Samyang 7.5/3.5 defishing examples
Started Jul 30, 2014 | Discussions
phodopus Junior Member • Posts: 49
All images defished to cylindrical projection, using AnglerFish, still in development stage:
http://anglerfish.ajotte.com/
This style of defishing straightens only vertical lines and sometimes gives "strange" results (look for example at the floor in the second pair of images), but people are not stretched and look natural. Now I can use my fisheye lens more often - not only for typical fishy images, bus as a ultra wide lens
And I need your help - if you have a fisheye lens not listed in AnglerFish, maybe you could take a profile photo and mail it to me?
 phodopus's gear list:phodopus's gear list
Olympus OM-D E-M5
Aaron801 Senior Member • Posts: 3,096
Re: Samyang 7.5/3.5 defishing examples
I love the idea of using a really wide lens and then making the images look not so "fishy." I like the fisheye look actually, but only for certainly kinds of images.... I really like wide angle though and if I thought that I was able to use a fisheye for more traditional looking wide angle shots (using a de-fish software) I think that I'd really consider getting a lens like that.
Still, it seems to me based on your experiments with it (that I really appreciate) that many images are still going to have the earmarks of that fisheye look even once you've done the correcting work. Other images are convincingly "flatter" with those bowed lines taken out, but if there are lines at certain angles that aren't perfectly vertical or horizontal it seems that they're still going to have that fisheye look... Though maybe there's other methods for correcting that stuff as well...?
 Aaron801's gear list:Aaron801's gear list
Panasonic Lumix DMC-GH2 Olympus OM-D E-M10 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS
hybert46 Contributing Member • Posts: 639
Hi,
you show some very good example of defished pictures. I have tried this process several times with my Samyang fisheye but I used the Hugin freeware. It is also interesting to play with the different projections to have different rendering. It really depends on the scenery you have captured as some projections work better for architecture, and some other work better not to distort too much people.
For me, the biggest problem of this method is the composition of the final defished image. I find it very difficult to compose well the picture having in mind how the defished image will look like.
Simon
Simon
Flickr favorites: http://flic.kr/s/aHsjkypfZu
E-M5, 7.5mm fisheye, 9-18mm, 12mm, 20mm, 45mm
 hybert46's gear list:hybert46's gear list
Olympus E-30 Olympus PEN E-PL2 Olympus OM-D E-M5 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
phodopus OP Junior Member • Posts: 49
Yes, there is other method: rectilinear projection
But areas near image edges look awful and have to be cut off.
Example:
For this image I used rectilinear conversion and, because it could be done here without bending horizontal and vertical lines, I used "center/edges H" slider to expand tower width and narrow edges.
This image is defished to rectilinear, then has only pespective corrected and is of course cropped:
For this kind of images electronic level is very useful
Olympus OM-D E-M5
daymon Regular Member • Posts: 121
Thanks for sharing, and interesting results. I think this so called cylindrical projection should also work nicely for landscapes, just to straighten trees for example.
I'll give it a try when I'm back home. Are TIFF files supported?
 daymon's gear list:daymon's gear list
Olympus OM-D E-M5 Canon EOS 6D Canon EF 135mm f/2.0L USM Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Samyang 14mm F2.8 IF ED MC Aspherical +3 more
Yes, tiffs are supported, 8 and 16 bits.
Olympus OM-D E-M5
dinoSnake Senior Member • Posts: 1,607
hybert46 wrote:
Hi,
I switched over from Hugin to a Photoshop RAW lens profile, very smooth and with excellent results - just click on the profile while in ACR and continue with the balance of your workflow.
windmillgolfer
windmillgolfer Forum Pro • Posts: 11,990
Thanks for posting phodopus. More evidence, methinks, to support going for the Samyang fisheye as my solution to wideangle on the G6 I just bought.. The x2 factor for  MFTs is quite a challenge for me as I prefer 24mm and less.
Stuart
Also at http://www.flickr.com/photos/dieselgolfer/
Mr Ichiro Kitao, please upgrade the FZ50
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GM1 +1 more
JimLindner
JimLindner Senior Member • Posts: 1,303
Very interesting concept. Some very pleasing results, I love the 7.5 Samyang and anything that makes it more versatile is a plus in my book.
I downloaded the program and will give it a go when I get a chance. It would be nice if final version would work as a Lightroom plugin.
You might want to add system requirements to your download page so folks would know if it would run on their platform, ie Win7, Win8, MacOS.
Good Luck with the project.
Regards Jim
We All Need Water!
 JimLindner's gear list:JimLindner's gear list
Panasonic Lumix DMC-G3 Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS Samyang 7.5mm F3.5 UMC Fisheye MFT Olympus M.Zuiko Digital ED 75mm F1.8 Adobe Photoshop Lightroom 5 +1 more
Timur Born
Timur Born Senior Member • Posts: 4,606
I like how this defishing method keeps the angle of view intact and thus makes composing easier.
At which areas do you lose resolution due to stretching with this method? Center? Edges? In between?
Red flash eyes save lives and eye-sight!
http://en.wikipedia.org/wiki/Retinoblastoma
 Timur Born's gear list:Timur Born's gear list
Panasonic Lumix DMC-LF1 Olympus OM-D E-M5 Nikon D750 Nikon AF-S Nikkor 50mm f/1.4G Olympus M.Zuiko Digital 45mm F1.8 +3 more
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,102
While I own the lens (Bower 7.5) I recommend that you also look at the Olympus 9-18.  Small, not too expensive, and very good optically.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus PEN E-PL2 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +11 more
windmillgolfer
Michael, thanks for the recommendation. Samyang is the main brand name in the UK.  I understand that Samyang, Bower and Rokinon are all the same lenses. The Olympus is quite a bit less than the Panasonic but I'll probably go for the Samyang as I quite fancy having a play with the fisheye optics. Sounds like the G6's electronic levels will help.  I still have my LX7 + LWA52 add-on lens giving 18mm at f1.4. So, have something to fall back on if de-fishing isn't satisfactory or too onerous.
Stuart
Here is an example - source image, then saved with rectilinear and cylindrical projection:
Rectilinear image has much more stretched edges, so only central area is usable. In cylindrical projection top and bottom edges are expanded up to about 120%. Is is not visible very much.
Olympus OM-D E-M5
Here's a quick test with some landscapes. I have to say this is exactly the kind of projection I have been looking for. As Jim said, would be really nice if the tool could work as a LR plugin, and OSX support would be great too! I know, it's a lot to ask...
