.
Improved “USB MODE” functionality
(i)When “PC SHOOT FIXED” is selected, the warning of “IMAGES ARE NOT SAVED IN THE CARD” appears.
(ii)If “PC SHOOT FIXED” is selected in the “USB MODE” and the camera is not connected to a PC via a USB cable, you cannot turn off the camera when you turn the ON/OFF switch to the OFF position or remove the lens from the camera because the camera stays in the waiting mode for image transfer.
With this upgrade, the message below will appear to confirm whether you stop the image transfer to the PC or not in such operations. If you press “OK” button, the camera will turn off without recording images.
Note: “PCSHOOT AUTO” and “PS SHOOT FIXED” in the “USB MODE” are the modes to use PC shooting software like the optional accessory HS-V5. If you don’t use such a software, select “MTP(PTP)” in the “USB MODE”.
X100T FIRMWARE UPDATES
“CONVERSION LENS” setting updated
When an Fn button with “CONVERSION LENS” setting is pressed, one of the messages below appears in a cyclic manner in addition to the icons.
Updated viewfinder display
When the dual optical viewfinder/electronic range finder (ERF) display is used with the Digital Split Image, the white Focus frame appears in the centre of the viewfinder.
Improvement of Focus Peaking display
Focus peaking improved in the electronic viewfinder for darker environments to help with focusing.
FINEPIX S1 FIRMWARE UPDATES
Improved image quality
Image quality improved (sharpness) when using continuous shooting mode.
LENS FIRMWARE UPDATES
Stability improvement for the OIS Function with the following lenses:
XF18-55mm
XF55-200mm
XF18-135mm
XF10-24mm
For more info head to Fujifilm.com
Comments
