question about filters and IQ
Started Aug 5, 2014 | Discussions
ace106 Contributing Member • Posts: 626
This is just a straight forward question.
Can attaching a clear protective filter soften an image or degrade image quality at all?
A salesman told me that it would have no impact on the image quality.  I'm a bit skeptical since that came from a salesman who gets commission so I figured I would get other opinions on the matter.
 ace106's gear list:ace106's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-FZ1000
Ron Poelman
Ron Poelman Veteran Member • Posts: 5,071
Yes, but there begins the road.
Many threads here on the topic.
If you can look after your lens,don't.
If you can't, buy a half decent one.
Clarity isn't generally a problem,
but additional reflections/flare and vignetting are worth considering.
Ron.
Volunteer, what could possibly go wrong ?
 Ron Poelman's gear list:Ron Poelman's gear list
Sony Cyber-shot DSC-H2 Sony Cyber-shot DSC-R1 Sony SLT-A57 Sony Alpha 7R
hotdog321
hotdog321 Forum Pro • Posts: 15,214
Re: question about filters and IQ
The top of the line protective filters, like from B+W, are excellent and have very little effect on the IQ. The cheap stuff definitely degrades the image.
I'm a photojournalist and 99.9% of the time I do not use a filter. I've been active for over 30 years and find that a hard lens hood provides all the protection a lens will ever need, plus they minimize lens flare.
I do use a filter at the beach, in the blowing rain, shooting sandblasting, etc., but that's it.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
Aletheia Senior Member • Posts: 1,437
A filter can only have negative effects on image quality.  Those effects may well be very small in most circumstances, and they may be quite obvious in others, but another two glass surfaces can only harm image quality.  Sometimes, in very specific cases, the protective function will actually be useful, but I never use a filter unless I have a  specific reason to do so.  And I know I'm not helping image quality while it's on the lens.
Nothing is enough for the man to whom nothing is enough.
Mako2011
Mako2011 Forum Pro • Posts: 19,819
Many times
Been debated many times...truth is yes sometimes, especially if a poor quality one. Also the case that a good quality one can be near impossible to notice. Here for example only one of the pics had a clear filter on and the rest taken with nothing over the lens. Note how hard it can be to tell. All taken in ambient sun light with a tripod no PP
He's right, for the most part, when it's a high quality one. Lens flare can be an issue though, but even that can be well controlled with a good quality filter. Another example:  Only one of these pics had a filter on
Better to know what they are good for and when they can help and when they can be problematic. In other words...use one when it really can help and take it off when it might be detrimental. For example, with my Nikon 16-35 f4 lens (due to how it functions), a clear filter can greatly reduce dust/pollen from getting in. When shooting bright lights at night, I might take the filter off, unless it's pollen season.
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
Futax Regular Member • Posts: 377
As others have said, if you get a good quality filter, it'll be very hard to tell the difference in the final image- even pixel-peeping with a high quality lens/camera. That's assuming the scene doesn't have a flare problem; a filter can only exacerbate any flare, so it's essential to choose one which has good quality multicoating. You can get an idea of how various filters perform by looking here:
http://www.lenstip.com/113.1-article-UV_filters_test.html
Finally, beware of counterfeit filters: it's very easy for cheap filters to masquerade as the decent stuff, so you MUST buy from a reputable dealer.  And even then, it's probably worth doing a few test shots to confirm you're getting zero negative effect on image quality.  (If you get a dodgy filter, it'll usually be all too apparent in the final image.)
 Futax's gear list:Futax's gear list
Sigma DP1 Fujifilm FinePix F70EXR Sigma DP2 Merrill Canon PowerShot SX50 HS Panasonic Lumix DMC-XS1 +4 more
sshoihet Senior Member • Posts: 2,538
Yes it can. Will it?  Depends on the situations you shoot in.
I shoot into the sun a lot and at night with bright lights and it almost always causes an issue for me.  On top of that, I have quite a few lenses and good UV/clear filters aren't that cheap so for the price of some filters, i could probably replace 1 or 2 front elements if i happened to seriously damage them.
I always use a lens hood and cap the lens when i'm not actually taking a photo; I find that's sufficient protection unless maybe i'm shooting in mud or have water spray that i need to be constantly wiping off the front element.
 sshoihet's gear list:sshoihet's gear list
Canon PowerShot S95 Nikon D7000 Canon EOS M Nikon D600 Nikon D7100 +14 more
bosjohn21
bosjohn21 Forum Pro • Posts: 13,135
this has been debated pro and con since I joined dpreview in 08 or so. For all practical purposes no it won't degrade your image in any noticeable way. Theoretically it is introducing two more glass to air surfaces to increase flare and decrease contrast, A well made filter should have little or no effect on sharpness.
John aka bosjohn21
Graham Meale
Graham Meale Senior Member • Posts: 1,380
A filter must degrade the image, just as an elephant becomes heavier when you put a feather on its back. With a good quality filter the degradation is so minuscule that in 99.9% of situations it doesn't matter. Have a read of this
 Graham Meale's gear list:Graham Meale's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EF 50mm f/1.8 II Canon EF 100mm f/2.8 Macro USM Canon EF 70-300mm f/4-5.6L IS USM +5 more
MisterBG Veteran Member • Posts: 5,812
Before you make any decisions, this is very interesting:
http://lensesforhire.blogspot.co.uk/2014/07/smashing-fun-with-filters.html
Truthiness Regular Member • Posts: 122
Yes
Yes. You add two extra air-glass-surfaces to the optical path. Depending on the quality of the filter there will be a tiiny little more or a lot more reflections. Wether they are an issue to you is a different question. A good quality filter causes only minute changes not visible at all under most conditions.
When I touched SLRs for the first time, I used UV filter for protection, but since the only they they ever did to me was cost money, I didtched the practise. Now I would only use any kind of extra filter for protection if the environment hazards would be such that using one would be advisable (like sand flying in the air).
Salesman's job is to see products, not to tell the absolute truth, or even to have a clue.
Never trust salesmen. Never trust advertisements.
Mahmoud Mousef Senior Member • Posts: 2,526
most noticeable degradation of image at night with lights, in my experience. Though I wouldn't be without one. I'm still upset I can't put one on my camcorder or teleconverter lens. No filter threads on both.
AlphaTikal
AlphaTikal Senior Member • Posts: 2,031
A good filter will not decrease wuality in the sense of resolution and sharpness. But overall image quality is or can be touched, in the sense of vignetting and flares. My filters are expensive and deliver good quality. But thei suffer from flares, especially long shutters in the night.
· http://www.flickr.com/photos/blackhole_eater/
· (All photos are creative common licensed. Check them out.)
· English is not my native language.
 AlphaTikal's gear list:AlphaTikal's gear list
Sony RX100 Sony a77 II Sony DT 16-50mm F2.8 SSM Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004) Samsung Galaxy S7 edge +11 more
Sir Canon
Sir Canon Senior Member • Posts: 1,217
keep it clean and make sure its a good filter made by a good company like tiffen or heliopan. then it'l be fine. this page is pretty helpful: http://www.bhphotovideo.com/explora/photography/buying-guides/filters-lenses
 Sir Canon's gear list:Sir Canon's gear list
Panasonic Lumix DMC-TS1 Canon EOS 350D Canon EOS 550D Canon EF 50mm f/1.8 II Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
scorrpio
scorrpio Veteran Member • Posts: 3,388
A poor quality clear filter significantly degrades your image quality, has a fairly negligible impact on your wallet, and provides zero benefit.
A high quality clear filter has negligible impact on your image quality, significantly degrades your wallet contents, and provides zero benefit.
The sales guy will likely make 5x more selling you the filter than selling you the lens.  Keep that in mind.
Sir Canon
yes but a shattered front element costs way more.
Peter Jonas Senior Member • Posts: 2,659
Re: Filters can offer benefits.
This really does sound very smart, if one doesn't let the facts get in the way of creating a nice expression.
Filters can have benefits.
I would not necessarily consider protecting the front element from impact damage one of them, but if you are in such environment it will do good service in protectig your lens from the effects of heavy smoke, dust, grime, grease, sand, sticky fingers, wet pet noses and the like.
A family BBQ or a trip to the beach are almost inevitably such environments.
Yes, you have to be aware of fake items being sold mainly online, and yes, the dealer will attempt ro make good money on this item. Buyer beware.
Most of the time I will make a reasonable effort to find the item with the best price/performance ratio. In this instance I have settled on using Nikon NC or Hoya Super SMC Pro1 filters when appropriate.
Your mileage may vary.
Peter Jonas
 Peter Jonas's gear list:Peter Jonas's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +1 more
AlphaTikal
About what filters are you speaking? Nd filters and polarizing filters are useful.
Mako2011
UV too
UV protective filters can be useful too, even on digital, in special cases. Did a lot of high altitude shots above 18,000 and found that a good UV filter did help in those cases. Added a bit of better contrast. Might be a body filter combination thing.
AlphaTikal
Re: UV too
Maybe on old lenses?
