Guess the lens
Started Aug 2, 2014 | Discussions
Nikolausz
Nikolausz Contributing Member • Posts: 952
Guess the lens
I've just recently started to use this new lens set-up. Ii's a bit unusuall but quite effective.
I intentionally removed the exif data during the resizing of the photos. Not other modification was  done, theye are straight out of camera jpegs.
Guess the lens I used:
Cheers
Marcell
Nikolausz
Nikolausz OP Contributing Member • Posts: 952
Re: Guess the lens
Nobody??
uhligfd
uhligfd Senior Member • Posts: 1,852
Re: Guess the lens
It obviously is a lens that can focus very closely,  often called a macro lens.
There are hundreds or thousands of these out there. Who would care to guess, and we even do not know the camera that was used. Useless post, sorry.
Nikolausz
Re: Guess the lens
Show me a macro lens with a similar field of view!
Tuloom
Tuloom Senior Member • Posts: 1,800
Re: Guess the lens
I'm going with that being a wide angle on a close focus adapter?
Am I warm?
Nikolausz
Re: Guess the lens
Am I warm?
Actually cold, but regarding the concept, warm.
Adapter is included.
Nikolausz
Re: Guess the lens
Camera is nex-5.
Tuloom
Re: Guess the lens
Camera is nex-5.
SEL16 with extention tubes. Gotta be!
unknown member
(unknown member) Veteran Member • Posts: 9,509
Re: Guess the lens
Cheers
Marcell
M4/3 lens?
 neil holmes's gear list:neil holmes's gear list
Pentax K-x Panasonic Lumix DMC-GX7 Sony Alpha 7S Canon TS-E 17mm f/4L Canon TS-E 24mm f/3.5L II +8 more
Nikolausz
Re: Guess the lens
Not u4/3 lens
Nikolausz
Re: Guess the lens
Tuloom wrote:
Camera is nex-5.
No, but it would have similar effect I guess, but it wouldn't be that wide.
Ralic
Ralic New Member • Posts: 10
Re: Guess the lens
Cheers
Marcell
So, if i guess the lens, do i get a prize or something? You posted with this "contest" just to get clicks Just name the lens and get it over with, this is boring. Nothing special about the photos either, this could be taken with anything...
Sorry
steve vida
steve vida Regular Member • Posts: 390
Re: Guess the lens
So Im willing to guess they where taken on a 10-18 zoom with extention tubes.
By the way I find them fairly interesting & dont believe they could have been taken with just anything,but it must be a lens that has EXIF data.With a bit of PP I think these are worthy of public view ,dont be put off by the grumps.
Steve.
 steve vida's gear list:steve vida's gear list
Sony Alpha NEX-5N Sony Alpha 7 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony E 10-18mm F4 OSS +6 more
captura
captura Forum Pro • Posts: 21,538
Re: Guess the lens
A combo I was going to try anyway, so I had it in mind.
- The Sony E 30/3.5 macro lens fitted with the Sony VCL-ECU1 0.75X Ultra Wide Converter.
ProfHankD
ProfHankD Veteran Member • Posts: 3,730
Guess not
There are thousands of "usual" lenses that work on a NEX-5 and you want us to guess an unusual set-up based on low-resolution images... there's a much better chance of guessing your birthday -- and I've been doing some lens forensics work. Getting more technical about it, there is a lot of DoF and there isn't a lot of focus blur, but the OOF PSF looks fairly circular with a moderately bright edge. Both suggest a retrofocal wide angle is most likely.
In fact, it looks pretty kit zoomish to me. Maybe with a +1 close-up lens or similar, but the focus isn't really all that close (that spider is big, judging by the flies). Certainly, although the photos are fine, whatever lens configuration you used did not result in anything all that distinctive. Hope it didn't cost you much....
Canon PowerShot A640 Canon PowerShot A720 IS Canon PowerShot S70 Canon PowerShot G1 Canon PowerShot G5 +24 more
Nikolausz
Re: Guess the lens
Cheers
Marcell
Sorry
Then, don't comment it. Or show your more special photos taken with anything.
Sure, the "should I buy this camera to abandon my xy system topics are more interesting.
Nikolausz
Re: Guess the lens
Almost. We are very close.
Bart Hickman
Bart Hickman Veteran Member • Posts: 7,256
24mm + Raynox 150?
Zeiss 24mm + Raynox 150 to get close.  Just guessing here.
Bart
 Bart Hickman's gear list:Bart Hickman's gear list
Sony Alpha NEX-6 Sony a6000 Pentax smc FA 50mm F1.4 Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS +10 more
Nikolausz
Re: Guess not
It was taken in Germany so it's not a huge spider, maybe 2 cm length of the body and flies are fruitflies (as far I can judge) so they were tiny.
Nikolausz
Re: 24mm + Raynox 150?
Bart
No, this wouldn't be that close
Captura was almost correct.
