What sort of shutter count level are A7R owners at?
Started Jul 12, 2014 | Discussions
davidevans1 Senior Member • Posts: 1,294
I'd be interested to hear what sort of shutter count A7R owners are at, and for the higher shutter count owners, have there been any problems or is it all good news?
I have a Nikon D800E and apart from the weight (which I can manage OK as I only ever carry two lenses) and the slightly inferior screen (by today's standards)for manual focusing in liveview, I have zero complaints and really enjoy using it.
However the D810 is interesting for some time in the future, mainly for the better resolution screen, but then it dawned that the A7R is roughly £1,000 less than the D810. Would it be a better option? That's where my question is coming from.
Also neither of the two lenses I use most are Nikon (one a 135mm Zeiss, the other a 50mm Sigma).
My photography is a mixture of landscape and urban. Landscape on tripod and urban usually handheld.
Thanks for any feedback on the A7R.
David
echolsphoto
echolsphoto Contributing Member • Posts: 780
Re: What sort of shutter count level are A7R owners at?
I wish I knew. It seems that the cameras use what ever number is on the card and add to it.
I have two A7, and they both are at the same exposure count. Because I swap cards. There is supposed to be a web site that can tell but it doesn't work for me. I know I have over 10k exposures on one of them. No problems
LeicaBOSS
LeicaBOSS Regular Member • Posts: 432
Isolated incident, maybe, but my shutter failed after about 10k images. They apparently had enough failed shutters that the part was backordered for over a month. A7r
From time to time, I point my camera at the right things. This is generally when I forget everything I've learned.
 LeicaBOSS's gear list:LeicaBOSS's gear list
Leica M9 Sony SLT-A77 Canon EOS M Sony Alpha 7R Canon EF 50mm f/1.8 II +17 more
NomadMark
NomadMark Contributing Member • Posts: 602
Shutter failure. Shutter shake....
...the D810 most likely will have fewer issues.
https://www.flickr.com/photos/nomadmark/
 NomadMark's gear list:NomadMark's gear list
Canon EOS 6D Sony Alpha 7R Canon EF 50mm f/1.2L USM Canon EF 135mm f/2.0L USM Canon EF 400mm f/5.6L USM +12 more
Juha Kannisto Regular Member • Posts: 102
I'm at 69012 according to Image Count read with ExifTool. Haven't had any issues with shutter. My A7r is Japan model bought on 15th of November last year.
 Juha Kannisto's gear list:Juha Kannisto's gear list
Sony Alpha NEX-6 Sony Alpha 7R Sony Alpha 7 II Voigtlander 35mm F1.2 Nokton Sony E 16-50mm F3.5-5.6 PZ OSS +39 more
LeicaBOSS
Don't count on it. If this comes from a fanboyism place, then fine. We can maintain the illusion for you. Otherwise, let us not pretend Nikon hasn't had its share of horrifying service/engineering issues and shutter replacements at the shop right now.
P.S. Every time someone mentions 'shutter shake' as a design or reliability problem, an angel dies... along with a little piece of my faith in humanity.
Nigel Clifford Contributing Member • Posts: 771
Mines of similar age, November 2013 Japan, not sure of shutter count had to have a PCB (C.BOARD.SY-1) replaced last month, camera would not remember any custom settings.
Nigel
 Nigel Clifford's gear list:Nigel Clifford's gear list
Sony RX100 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-ZS60 Sony Alpha 7R II Tamron SP 24-70mm F2.8 Di VC USD +4 more
davidevans1 OP Senior Member • Posts: 1,294
I agree, every manufacturer seems to have problems with particular parts or functions and some manufacturers stay in denial of the problem for way too long! Digital cameras are comparatively new technology and subject to relentless progress and advances. The consumer ends up being the real tester and pays for the privilege (in much the same way as buyers of branded clothing are paying for the privilege of marketing the brand!)With the A7R the one thing that caught my eye in the tests was the reports of the loud shutter, hence my question on shutter count. Do Sony give a shutter lifespan estimate like Nikon does on their pro cameras (250,000 activations in Nikons case I think)?
David
LeicaBOSS
Unfortunately, I don't know of a reliable published rating for Sony. I also don't think I would trust a thing they say. I couldn't imagine someone attempting to build one rated under 150k at this point, but it'll really be guesswork.
