HVL F43AM Flash, Frequency, Time and Power please explain anyone?
Started Jul 31, 2014 | Questions
nihon94 Regular Member • Posts: 402
Hi,
I got Sony flash HVL F43AM and reading the users manual. There are some terms frequency, power, time for setting. I want to set for multiple flash which I found out but these terms Frequency, Time and Power are not clear. I do not want flash to be too bright because I will be near to the subject in the festival. What settings should I make?
Right now right now I have chosen Frequency 5, Time 5 and Power 1/16 is it ok?
Otherwise just explain what does those Frequency, Time and Power do?
Thank you in advance
nihon94
Leon van Roosmalen Contributing Member • Posts: 563
Re: HVL F43AM Flash, Frequency, Time and Power please explain anyone?
If i'm right you set your flash to fire at each trigger a puls of 5 flashes with a frequency rate 0f 5 per second at 1/16 power.
Greetings leon.
 Leon van Roosmalen's gear list:Leon van Roosmalen's gear list
Sony Alpha DSLR-A700 Sony SLT-A77 Sony SLT-A99 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-300mm F4.5-5.6 G SSM +7 more
nihon94 OP Regular Member • Posts: 402
Greetings leon.
Hi, thank you for answer. You are right but I wonder what does those things frequency, time and power do? what does 1/16 means etc.
lehill
lehill Senior Member • Posts: 1,897
It means if had a ball and let it fall you can take a photo like this:
Does that help?
Lance H
 lehill's gear list:lehill's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha DSLR-A850 Sony SLT-A77 Sony a77 II Sigma 10-20mm F4-5.6 EX DC HSM +24 more
Glenn Veteran Member • Posts: 7,476
Greetings leon.
frequency in the number of flashes. in this case the flash will go off 5 times. in the time of one second with the flash power reduced to 1/16th of full power.
Greetings leon.
Hi, thanks a lot for giving me details I appreciate it very much.
