Camera is fine except for one major problem, LCD screen turn off.
Started Aug 3, 2014 | User reviews
Larry
Junior MemberPosts: 33
Aug 3, 2014
This problem is consistent with K50, K30, and even K500.The annoying LCD screen will not turn off as your using the viewfinder to take a photo. This also takes up battery power. I have to recharge my battery far to early. I even bought a back up due to this problem.
I do not use the LCD screen as its worthless in sunlight conditions. I have tried everything even the Pentax forum to get this camera to turn off the LCD. This is a Pentax problem they have not addressed to this date. Pentax forum has a lot of responses to this problem and I have tried all the actions suggested with no luck.
I do like this camera as an upgrade to the KX. I am taking it to Alaska. But the LCD screen annoyance is a big problem. I have contacted Pentax and they have not returned my call.
Larry's score
3.5
Average community score
4.4
Pentax K-30 Pentax K-50 Pentax K-500 Pentax K-x
brandrx
Forum ProPosts: 27,781
Re: Camera is fine except for one major problem, LCD screen turn off.
In reply to Larry, Aug 3, 2014
Press the Info button twice, then select Display Off.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
Tan68
Veteran MemberPosts: 5,277Gear list
Without a doubt, there is a way to turn off the LCD. I don't know if brandrx's recommendation (shortcut) works for all models you listed. If it doesn't, there will be a menu option somewhere.
In addition to turning off the LCD screen, it is possible to change the time the startup screen is displayed. Or turn it off altogether. Also, the replay screen.
Still, I get the idea you would like the screen to turn off when you bring the camera up to your eye to use the viewfinder..? If this is so, I am not sure the Pentax cameras do this. I haven't ever tried it... but I don't see any kind of sensor near the eyepiece other cameras have.
 Tan68's gear list:Tan68's gear list
Phase One Capture One Pro +1 more
Conjure
Regular MemberPosts: 403
1.) Go to Penatx/Ricoh - > Support & Service > Downloads: Operation Manuals
http://www.ricoh-imaging.co.jp/english/support/download_manual.html
2.) Download or Open the K-50 Manual
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-50.pdf
3.) Go to Page 29:
cheers
Anton
ozdean
Forum ProPosts: 22,441Gear list
You don't have a major problem.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 70mm F2.4 AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM +9 more
Leandros S
Senior MemberPosts: 1,636Gear list
or half-press the shutter button
In reply to brandrx, Aug 4, 2014
or half-press the shutter button.
No amount of perceived entitlement can replace actual expertise.
KRG1953
Regular MemberPosts: 248Gear list
In reply to ozdean, Aug 4, 2014
sometimes the man behind is the problem, not the camera
Michael Piziak
Regular MemberPosts: 406Gear list
In reply to KRG1953, Aug 4, 2014
Yep, it's a shame someone writes a review like this instead of asking in the forum.
 Michael Piziak's gear list:Michael Piziak's gear list
Pentax K-r Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA 18-55mm F3.5-5.6 AL +1 more
Wanganuilad
Senior MemberPosts: 2,210Gear list
In reply to Larry, Aug 4, 2014
heck, pentax forums couldn't help ?
K-5ii-s K-01 Q some Len
Larry
Larry OP
In reply to KRG1953, Aug 6, 2014
Unbelievably "inappropriate" answer. No go back to your room and put that dunce cap on junior.
Larry
Larry OP
In reply to Michael Piziak, Aug 6, 2014
its on the pentax form yo yo. Pentax website.
Larry
Larry OP
In reply to Wanganuilad, Aug 6, 2014
tried and failed.
Larry
Larry OP
In reply to ozdean, Aug 6, 2014
Oh, so your the expert, NOT.
Mac McCreery
Regular MemberPosts: 126Gear list
In reply to Larry, Aug 6, 2014
If it is like the Kr and K5 iis you hit the info button.
Cheers
Mac
 Mac McCreery's gear list:Mac McCreery's gear list
Pentax K-5 IIs Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) DxO Optics Pro Standard +1 more
Cideway
Veteran MemberPosts: 5,700Gear list
A few points to bear in mind.
1. Operating under the belief that you are referring to the Status displays on LCD screen you can disable them using the info button, read the manual particularly pages 24-29 and it gives and explanation of how to change between the screens and what information they contain.
2. A half press of the shutter button will blank out the screen, as there is no eye level sensor on the camera to detect when you place the camera to your eye.
3. Now if this isn't the issue that you are having with your camera then there is something else at play and that would be that your camera is defective and should be returned for service.
4. Given your posting history it would be natural for people to assume that you are/were trolling with your post, many members of the fora have been dealing with constant attacks for years and their natural response is to attack back at anything that is seen as trolling.
Finally though, don't be a twot in responding to people who are trying to help you, it is a horrible personality trait.
Chris.
A weather sealed ultra wide, is that too much to ask?
http://www.pentaxphotogallery.com/chriside
GMT +9.5
Pentax SLR talk FAQ
http://forums.dpreview.com/forums/read.asp?forum=1036&message=23161072
 Cideway's gear list:Cideway's gear list
Pentax K-5 II Pentax K-3 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Sigma 8-16mm F4.5-5.6 DC HSM +2 more
chiane
Veteran MemberPosts: 4,397
Larry, do you take drugs?
JeffAHayes
Senior MemberPosts: 1,968Gear list
In reply to chiane, Aug 8, 2014
Good question, Chiane. Based on his replies to some of the nicest, most knowledgeable and most helpful members in this forum, one would think if he doesn't, perhaps he needs to -- mood stabilizers, maybe? The one post that actually DISPLAYS the page from the user manual showing how to completely disable the display of the LCD screen completely answers the question/problem.
IF that doesn't work -- and we've yet to see ANY response from "Larry" that he's tried that, or any of the other useful suggestions -- then he MAY have a service issue. Otherwise, perhaps he is just trolling. It's always suspect with someone with only a few posts to his or her name when they come in flaming with an "issue" and then appear to pay NO ATTENTION to reasonable and responsible replies as to how to solve that issue.
I'd like to see a response from Larry that he HAS tried pushing the INFO button and scrolling down to turn off the LCD, and whether or not that works. If it does, his problem is solved, and then he owes an apology to several people, including Dean.
Jeff
A word is worth 1/1000th of a picture... Maybe that's why I use so many words!
 JeffAHayes's gear list:JeffAHayes's gear list
Pentax WG-3 Pentax K-5 Pentax K-30 Pentax K-3 Pentax smc D-FA 100mm F2.8 Macro WR +8 more
Brad99
Veteran MemberPosts: 3,145
In reply to Cideway, Aug 9, 2014
The only time I see my K-30 LCD is when I review shots.  I must be doing something wrong.
Larry
Larry OP
In reply to chiane, Aug 13, 2014
chain, yes right after I read your response.
Larry
Larry OP
Re: or half-press the shutter button
In reply to Leandros S, Aug 13, 2014
then turn it off and back on............walla its here again.
