d600 won't change focus point ! Ideas?
Started Aug 22, 2014 | Discussions
Charles9600
Junior MemberPosts: 41Gear list
Aug 22, 2014
So.... I read many posts on setting camera to allow focus points to change.
I cannot get the camera to change from the center focus point.  On auto, I do see various focus points illuminating so I guess they are "connected" but still, I cannot direct the camera to select.
Anyone have a fix idea?  I wonder if the wheel on back is somehow not connected, but I can navigate around pictures in review mode.  Hummmm.
Charles
 Charles9600's gear list:Charles9600's gear list
Fujifilm X100S
Nikon D600
pxlwz
Regular MemberPosts: 291Gear list
Re: d600 won't change focus point ! Ideas?
In reply to Charles9600, Aug 22, 2014
On the focus selection point wheel on the back, make sure, the white dot is not set to L (locked)
http://www.dpreview.com/reviews/nikon-d600/images/allroundview.jpg
 pxlwz's gear list:pxlwz's gear list
Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 300mm f/2.8G ED VR II +8 more
Steve9
Junior MemberPosts: 46Gear list
Charles
Use the 4-way controller just to the right of the LCD screen to control your AF points.  Pressing OK should return your focus to the center AF point.  The back wheel is normally set to change your shutter speed.
 Steve9's gear list:Steve9's gear list
Sony Cyber-shot DSC-RX100 IV Nikon D7100 Nikon D610 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +13 more
PK24X36NOW
Senior MemberPosts: 1,435
In reply to pxlwz, Aug 22, 2014
...and also make sure that when you're trying to change the focus point that the camera/meter is ON, since it will not change otherwise.
TheMeister
Regular MemberPosts: 247Gear list
This is probably the answer. common mistake.
 TheMeister's gear list:TheMeister's gear list
Canon PowerShot A410 Nikon D610 Nikon AF Nikkor 35mm f/2D Nikon AF Nikkor 70-300mm f/4-5.6G Samyang 14mm F2.8 IF ED MC Aspherical +10 more
Charles9600
In reply to TheMeister, Aug 23, 2014
I appreciate the replies, but my problem is beyond  "user error" I am afraid.
Thanks to all,
Charles
Fujifilm X100S
tomnorth
Contributing MemberPosts: 538Gear list
In reply to Charles9600, Aug 23, 2014
Just to be clear, what area focus mode are you in when you are trying to move the focus point?
 tomnorth's gear list:tomnorth's gear list
Nikon D800 Panasonic Lumix DMC-GH3 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 85mm f/1.8G +10 more
