My first sky replacement - Critique please
Started Aug 3, 2014 | Discussions
Florida Nature Photographer OP Senior Member • Posts: 7,805
Re: Can you work with the original sky?
Scotsman wrote:
Florida, I think you did a GREAT. Job for your first try. I
I was encouraged but not satisfied. I've received great feedback in this thread that will help me do better in the future.
 Florida Nature Photographer's gear list:Florida Nature Photographer's gear list
Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus 12-40mm F2.8 Topaz Adjust +3 more
Bassam Guy Regular Member • Posts: 319
Re: My first sky replacement - Critique please
On the first: well done. I don't pixel peep and I'm sure I could find some faults if I did.
On the second: blue sky doesn't match the color balance or ambiance of the water. It looks photo-shopped :).
You have far more skill and patience than I.
However, you can get skies that pop with a simple polarizing filter.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +2 more
duartix Veteran Member • Posts: 3,573
Too much uninteresting space below the car. Crop it out. It makes the composition better and the car stand out.
I'd also go with a bit of a crop on the right but a bit smaller.
TheĀ grass and trees should have been feathered when selected. You can see a few harsh artifacts (but only at 100%). Look out for the mirror on the passenger side. It's got artefacts too. But as I said before, it's hard to notice at 100%.
Duarte Bruno
 duartix's gear list:duartix's gear list
Fujifilm FinePix F40fd Olympus PEN E-P1 Panasonic Lumix DMC-GH2 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +4 more
rickreyn
rickreyn Senior Member • Posts: 1,433
You are quite ambitious. I admire your desire to tackle all aspects of photography, and your willingness to ask for CC. I think that technically you nailed the replacement, and there would be times that it's very necessary. A friend taking million-dollar home shots for a realtor has to do it frequently when the sky on the day of the shoot does not comply.
As for the composition of the car, nearly all the time a tighter shot would be better. My normal procedure is just get a part of the car. The eye imagines the rest. Of course, if you are taking shots for a dealership it's another story.
Anyway, it's a shame you have to go on vacation to really shoot something these days.
http://www.gloriography.com/Photography/AmeliaSavannah-2013/i-ffGLSX9/A
 rickreyn's gear list:rickreyn's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus 12-40mm F2.8 +8 more
19andrew47
19andrew47 Forum Pro • Posts: 22,003
I'm going to guess that the intent is, cut out the car and paste it into a dramatic image that will work with it, but just a guess.  I tried once.  Got the car but couldn't get a suitable background so still waiting  to find one six months later!
Andrew
Lee Beasley Senior Member • Posts: 2,389
People love bling, especially if it involves a prized possession. The subtleties of photography are lost on them as long as you've captured a unique expression or showcased their toys in a good light. The rest of the picture could be complete garbage, but they don't care, honestly.
 Lee Beasley's gear list:Lee Beasley's gear list
Pentax WG-3 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +3 more
Scotsman Senior Member • Posts: 1,447
You are much more ambitious than I am!  I'm getting there though.
A DSLR is a black hole that you throw money in to, and enjoy every minute of it!!!!
 Scotsman's gear list:Scotsman's gear list
Canon EOS 7D Olympus OM-D E-M5 Olympus E-M5 II Canon EF 50mm f/1.8 II Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +8 more
Good thought about a tighter shot. I have to remember to take multiple shots. Some isolating the subject and some putting the subject in context, for evaluation in post later.
19andrew47
Tighter Crop
I believe a tighter crop of the image you already have was mentioned by one of the posters above.  Perhaps something like below.  Note that you can take the opportunity to 'touch up the paint' for the owner as well as it is much cheaper to do in the image than on the car.  In the tighter crop the bland sky is less of an issue as it makes up a smaller amount of the image.  I would have cropped tighter yet on the left but cutting off the farm machinery is not a great idea, although total removal might make it work.  Replacing skies is not easy and lighting issues aside you did well!
Andrew
nevada5
nevada5 Veteran Member • Posts: 7,867
Here's the result using my procedure.
nevada5 wrote:
I've tried to replace skies in the past and never liked the results. I have good success changing dull grey skies to blue. I use PS CS5. I can't say if the procedure can be used in Elements, but I'll post it just the same.
Click on Magic Wand Tool. Set tolerance to 30. Uncheck Contiguous, uncheck Anti-alias, uncheck Sample All Layers.
Select the sky. Using shift, select all sky areas. Then Select>Modify>Feather, select 10 pixels +/- (I think I usually use 3-5 pixels).
Click on Gradient Tool. Select “Foreground to Transparent” from drop-down menu. Select “Reverse”, select “Dither” and select “Transparency” (check all). Set Opacity to 30%.
Click on the Foreground Color box and select a natural blue sky-like color. Color picker #1A56B1 is a good color.
Click on Gradient Tool again. Put mouse cursor on bottom of sky, drag to top of sky. Drag at an angle for a different look. If needed, click on “Edit” and “Fade.”
I used a tolerance level of 15 and still picked up parts of the car, so I deselected those areas.  That's part of using and learning the procedure. When I finished I used "Fade Gradient" and increased it from 30 to 40 to increase color.  Then I dodged the sky to brighten it.  For my tastes, it's more natural than to replace the sky.
Life is short - drive a convertible.
Tolerance is the last virtue of a dying society. Aristotle
 nevada5's gear list:nevada5's gear list
Nikon Coolpix P330 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-G7
Re: Tighter Crop
Andrew
That does have a bit more impact than mine. However, I'm a bit unsure about removing the front corner of the shadow. Is that me being too anal?
I tried to clone out the imperfections in the front of the car but it didn't look believable. What technique did you use?
Thanks for your effort.
Re: Here's the result using my procedure.
Thanks for this great alternative. Yours will definitely be more satisfying to the pixel peepers. It hadn't occurred to me to mask it out just to do normal adjustments.  I would normal apply that kind of thing to the whole image.
19andrew47
Re: Tighter Crop
For me, the important thing in the image is the car.  The corner of the shadow was cut off but I don't really notice it when comparing the before and after crops.  What is apparent to me is that the car takes a more dominant role in the image and that is as it should be.
At the moment I do all my cloning work in PSPX6.  The cloning tool allows for vairations in density and opacity and the donor spot can be set to move with the spot to be cloned as you move your mouse along.  There is a ridge line on the bottom of the bumper.  Set the cursor of the donor spot directly along the ridge and then locate further along the area you wish to clone.  Hold down the left button and move the clone spot along the ridge slowly watching what you are doing.  Check to make sure the ridge line in the cloned area and the original image line up and move the mouse down the line.  If the result is less than pleasing undo and try again, possibly changing opacity or density.  You must make sure the donor area is a good match for the area you are going to clone into or it won't work.  I believe I had the opacity set for less than 100% here because you can still see the paint blemishes below the added colour.  I didn't spend much time on this.  The key is to match the donor area well to the area to be cloned.  It is not always possible to do this well but sometimes it works out OK.  When cloning doesn't work as well as I like I will also use the airbrush to paint in details if I can improve upon the results.
I do not have lr 5 and don't know if the cloning tool has been improved over lr 4.
Practice makes perfect, or at least better and better!
Andrew
Re: Tighter Crop
For that type of cloning I'd use Elements not Lightroom. Thanks for the steps. I can apply them to the Elements method.
