ACTION SHOTS
Started Jul 3, 2014 | Questions
BEARMYLOVE
BEARMYLOVE Regular Member • Posts: 323
ACTION SHOTS
What are the settings and posture I should use when using the D7100 & 18-140mm for action sport? Action sport for me means my dog running towards me or away from me or running and stopping at intervals on a foot ball field.
Nikon D7100
ryan2007 Forum Pro • Posts: 12,001
Re: ACTION SHOTS
This is about as broad as it gets.
Variables: Weather conditions, snow, clear, rain (mist)
Lighting conditions - time of day and location of Sun or cloudy day
Filters in use - will reduce exposure. You want to shoot wide open but it is too sunny and you need to stop down. You want the dog and clouds to be well defined with a blue sky etc.
Short version with any camera.
Single shot autofocus to lock onto the subject, stop the lens down as much as possible to increase the chances of a sharp result, use the rapid fire motor drive so when you press the shutter it rattles off shots. At least one should be in focus.
Use of a mono-pod is helpful as well.
Composition as close to eye level with the dog or any subject matter is always a good idea.
Metering mode could be matrix or center weight depending on the lighting.
Their is also a difference if you are stationary shooting or having to move fast, stop, compose and shoot. In this case using Release priority if the camera has it is an option.
*Look up how to shoot football or soccer, the dog could be a player running the field you need to shoot so the same idea applies with the dog.
curiousmike1300
curiousmike1300 Contributing Member • Posts: 641
Re: ACTION SHOTS
This is what I've dedicated the last 3 months of my photography to, and I still fail.
I upgraded from a D5000 with a kit 55-200 to my current D7100 with a 70-200 F4 which should be much faster.
The fact of the matter is -- it's still really hard to get perfect focus with dogs running right at you. Better success if the dog is running perpendicular to you and you pan.
I use Aperture priority mode, AF-C, spot focusing with matrix metering, shutter speeds > 1/500 (more like 1/1000) and various apertures -- typically a stop or two down from minimum.
You have to watch your shutter speed and not let it drop below... 1/500th?  1/1000th?
Personally, I'd start with just ensuring you're at 1/1000th to help with success.
Also, if your aperture is too small (and the AF-C prediction misses ), you will have a lot of images where the dogs shoulder is in focus but not their head.   I have found that upping my aperture to the 6.3 or 7 or 8 range helps with this regard by having a slightly deeper DOF.  Of course, that typically means upping the ISO.
 curiousmike1300's gear list:curiousmike1300's gear list
Sony RX100 Nikon D5200 Nikon D610 Olympus OM-D E-M10 Nikon AF-S Teleconverter TC-17E II +9 more
BEARMYLOVE
BEARMYLOVE OP Regular Member • Posts: 323
Re: ACTION SHOTS
Thanks so much. I'll give this a shot.
GerardHaines Regular Member • Posts: 496
Re: ACTION SHOTS
Uncropped images of my Britts taken with an 18-140 on a D7000 this past March, excuse the snow fence in the background:
 GerardHaines's gear list:GerardHaines's gear list
Nikon D7000 Nikon D5100 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Tokina AT-X Pro 11-16mm f/2.8 DX II +1 more
Phathom
Phathom Senior Member • Posts: 1,099
Re: ACTION SHOTS
I posted about this a little while ago. I link you to a blog that was written for the d300 but has the same AF system as the 7100. It's fantastic advice.
http://www.dpreview.com/forums/thread/3691096
 Phathom's gear list:Phathom's gear list
Sony Cyber-shot DSC-RX100 III Nikon D810 Nikon D500 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +3 more
curiousmike1300
Re: ACTION SHOTS
A little crop, a little color correction
BEARMYLOVE
Re: ACTION SHOTS
HI,  WHAT DO YOU USE FOR POST PROCESSING?  THANKS, RAB
curiousmike1300
Re: ACTION SHOTS
I use Lightroom.
Assuming I'm shooting in good light, most of my RAW processing involves adding some contrast, pulling down highlights a bit ( lighter colored dogs I might pull down more ), push up shadows a bit, add some clarity and a smidge of vibrance.    Sharpening is to taste, but I would say 40-50 is typical for me.
