My first sky replacement - Critique please
Started Aug 3, 2014 | Discussions
Florida Nature Photographer Senior Member • Posts: 7,700
I am finally getting serious about doing more advanced post processing. Up until now I have been focusing my efforts on learning how to use my E-M1 and the quirks of each of my three lenses. I've been trying to learn about composition. And I've been trying to tweak more and more advanced in Lightroom.
This is the first time I've ever done anything close to this.
The first one is what I would have normally been stuck with after using Lightroom.
The second one is what I ended up with.
The third is where the new sky came from.
Let me know how I can do better.
My process was:
  1. Do as much as I can in Lightroom
  2. Edit in Photoshop Elements 10
  3. Use Topaz Remask to mask out the sky
  4. Back to Elements
  5. Find a sky that look decent in my existing photos
  6. File | Place and select my sky photo
  7. Cntrl - T to free transform to get something that looked nice
Do you take your own sky shots or use those you can find on line?
 Florida Nature Photographer's gear list:Florida Nature Photographer's gear list
Olympus E-M1 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus 12-40mm F2.8 Panasonic Lumix G Vario 7-14mm F4 ASPH Adobe Photoshop Lightroom 5 +3 more
Olympus E-M1
DocJim65 Junior Member • Posts: 41
Re: My first sky replacement - Critique please
Lovely sky, handsome car. Doesn't quite make it though.
My eye goes from front of car to red machine to the left, then to the bright clouds in the gap between those trees. I get stuck there and must force myself to look away from that path.
I applaud your efforts and it makes me want to try it!
Jim
Florida Nature Photographer OP Senior Member • Posts: 7,700
Thanks very much for your critique. I really do appreciate it.
I took this photo for the benefit of the car's owner and his sun. I was  stuck with a lousy day and the car was parked where it was parked. The owner is a farmer so he may like having some of his machinery in the shot.
Very helpful to hear your reaction to the composition, however. I will keep that in mind when I have more options.
JohnLock Senior Member • Posts: 1,214
I'm impressed with how Topaz Remask handled the job-- I just got it but haven't used it yet.  Selection artifacts can be seen at 100%, but probably not at 50-60%?  I like the work and just think I'd add a little shadow in the foreground and up on the car-- very lightly though.  Nice work, and continue to experiment and enjoy.
JL
 JohnLock's gear list:JohnLock's gear list
Olympus E-M1
Spend 40 minutes watching this video tutorial before you get started and you will save yourself a lot of frustration.
BTW Don't blame Remask for the 100% artifacts. Until proven otherwise let's assume it was beginner error.
I assume you were lured by the 50% off deal that just ended, as was I.
I see that your are right about the highlights. I was overzealous about trying to make the car look white. Do you like this better?
Adamant Contributing Member • Posts: 600
For skies, I've been having good luck using VSCO's ++Blue and ++Darken Sky presets.  It's remarkable what can be recovered with the E-M1's raw files.  Plus the end result looks very natural since you're seeing the sky in the original shot.
Topaz did a good job here, but I still feel like I'm in the Uncanny Valley when looking at these masked shots.
Maklike Tier
Maklike Tier Regular Member • Posts: 382
Wow, the Topaz masking tool is awesome.  Wish I had something like that 15 years ago!
 Maklike Tier's gear list:Maklike Tier's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 25mm F1.8
19andrew47
19andrew47 Forum Pro • Posts: 21,687
You could touch up some areas on the right rear of the car and the tree line by cloning or go back and retry the masking and try for a different result.  I have not used this particular software but have tried in a couple of other programs and there are a number of adjustments that can be made that may improve the edge selection in those.  Your second try has better highlight control.  This is a difficult task with this image because of the trees and the sky that will show through the open areas of the leaves.  I don't have enough experience with sky replacement to offer any helpful advice other than that I had to play with several variables in PSP to get the best outcome, which was still less than perfect.  Lots of trial and error.
As an aside, that car is in a lot better condition than the white 84 (looks like the same year as in your image) that sits parked behind my house.
Andrew
baxters Veteran Member • Posts: 4,992
Not bad for first try, but the back of the car by the rear window is chewed up. You can copy that part of the car onto an upper layer in Elements so it covers any changes underneath. The polygonal lasso tool would work.
I haven't used Topaz. Looks like it can wiggle it way around the leaves in trees. Cool!
 baxters's gear list:baxters's gear list
Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6
Another trick that is less work is throw in a blue gradient in Lightroom. It screws up the tree colors a bit.
FNP;  thanks for the video link-- will watch.  Actually I have quite few Topaz plug-ins, but yeah, the 50% off got me on that one.  I'm looking forward to getting into it.
JL
Olympus E-M1
Hen3ry
Hen3ry Forum Pro • Posts: 15,289
Good stuff, and thanks for the tute link
I've been using Topaz Adjust with great satisfaction for some time. I got Remask a little while ago but hadn't made great headway with it. Many thanks for the tutorial link.
I actually don't like the car in this pic -- too white and featureless. Cool car, though.
By coincidence, I was pootling around on a local bus today and saw someone tooling down the road looking super cool in one of the second model Corvettes -- the one with the double headlamps, metallic red in concours condition.
Cheers, geoff
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://pngtimetraveller.blogspot.com/2011/10/return-to-karai-komana_31.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +5 more
All right, you guys are going to turn me into a pixel peeper if you keep this up. I hadn't noticed that but when I went in to see what you were talking about it was kind of ugly.
Tell me what you think of my latest try... and yes I changed the color treatment a bit as well, while I was at it, so don't be afraid to critique that also.I'm including my second posted version for comparison.
Lee Beasley Senior Member • Posts: 2,386
That's really nice. Now the foreground matches the sky. I'll bet he'll love that one. You need to get the Topaz light effects filter and toss a little glint on a bright spot or two. People love them. Nothing flashy... make it subtle.
 Lee Beasley's gear list:Lee Beasley's gear list
Pentax WG-3 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital ED 75mm F1.8 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +3 more
If you mean Star Effects I have it but I would never have thought to use it on a shot like this. There are no lights and no stars. How would you use it?
windmillgolfer
windmillgolfer Forum Pro • Posts: 11,813
Pretty good result Florida. Yes, there are a few imperfections, like the car body edge by the rear window. Mostly things that can easily be corrected. I suspect you didn't notice it because you were focused on the complex trees, which, with the help of Remask, look very good
I have Remask and need to put some effort in, so that usage doesn't require a read up every time. It is a wonderful product, so easy to buy, especially when discounts are on offer,  a tool to have in the armoury. But, like all tools, effort is needed to master them and get the best out of them.  I have Detail too, very good, and use it often for selective sharpening.
Stuart
Also at http://www.flickr.com/photos/dieselgolfer/
Mr Ichiro Kitao, please upgrade the FZ50
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GM1
Jim Salvas
Jim Salvas Veteran Member • Posts: 4,343
I picked up Remask recently too, and have been using it to replace backgrounds in portraits. It can do an amazing job with hair.
You might find it helpful to post in the Retouching forum. Some of the people there are amazing. Too amazing sometimes, but amazing.
Jim Salvas
"You miss 100% of the shots you never take." - Wayne Gretzky
 Jim Salvas's gear list:Jim Salvas's gear list
Olympus E-M1 Olympus PEN E-PM2 Olympus 12-40mm F2.8 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +9 more
Timur Born
Timur Born Senior Member • Posts: 4,606
Artifacts aside (grass) I am not so sure that this sky works the way you used it. The clouds look strange around the horizon tree line, too big and unnatural. Look at your third image again, how the clouds look changes towards the horizon.
The left side behind the trees also kind of looks a bit like a tapestry/studio background.
Red flash eyes save lives and eye-sight!
http://en.wikipedia.org/wiki/Retinoblastoma
 Timur Born's gear list:Timur Born's gear list
Panasonic Lumix DMC-LF1 Nikon D750 Olympus OM-D E-M5 Tamron SP 24-70mm F2.8 Di VC USD Olympus M.Zuiko Digital 45mm F1.8 +3 more
How do I do better? Use online skys? If I go take my own sky photo, how do I do it best?
