easy ccd cleaning
Started May 2, 2004 | Discussions
alex from holland Senior Member • Posts: 2,341
easy ccd cleaning
First i must start to say that it was not my idea.
It was a tip somebody gave to me.
Today i did it (was nervous for sure)
Be aware !!! Don't take the risk with cr123. Just buy yourself a ac power supply for only aprox $35,==.
This picture shows how dirty the ccd was.
This picture shows the clean ccd after the second attempt.
"open" s2
Bring in the tape. You will need some pratice for this because it's very small
in the camera.
Gently puch the tape on the ccd. I used a small piece of a creditcard
( the goldcard of my wife LOL)
After this gently remove the tape from the ccd.
Move from one way to the other.
Don't stop, but remove it in one movement.
Good luck
Happy Shooting
alex from holland
http://www.pbase.com/alex28
'You don't take a picture, it's given to you'
OP alex from holland Senior Member • Posts: 2,341
it was the scotch green magic tape (forgot ot say)
alex from holland wrote:
Happy Shooting
alex from holland
Jusko Contributing Member • Posts: 729
Re: it was the scotch green magic tape (forgot ot say)
Could you post a shot showing how the original tape look like ?
And please give more detail on how to prepare the tape ?
Regards
Jusko
 Jusko's gear list:Jusko's gear list
Canon EOS 5D
Tariq Senior Member • Posts: 1,529
What? tape on ccd
You actually applied Tape to the Sensor? That sounds very dangerous.
Tariq
Tariq.com
 Tariq's gear list:Tariq's gear list
Sony a7R Sigma sd Quattro H +1 more
2 Pistol Corky Regular Member • Posts: 123
LOL
Title should read How Not To Clean Your CCD!!!
Tariq
Tariq.com
picture of the tape
Jusko,
here's a picture of the tape.
I do nothing to prepare the tape. Just take a piece of the tape and bring it in the camera. you need some pratice for this because it's very narrow. But the size of the tape is ecactly the size of the ccd
Be aware that you only use this tape. teh scotch tape can easily be removed from a surface.
If you don't believe it, just give it a try on a lens surface or just a mirror with some dust.
Happy Shooting
alex from holland
Re: LOL
if you don'believe it, it's up to you. I did it this morning and it worked just great.
Happy Shooting
alex from holland
Re: What? tape on ccd
Tariq,
That's why i took the pictures. Otherwise nobody would believe me.
THIS IS NO JOKE.
It work perfectly, BUT be AWARE that you only use the scotch tape !!
It can be removed very easily. Just give it a try on a mirror or something like that.
Happy Shooting
alex from holland
Scotch magic tape is suppose to leave no residue behind but I wouldn't want to take that chance.
Tariq,
THIS IS NO JOKE.
RogM Senior Member • Posts: 2,289
Other ideas...
Jusko,
I'd be a little concerned about using a tape with such an aggressive adhesive--at least the green-boxed tape they sell here in the U.S. is quite sticky, and perhaps doesn't need to be for this application. How about using the far less aggressive temporary Scotch tape that comes in a blue box, it's called Scotch #281 Removeable Transparent Tape and comes in all widths. It has an adhesive that is like Post-It notes have. Or how about the Post-It translucent index markers? They appear to be of a ready-to-use size and even have a convenient handle!
There's also a gadget called the "Pick-Stick" that sells for about $10 that is supposed to do the same thing, but I've seen some negative comments that were not very specific.
Rob de Knegt New Member • Posts: 17
I've done the same trick a year ago, and my camera is still working ;-).
However, now I am using the swaps plus cleaning fluid, its a little more expensive than the 99 eurocents of the tape (Eur 85.00 a set) but my CCd is shing like new.
I did have the idea after applying the tape, there was still some residue on my CCD, however could not prove it.
rob
Tariq,
THIS IS NO JOKE.
Gabriele Sartori Veteran Member • Posts: 4,428
I think Alex is right
If there is any tape glue left, it can always be cleaned with eclypse and pads as usual.
Regards
Gabriele Sartori
Bay Area, CA
Equipment list in profile
 Gabriele Sartori's gear list:Gabriele Sartori's gear list
Leica D-Lux (Typ 109) Nikon D800E Leica M Typ 240 Panasonic Lumix DMC-GH3 Nikon 1 J1 +3 more
Re: I think Alex is right
If the tape did indeed leave a residue which one then had to clean as well by safe and traditional means, then what would be the point of risking the use of tape in the first place?
Tariq
Anthony Veteran Member • Posts: 8,933
Ummm
You might not be so happy if the cover over the CCD got pulled out with the tape. I don't know how it's attached, but pulling on the tape and thus the CCD cover itself can't be a good idea.
Anthony
as far as i can see there is no residue.
You put it on and after 10 sec you remove it.
The pictures show a 99,9% clean ccd.
I have made pictures later and they look just great.
Happy Shooting
alex from holland
Re: Ummm
Just give it a try on a mirror. Put a fingerprint on it and than use the tape.
It will take off the fingerprint complete.
The can be removed very easy, you don't need any force.--
Happy Shooting
alex from holland
dustin Contributing Member • Posts: 609
Re: Ummm
Scotch tape totally leaves a residue. I recommend duct-tape for getting all of the residue off.
Re: Ummm
No it doesn't !!
Just give it a try on a mirror, Than you will see it won't leave any residue.
And if you don't believe it, just leave it
Happy Shooting
alex from holland
Thanks santori.
the tape will not leave a residue.
Just give it a try with a mirro.
put a fingerprint on it and remove it with the tape.
there will be nothing left
Happy Shooting
alex from holland
JoshuaMB Regular Member • Posts: 381
Another great tip:
Ive tried duct tape, scotch tape, and found that what really works best is some M3 Super 77 spray mount adhesive sprayed directly into the camera covering all parts including the dusty sensor, then taking cheese cloth and pressing firmly for about 30 minutes and pulled off in 5 jerky motions best ruins my camera and cleans the sensor about > 1% of the time. To prep the surface use some canned air with the can turned upside down and sprayed at an angle onto the sensor, if some freon comes out just use a fingernail to scrape if off the AA filter and go to work!
Happy Shooting!
