FZ1000, Infamous Back Wheel Pushing Back?
Started Jul 1, 2014 | Discussions
Proacguy
Proacguy Regular Member • Posts: 296
It seems the FZ1000 has the back wheel pushing in operation once again. In view of the horror story I have had with the back wheel pushing in on the FZ200 that broke after 1 year, and with many other users also, are we heading back to the same problem?
Please  tell me that I am wrong!
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-FZ200
morepix
morepix Veteran Member • Posts: 8,722
Horror lite?
Proacguy wrote:
It seems the FZ1000 has the back wheel pushing in operation once again. In view of the horror story I have had with the back wheel ...
Ugh! But how do you know it's the push-click and not just a nice, smoothly rotating control wheel? If it actually is the old style, what a shame -- even a niggle. Ddon't you think "horror" is a bit strong?
I guess it's a way to get two control wheels for the price of one, but it sure doesn't do it very well. I've been delighted at how easy it is to operate the control wheels on my Olympus Stylus 1 and E-M10. Why doesn't Panasonic learn?
David
www.pbase.com/morepix
 morepix's gear list:morepix's gear list
Ricoh GR Olympus Stylus 1 Panasonic Lumix DMC-FZ1000 Olympus OM-D E-M10
Proacguy
Proacguy OP Regular Member • Posts: 296
Re: Horror lite?
Qote from the DP Review Hands on:
The FZ1000 supplies a single, clickable rear command dial. In full manual mode, pressing the command dial shifts between shutter and aperture priority. In semi-manual modes, pressing the dial toggles between exposure compensation and aperture, shutter or program shift, depending on your mode. Exposure compensation is not available in manual mode.
Seems a click wheell like on the FZ200.
morepix
Re: Horror lite?
Proacguy wrote:
Quote from the DP Review Hands on:
Gotcha. Thanks for the info. Too bad, too bad. One might almost say, taking one's lead from Colonel Kurtz, "The horror, the horror!"
David
JoePhoto
JoePhoto Veteran Member • Posts: 6,916
Re: Horror lite?
I hope the wheel is easier to turn without accidently activating the "button".
I know there are some trick ways to do it on the FZ-200 but I still have problems with it.
Thanks for reading .... JoePhoto
( Do You Ever STOP to THINK --- and FORGET to START Again ??? )
Stephen McDonald
Stephen McDonald Forum Pro • Posts: 12,949
Turn and Push Wheel
Sony moved away from the dual-action wheel this year. Now, the push part is done to choose the function, on the arrow-button cluster. You can use either the left/right buttons or the wheel to change the setting. I didn't like it at first, but after awhile, I found it to be quicker and more precise.
cainn24
cainn24 Senior Member • Posts: 4,722
Re: Horror lite?
Look at it though:
http://camerasize.com/compare/#556,349
It's bigger, more robust looking.  Sure, maybe it's just a cosmetic/ergonomic tweak, but it's also possible that they reworked the whole mechanism.
Unfortunately it will probably take longer than the warranty period to find out...
John Miles
John Miles Veteran Member • Posts: 6,905
Re: FZ1000, Infamous Back Wheel Pushing Back?
The wheel is reported as being much better than that on the FZ200:
http://www.youtube.com/watch?v=zpyCJdjYFVg
__________________________________________________________________________
The FZ50: DSLR handling of a bright, non-extending Leica 35-420mm F2.8-3.7 lens. Thank you Mr Ichiro Kitao, Mr Michiharu Uematsu and Mr Yoshiyuki Inoue for having triggered the update to the FZ50.
FZ50 is still great though: http://www.juzaphoto.com/recensione.php?l=en&t=panasonic_lumix_fz50 . Performace diagram here: http://www.dpreview.com/galleries/3862228415/photos/2623982/fz50-performance-range
 John Miles's gear list:John Miles's gear list
Panasonic Lumix DMC-LX2 Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-G5 +1 more
