Exposure compensation in Photoshop?
Started Jul 13, 2003 | Discussion
Derekasaurus Rex
Senior MemberPosts: 2,914
Jul 13, 2003
The way I usually perform exposure adjustments in Photoshop is to duplicate the layer in "Screen" blend mode and set the opacity to 33% for +1/3 EV, 50% for +1/2, 66% for +2/3, etc. For negative adjustments I use "Multiply"mode.
I was wondering what techniques others had for adjusting exposure in Photoshop?
A problem with my method is that it won't work with 16-bit images because it requires layers, so I'm interested in methods that work with 16-bit images.
TonyK_in_Texas
Veteran MemberPosts: 3,668
Re: Exposure compensation in Photoshop?
In reply to Derekasaurus Rex, Jul 13, 2003
I do my EC in C1LE these days.
I like your method though and will have to keep it in mind.
Thanks,
in Photoshop?
with 16-bit images.
TonyK
Greg M
Veteran MemberPosts: 4,220
I'd sugest shooting in RAW and doing your exposure adjustment when you convert the image to a 16 bit tif file. It would be better and probably just as quick as what you are doing. Then you would have all of the advantages of shooting in RAW.
Greg M
http://www.mocanu.com/gallery/index.php
http://dslr.mocanu.com
Derekasaurus Rex
I already shoot RAW
In reply to Greg M, Jul 13, 2003
I shoot exclusively RAW and use BreeseBrowser to perform exposure compensation. However, BB uses a small and fuzzy preview to adjust WB and exposure, so I figured if there it a slick way to do it in PS it might be better. My way is easy (especially with PS actions), but it doesn't work for 16-bit images.
Greg M
Greg M
Re: I already shoot RAW
Give Yarc Plus a try. The preview can be set to high quality and it makes it easy to make your adjustments.
Greg M
Greg M
Derekasaurus Rex
Will do. Thanks. {nt}
Greg M
Greg M
Leo Reinhard
Senior MemberPosts: 1,234
Why not download the trial version of C1LE to see if it suits you. You can do a lot of adjustments in 16 bit and output it Tif or jpg. Croppiing is also available. I find their exposure adjustments ( EV + -), contrast, WB, curves, levels and color saturation to be so good that I rarely have to do anything in PS.
in Photoshop?
with 16-bit images.
Leo R
Derekasaurus Rex
In reply to Leo Reinhard, Jul 13, 2003
I already have the evaluation version of C1LE and it is very good. However, I find Photoshop's adjustment layers invaluable, which is why I prefer to work in PS. Over the past few months I have created all sorts of adjustment layer actions for changing tone, saturation, exposure compensation, etc. This way I can process my entire image without actually altering it and save the PSD. Later if I decide I shouldn't have applied that warming filter, I can just toggle the layer off and be done with it.
Nill Toulme
Veteran MemberPosts: 8,149
Is there a way to use this method...
... on a selection only?
Nill
http://www.toulme.net
in Photoshop?
with 16-bit images.
Derekasaurus Rex
Re: Is there a way to use this method...
In reply to Nill Toulme, Jul 14, 2003
You can create a layer mask (Layer-> Add Layer Mask-> Hide All) to the Screen layer. Then you can paint (or fill) the parts of the layer mask white where you want the image's exposure modified. The rest will be untouched.
Nill
in Photoshop?
with 16-bit images.
Nill Toulme
Thanks! (NT)²
In reply to Derekasaurus Rex, Jul 15, 2003
Nill
in Photoshop?
with 16-bit images.
Derekasaurus Rex
This method is the same as using Curves
After working through the math it's apparent that this "Screen blend mode" method is identical to applying a quadratic curve using the Curves tool. For example, a 66% opacity Screen layer (+2/3 EV) is basically the same as a Curve with a control point at (128,165). So good old Curves can be used to modify exposure for 16-bit files. Now I hope Adobe gives us 16-bit layers soon...
in Photoshop?
with 16-bit images.
David Martin
Forum ProPosts: 17,056
What are you saving PSD files on?
They are so massive I've given up using them, instead I do my adjustments and save as a TIFF.
Are you burning on to DVD or something?
DaveMart
Please see profile for equipment
Derekasaurus Rex
External hard drives and CD
In reply to David Martin, Jul 15, 2003
I have large external hard drives (USB2 and FireWire) and I archive to CD. Nothing special.
The files can double in size when I add the Screen layer, which is why I'm going to switching to Curves for exposure compensation (adjustment layers add almost nothing to PSD file size). This puts them just over 30mb a piece. For this reason I sometimes only archive the RAW original to CD and leave the PSD files on external drives. Multiple copies are pretty safe and I can always reproduce them if necessary.
Now that I've discovered the equivalence between my Screen method and applying a Curve, my files sizes should go down to the point where they are very comparable to uncompressed TIFFs.
David Martin
I wonder how 'Lightness' equates!
them if necessary.
If that is similar to curves?
DaveMart
Derekasaurus Rex
Re: I wonder how 'Lightness' equates!
David Martin wrote:
(snip)
What exactly do you mean by Lightness? I only know that term in the context of Photoshop with respect to Lab color mode.
Milind Rao
Regular MemberPosts: 164
After reading this excellent article,
http://www.gurusnetwork.com/tutorials/photoshop/curves1.html
I use curves for exposure compensation.
Regards
Milind
Derekasaurus Rex
Great tutorial! Thanks! {nt}
In reply to Milind Rao, Jul 15, 2003
Regards
Milind
hounwai
Junior MemberPosts: 32
Re: Thanks for sharing! (nt)
Regards
Milind
Greg M
I'll second that (nt)
In reply to hounwai, Jul 15, 2003
Regards
Milind
Greg M
