New Sony A6100 and A7000 cameras plus firmware update for A5100 and A6000
Started Nov 6, 2015 | Discussions
Anthony David Forum Member • Posts: 51
A6100 and A7000:
28 MP BSI 23.5x15.6mm
399 PDAF
Updated CDAF routines
Low-light focusing and metering -3 EV
EVF
Touchscreen LCD, 3.15", 1.2M screen dots
ISO 64-51200 (expansion L1: ISO 50, expansion H1: 102400, multi-frame NR: ISO 204800)
Silent electronic shutter up to 1/32000
Mic-in
Orientation sensor
X AVC
4K in-camera recording
1080p HFR (high frame rate)
Can record two JPEG sizes simultaneously (e.g. full-size and small-size) either in JPEG or RAW+JPEG mode
Can record still photos (in 16:9 aspect ratio) while recording video
WiFi NFC
USB 3.0
A6100 only:
The EVF is the same as A6000, EVF cannot be used while LCD is in selfie position
The LCD can facilitate selfie photographers: 180 degrees up, 70 degrees down
Mechanical shutter same as A6000, standard durability
Continuous mode: Same as A6000
No weather sealing
No headphone port
Has OLPF
Flash same as A6000
Standard set of buttons
Standard RAW/JPEG buffer
SDXC UHS-II, very fast write-out
Weight: 352g
Dimensions: 117x70x48mm
Battery life about 440 shots
Price about $900
A7000 only:
The EVF is 2.36M, 100%, 0.85%
The LCD can't do selfies: 90 degrees up, 82 degrees down
Mechanical shutter 1/8000, extra durability (rated at 200,000 shots)
Continuous mode: 14.5 fps
Has weather sealing (kit lens won't be weather-sealed but weather-sealed lenses will be announced later)
Has headphone port
Has a user-selectable OLPF which can be switched on or off
Flash range at ISO 100: 9m, can act as a wireless flash commander
Advanced set of buttons
Large RAW/JPEG buffer
Dual SDXC UHS-II, very fast write-out
Dual memory card write modes: 1) Raw in Card1, JPEG/movies in Card2; 2) RAW/JPEG in Card1, movies in Card2; 3) Everything in Card1, auto-backup in Card2
Special deletion modes provided: User can delete photo or movie from one card while retaining it in the other card (when a suitable write mode is selected), or can delete it from both cards
GPS/GLONASS/Beidou satellite receiver
Digital compass
Basic world map for satellite provided, advanced maps will be available as paid app update
Special mode: can be set to automatically take photo(s) or video when camera satellite receiver detects it has entered a user-specified geographical area or is within a user-specified distance from a user-specified geographical spot
Weight: 411g
Dimensions: 125x76x55mm
Battery life about 400 shots
Price about $1300
A new firmware version for A5100 and A6000 is also on the way. It adds uncompressed RAW capability.
Fujifilm FinePix A610 Panasonic Lumix DMC-L1 Sony a5100 Sony a6000 Sony Alpha DSLR-A700
jakegrahamphotography
jakegrahamphotography Regular Member • Posts: 184
Re: New Sony A6100 and A7000 cameras plus firmware update for A5100 and A6000
This is some astounding level of specs detail, you've got me convinced (and sold).
instagram.com/jakecdgraham
 jakegrahamphotography's gear list:jakegrahamphotography's gear list
Sony a7R IV Zeiss Batis 18mm F2.8 Sony FE 100-400mm F4.5-5.6 Tamron 28-75mm F2.8 III Sony FE 24mm F1.4 GM +2 more
OP Anthony David Forum Member • Posts: 51
I was lucky to be one of the beta-testers of these two marvelous little beasts. The announcement date is Nov16.
And which of the two did you prefer & why?
Potential downsides of each?
Silmarion Contributing Member • Posts: 605
Is high ISO improved a bit? Is new kit lens coming? Thank you.
I mean due to BSI sensor - is it at least +0.5 stop better now?
Is any new kit lens coming? Please share your thoughts? Much appreciated!
caravan Junior Member • Posts: 44
Touchscreen,4K Video,and Selfie Screen = Pass
 caravan's gear list:caravan's gear list
Sony RX1R II
I really liked A7000, lots of customization options and very good ergonomic design. A6100 is a good update for A6000 users who don't need extra features.
BrianYarvin
BrianYarvin Contributing Member • Posts: 558
For me, the uncompressed raw for the a6000 is incredible news enough. The rest is pretty exciting too. Let's hope it's for real.
Re: Is high ISO improved a bit? Is new kit lens coming? Thank you.
Yeap high ISO is quite improved, I'd say by 2/3 of a stop. There will be weather-sealed new lenses, including a new weather-sealed 16-50 kit lens, but not at launch. I had the opportunity to try the weather-sealed prototype of the 16-50 kit lens, it seems to have the same optical performance as the current 16-50 but it needs a filter for weather sealing to work.
The new firmware adds not only uncompressed RAW support, but also some new cool stuff, like full PDAF support for lenses like Sigma's.
Tonkotsu Ramen
Tonkotsu Ramen Senior Member • Posts: 2,380
Do you happen to know if that only applies to native E mount lenses, or also for a mint lenses via an adapter?
Also any chance of ibis?
Poxycon New Member • Posts: 9
If this is true then wow
Anything about auto iso minimum shutter speed?
 Poxycon's gear list:Poxycon's gear list
Sony a6000
No IBIS in A6100/A7000. I didn't have the opportunity to test lenses on adapters. But the full PDAF works really brilliantly with E-mount non-Sony lenses like Sigma 19/30/60.
(unknown member) Veteran Member • Posts: 4,469
10
So 10 hours ago you decided to join and post these specs that no one else has or no one else will talk about.
I am calling BS, I'll apologize on 11/16 if you're right.
A hobbyist sees a photo with his eyes and captures it. A photographer sees a photo with his mind and creates it.
Yeap the min shutter speed in auto ISO is fully configurable.
On 11/16 you'll apologize because you'll see I'm right!
justmeMN Veteran Member • Posts: 8,817
Mathieu18 wrote: I'll apologize on 11/16 if you're right.
I'm secretly being skeptical, to spare myself from any future public apology.
Anthony David wrote: I had the opportunity to try the weather-sealed prototype of the 16-50 kit lens, it seems to have the same optical performance as the current 16-50 but it needs a filter for weather sealing to work.
It's too bad that they didn't come out with a better kit lens. The quality of the current one is "controversial", to put it politely.
This is a fake.
This b/astard fooled some of us momentarily, but it's over now. I'm sure Sony has A6K successor and we might see it announced in November, but this specs are fake.
JohnNEX Senior Member • Posts: 1,991
Re: This is a fake.
I guess there are three options:
1. He is making this stuff up, but clearly knows enough to know what is broadly plausible and what is not, such that even if the final specs are different he is probably going to get enough correct to claim partial success.
2. He is who he claims and will get fired very soon for breaking his NDA. I can't imagine that it would be too difficult for Sony to identify him.
3. He is correct with the specs and is posting with permission from Sony who are effectively doing a bit of informal pre-announcement market research and/or get a bit more hype for the announcement. I don't know enough about marketing to know if it is more effective to have a genuine 'surprise' announcement or a 'surprise-but-not-really-a-surprise' announcement.
 JohnNEX's gear list:JohnNEX's gear list
Panasonic Lumix DMC-ZS20 Sony Alpha NEX-6 Sony a6500 Canon EF 70-300mm f/4-5.6 IS USM Sony E 50mm F1.8 OSS +9 more
