Help needed: Travel Tripod for A7+LAE-A4?
Started Jul 31, 2014 | Discussions
darkdirtydwarf
darkdirtydwarf Senior Member • Posts: 1,019
I'll try to be quick and clear to give you a better understanding of my problem.
  1. I almost never use the tripod, I hate it, it's annoying to carry it, use it, it's for nerds
  2. I need to use one to improve my photography, no way around it
  3. It must be compatible with the A7 equipped with the LAE-A4
My first choice would have been the 3LT Eddie. I want something small, light, that I would not mind taking with me "just in case", and if it's fancy it helps feeling less nerdy carrying it around. The built in monopod of the 3LT Eddie is a big plus and this model has plenty of extra features (weight hook, bubble level etc).
Unfortunately the plate is too big and won't allow me to use it with the A7 when using the LAE-A4 on it (the motor of the adapter gets in the way). As most of my wide angle and tele lenses are A mount, being able to use the tripod with the A7 sporting the LAE-A4 is a must.
The solutions I imagine are:
  1. Buy the Eddie and use it with a smaller plate (is it compatible? Would it be overkill?)
  2. Buy the Eddie without ball head and get a ball head with a smaller plate (which one?)
  3. Buy another tripod, like the Keith (or equivalent from another brand: suggestions?).
I'm new to tripods, I have a crappy unstable plasticky one I rarely used cause my hands are steadier, so I'm open to suggestions. I'd prefer to keep the cost below 500 Euro.
Thanks in advance!
 darkdirtydwarf's gear list:darkdirtydwarf's gear list
Sony Alpha NEX-5 Sony SLT-A55 Sony Alpha NEX-5N Sony Alpha 7 Sony E 16mm F2.8 Pancake +8 more
Sony Alpha 7
WestO Forum Member • Posts: 91
Re: Help needed: Travel Tripod for A7+LAE-A4?
MeFoto Backpacker or Roadtrip - Strong, portable, lightweight, and sturdy tripod. Check the reviews anywhere, you will find happy customers; I'm one.
 WestO's gear list:WestO's gear list
Sony Alpha 7R Sony a6000 Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Sony FE 55mm F1.8 +6 more
darkdirtydwarf
darkdirtydwarf OP Senior Member • Posts: 1,019
I'll check their website. There is a useful "Help me choose" system. I'm gonna try it and see which model they say fits my needs
You should be Ok. The backpacker is more portable, but the Roadtrip has a built-in monopod, which is nice for someone like yourself that doesn't like to carry a tripod. I have used it with the LAE-A2 with 5T, so it should be an issue with the A7. The plate is very small but solid. Good luck.
darkdirtydwarf
The roadtrip is quite nice. But for the price difference (aluminium version), I'm trying to decide whether I should just go for the globetrotter model. It's still small but seems to have a better plate.
What would you say?
Letsgokoulos
Letsgokoulos Senior Member • Posts: 1,773
Have you thought of attaching the tripod on the LA-EA4 adapter ?
I can't imagine a tripod plate would be a problem there...
Marc
darkdirtydwarf
Marc
LoL!
Obviously I didn't... I am so used to the LAE-A1 with the tripod adapter removed that I completely forgot that the LAE-A4 has a thread under it...
Thanks for pointing it out! Now I could get the Eddie, but thanks to this thread I realized the MeFOTO tripods are enough for my needs and a lot cheaper
JeffGo Contributing Member • Posts: 831
I recently bought the Roadtrip Carbon as well. It's quite light and the monopod is a nice to have feature. The clamp does interfere a little with the L bracket I am using but should be fine with an adapter+plate instead.
 JeffGo's gear list:JeffGo's gear list
Panasonic Lumix DMC-TS20 Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-7 Sony E 18-55mm F3.5-5.6 OSS Voigtlander 28mm F2 Ultron +11 more
I think the globetrotter weighs about a pound more. for someone who doesn't like to carry tri-pods to begin with, it will be noticed. Also if your are using it on an A7 with E-mount lenses, the plate on the roadtrip will suffice.
darkdirtydwarf
Is the carbon version really better than the alloy version? I'm having a hard time trying to decide. I rather invest the extra cash in a lens or something...
darkdirtydwarf
Yes, you're correct, it's one more pound. The carbon fiber version has the same weight of the roadtrip in aluminium (but costs so much, I'd rather buy both tripods in the aluminium version...).
I'm planning on using it with longer lenses too. I have a Minolta AF 100-400 APO that's quite heavy and slow.
I can't use it hand held properly, it's doable with a lot of light, but extended is hard to frame the image correctly quickly and the lack of any kind of stabilization makes it even worse in less than ideal light conditions; even still images require sniper skills, but even holding my breath while pressing the shutter is not enough to get the best out of this lens (this lens is not tack sharp to begin with).
Of course I CANNOT afford the FE70-210 (I mean, I could, but hey, my son's got to eat... )
PVCdroid
PVCdroid Senior Member • Posts: 3,714
Thanks in advance!
Save some money. Check these out:
http://www.dpreview.com/forums/thread/3697570
 PVCdroid's gear list:PVCdroid's gear list
Sony Alpha NEX-5N Sony Alpha NEX-7 Sony Alpha 7R Sony Alpha 7R II
darkdirtydwarf
thanks for the input!
They look interesting, I'll read up a bit and see whether I could buy one of these instead (the Q-666 in carbon fiber seems very interesting)
You will just have to hold each one. To me it was worth it but the difference in weight is only about a half pound. I don't think there is any other differences and the alloy comes in lots of accent colors.
mgerpe
mgerpe Regular Member • Posts: 242
Thanks in advance!
I love my 3LT but for traveling light you should go with something much much smaller and lighter.
"Sit loosely in the saddle of life"
http://www.michaelgerpe.com
darkdirtydwarf
Which weight do you thing would be best? Isn't there the problem of having a tripod that's not that stable, it it's too light? Smaller one also tend to have no hook to add weight...
Choosing a tripod turns out to be much more complicated than I expected..
It will really depend on the tripod. I bought a Manfrotto carbon fiber 190CX3 and it turned out to not be very stable - they have revised it recently. But the carbon fiber meFoto Roadtrip is very stable, and it has a weight hook.
Brian_Smith
Brian_Smith Senior Member • Posts: 2,499
I'm really happy with the 3 Legged Thing Brian. It's very solid and no vibration with that combination and a 70-400mm G lens.
darkdirtydwarf
thanks for the answer (and to putting up with all my typos, I should take more care when I write here.. )
The meToto tripods are very tempting due to the price. But I guess still need to do some thinking regarding how I will use it, in order to better chose the right model (I really don't want to end up buying two, for now...).
darkdirtydwarf
Hi Brian, thanks for your input, I value it!
Do you think the changes made in the Eddie model are worth the extra cost compared to the Brian?
