USB thumdrives vs Card Readers
Started Oct 20, 2014 | Discussions
wklee Veteran Member • Posts: 9,130
I have some 32 and 64GB SD and/or MicroSD cards. Would it be possible to use those as USB pendrives? How well would it work that way?
Never buy version 1.0 of anything.
hotdog321
hotdog321 Forum Pro • Posts: 20,725
Re: USB thumdrives vs Card Readers
Not sure what you are asking, but I've used my outdated CF and SD cards as storage devices and swapping data between computers for over a decade. Good use for outdated cards.
photojournalist
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
OP wklee Veteran Member • Posts: 9,130
I was thinking that while it is possible to create a bootable USB disk, it may not be possible to create a bootable SDHC disk when inserted into a card reader, for example.
dad_of_four Veteran Member • Posts: 8,491
Yes but... While most every computer running today has a USB interface, not all computers have a SD card interface.  You might find yourself needing to carry around a USB Card reader that reads the SD card
 dad_of_four's gear list:dad_of_four's gear list
Nikon D70 Nikon D2Xs Nikon D700 Nikon D5000 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +10 more
Phil_MI
Phil_MI Senior Member • Posts: 1,122
I've just recently installed a Linux O.S. Fedora 21 alpha w/Xfce desktop to a 4GB SD card that was inserted in a usb card reader. The usb card reader with the sd card and Fedora o.s. boots from a Acer Aspire One and runs the live operating system well and have also created a persistent overlay that saves any changes that are made while running and after rebooting.
You may find that some computers will not boot from a usb device or sd card though. The Acer netbook here will boot from usb card reader and from just the sd slot but an Emachines computer here will not boot from the usb card reader but will boot from its sd slot.
phil
 Phil_MI's gear list:Phil_MI's gear list
Canon PowerShot SX40 HS Canon EOS 20D Canon EOS 7D Mark II Canon EF 28-80mm f/3.5-5.6 V USM Canon EF 100-400mm f/4.5-5.6L IS USM +1 more
mauibreeze Regular Member • Posts: 318
If you are asking if you can store files on a SD car and use that to transfer around stuff instead of a USB thumb drive then yes, it's essentially the same thing just different format. You just need to have a reader to be able to load the SD card.
I was thinking of that and also if it can be made bootable. My Vaio laptop has a SD card reader with isn't recognised as a bootable device. The laptop recovery options specifically ask for USB drives or DVDs.
(unknown member) Veteran Member • Posts: 4,585
I've never attempted that sort of solution, but bear in mind the BIOS will be looking for either a hard drive, or USB thumb drive, NOT a card reader for boot options.
So, is it possible? I can't say cause I've never tried it, but in keeping things simple, I highly doubt it, mainly because I don't think the card reader will be recognized in the BIOS.
New to this forum, not to forums!
ktownbill Senior Member • Posts: 2,191
I believe some or all usb memory sticks can be configured so a PC recognizes them as a "non-removable" device?  Otherwise you can't boot from them?
Bill
rebel99 Veteran Member • Posts: 4,025
phil
the new pcs can do that if you enable the bios and select flash drives as bootable media.
cheerz.
phil
cheerz.
Yes, that's true... however, I'm not sure the BIOS views a "card reader" as a "flash drive".  That's the issue.  Anyway I'll pose this question over at the tenforums and post back here later.
Depends on what the BIOS thinks and sees
Hi guys,
Being curious I posted this question in the Windows ten forums here: Boot from SD card Reader?  and the prevailing thought is it depends on whether the BIOS sees the card reader or not, and whether it recognizes it as a bootable device. Most think it should work depending on MB BIOS.
One poster did however state his laptop has a built in SD card reader but the laptop doesn't recognize it as a boot device so...
Another showed his BIOS setting showing the card reader as a bootable device. Any way I've already linked to the thread for those interested.
Peace.
