Quick and Dirty - PL25mm vs Oly 14-42 EZ vs Pana 12-32 GM1 kit
Started Aug 21, 2014 | Discussions
Maklike Tier
Regular MemberPosts: 373Gear list
Aug 21, 2014
Okay so I fully admit up front that I did this quick comparison without the same camera settings (I just turned it on and shot the shots) THIS IS NOT SCIENCE. The sales guy was happy to do it in so much as he wasn't that happy to do it, so I had to do it quick so I let the camera do it's thing.
All three shots were done at 25mm. The close up images were about 3.5m (10ft) away. All files were ORF, imported into Lightroom CC as DNG, then exported as full size jpegs with no fiddling whatsoever. The close-up 1:1 shots are actually screengrabs of the DNGs.
Can you guess which is the Panasonic-Leica 25mm f1.4, which is the Panasonic GM1's 12-32 kit zoom, and which is the Olympus 14-42 EZ?
Lens #1
Lens #2
Lens #3
Lens #1
Lens #2
Lens #3
 Maklike Tier's gear list:Maklike Tier's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 25mm F1.8
Panasonic Lumix DMC-GM1
oneohone
Forum MemberPosts: 77Gear list
Re: Quick and Dirty - PL25mm vs Oly 14-42 EZ vs Pana 12-32 GM1 kit
In reply to Maklike Tier, Aug 21, 2014
1. EZ
2. 25mm 1.4
3. Pana 12-32
Would be my guesses
 oneohone's gear list:oneohone's gear list
Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ
emd5 001
Regular MemberPosts: 106Gear list
In reply to oneohone, Aug 21, 2014
oneohone wrote:
1. EZ
2. 25mm 1.4
3. Pana 12-32
Would be my guesses
+1
 emd5 001's gear list:emd5 001's gear list
Canon PowerShot S3 IS Olympus E-M1 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S +2 more
unknown member
(unknown member)
1. EZ
2. 12-32
3. 25
 sylon's gear list:sylon's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 17mm 1:1.8 Olympus M.Zuiko Digital 45mm F1.8 +2 more
fluberman
Regular MemberPosts: 115Gear list
oneohone wrote:
1. EZ
2. 25mm 1.4
3. Pana 12-32
Would be my guesses
+1
 fluberman's gear list:fluberman's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-GM1 Olympus OM-D E-M10 Olympus E-1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +12 more
broody
Contributing MemberPosts: 674Gear list
oneohone wrote:
1. EZ
2. 25mm 1.4
3. Pana 12-32
Would be my guesses
+1. That's in line with my impression of all three lenses. But I'm intrigued that we may get a startling revelation
 broody's gear list:broody's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Canon EOS 5D Mark II Olympus M.Zuiko Digital 45mm F1.8 Panasonic Leica Summilux DG 25mm F1.4 +5 more
eques
Senior MemberPosts: 2,025Gear list
Very Quick and Dirty
#1 shows severe shake or shutter shock, #3 the same but to a lesser extent. So I could just guess #2 was made with PL25 wide open or with one of the zooms with active OIS.
I hope you didn't make your decision on basis of these images.
Peter
 eques's gear list:eques's gear list
Ricoh GR Panasonic Lumix DMC-GX7 Samyang 7.5mm F3.5 UMC Fisheye MFT Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +3 more
Maklike Tier
Re: Very Quick and Dirty
In reply to eques, Aug 21, 2014
Peter
Shutter shock huh. Sure it's not.....decentered?
There's no shutter shock in any of these photos.
eques
Peter
Of course, sorry to name the things not to be named.
But seriously, I believe the bad IQ of ##1 and 3 are not the fault of the lenses.
Peter.
Maklike Tier
eques wrote:
Peter
Peter.
Well, I gave full warning that I just whipped the camera out, stuffed the lenses on and pressed the shutter button. This is not a 'critique my photo' post.
You may believe the IQ is not the fault of the lenses, but what if I told you the images that you think were 'not the fault of the lenses' were both kit zooms; and the one in the middle (#2) was the PL25?
Would that information - when combined with the knowledge of every test on the internet carried out with those three lenses - lead you to believe that kit lenses could resolve as much detail as the PL25; it's just me and my 'quick and dirty' contribution that has the issues?
eques
Maklike Tier wrote:
eques wrote:
Peter
Peter.
Well, that was my first guess, see above.
I am well aware, that the kit zooms are no excellent lenses - I myself avoid them, if possible. However they are not that bad - and look at the double contours of the images #1 and also #3.
Could you provide the exif data, now that you unveiled the secret? Knowing that #2 was made with the PL25, I suspect P-Mode or iA mode selected wide open aperture and the zoom lenses didn't have OIS activated, so that exposure time was about 5,5 times as long as with the PL25.
Peter.
Pikme
Senior MemberPosts: 1,819Gear list
a bit ridiculous
In reply to Maklike Tier, Aug 22, 2014
The difference you are seeing is not the difference in sharpness between the lenses and you certainly cannot say it is because any of the lenses are 'decentered'.
What you are seeing is good old fashioned camera shake in two of the images from using too slow shutter speed and/or sloppy handholding (easy to do when acting quickly in a store).
I generally enjoy 'real life' tests rather than brick wall shots, but c'mon - you can't make ANY conclusions from these photos!
Roberto M.
Len_Gee
Veteran MemberPosts: 8,329Gear list
In reply to broody, Aug 22, 2014
broody wrote:
oneohone wrote:
1. EZ
2. 25mm 1.4
3. Pana 12-32
Would be my guesses
+1
 Len_Gee's gear list:Len_Gee's gear list
Sony RX100 Fujifilm X100T Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 7-14mm F4 ASPH +7 more
Michael M Fliegel
Senior MemberPosts: 2,610Gear list
Re: a bit ridiculous
In reply to Pikme, Aug 22, 2014
Each lens has its uses.  The PL25 is sharp, but not as sharp as the 14-42EZ at 14mm, and certainly not as sharp as the 12-32 at 12mm.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus E-M1 Olympus PEN E-PL2 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 +11 more
fuesting
Regular MemberPosts: 191
In reply to Michael M Fliegel, Aug 22, 2014
The PL25 is completely unsharp at 12mm, I find the shots unusable too.
arbuz
Senior MemberPosts: 2,247Gear list
but at 25mm it's the sharpest
 arbuz's gear list:arbuz's gear list
Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Nikon D600 Samsung NX 45mm F1.8 2D/3D +14 more
Michael M Fliegel
In reply to arbuz, Aug 22, 2014
Great lens but not so sharp at 32mm.
Landscapephoto99
Senior MemberPosts: 2,731
Re: Let's try not quick and dirty, but useful
Certainly in good light, it will be hard to tell the difference between the lenses except blown up 200% for pixel peepers.  Maybe bokeh?  But in low light is where the PL 25mm shines.
Michael M Fliegel
In reply to Landscapephoto99, Aug 22, 2014
No disrespect meant for the PL25, which is a great lens!
Landscapephoto99
Yes, no problem.  I have the 12-50 and the PL25.  Each has its own uses.  There is just something about the look of photos taken with the PL25 that is hard to describe, like a 3D effect...but maybe it's the Leica name getting to me
