Nex5n Owner bought an A7, shutter speed question
Started Jun 25, 2014 | Questions
ksarkar77
Junior MemberPosts: 32
Jun 25, 2014
Hello All,
I have recently purchase a Sony A7. I was comparing it against my beloved Nex5n and I noticed a strange shutter speed behavior. I was shooting the same subject under same lighting condition with respective kit lenses wide open, i.e, 18-55 on Nex5n @F 3.5 and 28-70 on A7 @ F 3.5.
Here is the shutter speed and other details.
Nex5N: 18 mm, ISO 3200, Shutter Speed 1/50, F 3.5
A7: 28 mm, ISO 3200, Shutter Speed 1/20, F 3.5
I was expecting that A7 would record higher or at least the same shutter speed compared to Nex5n as Nex5n is shooting 18 mm @f 3.5 (27 mm f 5.2 on full frame equivalent after considering the crop factor).
Is my Sony A7 broken? Or am I missing something?
I have started learning f stops, shutter speed and crop factors and so on very recently, so if it is very silly question then please forgive my ignorance.
Kuntal
Sony Alpha 7 Sony Alpha NEX-5N
andrewD2
Veteran MemberPosts: 8,468
Re: Nex5n Owner bought an A7, shutter speed question
In reply to ksarkar77, Jun 25, 2014
If the photos are taken at those settings are they the same brightness?
If they are the same brightness then the A7 is overrating its ISO relative to the 5N.
If the A7 image is a lot brighter it is a difference in metering (area used / algorithm / calibration)
Andrew
ksarkar77
In reply to andrewD2, Jun 25, 2014
Andrew
Hi, I am not sure about that. I did not see them side by side on the monitor. I assumed that both camera should expose similarly.
Ok, I will take couple of pictures tonight and post it here.
SQLGuy
Senior MemberPosts: 3,689Gear list
If your scene has mixed bright and dark spots, you may also want to switch to spot metering to ensure the two cameras are using the same point and light intensity on which to calculate exposure.
A7 with kit lens and a number of legacy lenses (mostly Canon FD); A3000 converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 A3000 Sony Alpha 7 Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
ksarkar77
In reply to SQLGuy, Jun 25, 2014
Thank you SQL guy for the advice. My cameras were in matrix metering mode. I will switch them to spot metering and get some samples.
Kuntal
andrewD2
Kuntal
The simpler way is to set both to the same exposure manually "M Mode" and see if they match.
The other possible is that the A7 lens vignettes so badly it is losing more light than the 18-55.
Andrew
ksarkar77
Kuntal
Andrew
Hi Andrew,
Can you please be little bit more elaborate? Did you mean that on M mode, set the same shutter speed, ISO, F stops and then compare the brightness of the pictures?
About the Vignetting, did you mean that I have a bad copy of lens on my A7?
andrewD2
ksarkar77 wrote:
Kuntal
Andrew
Hi Andrew,
Yes, eliminate the possibility of the cameras metering differently by setting the same ISO, exposure time and aperture.
I'd not worry about your lens, if it vignettes strongly it is likely to do it on them all. Wait and see the results of the test first.
Andrew
viking79
Forum ProPosts: 14,098Gear list
ksarkar77 wrote:
Hi Andrew,
Check settings like DRO (dynamic range optimizer) as that intentionally underexposes and boosts the exposure of the shadows to protect highlights.
For M mode, set both cameras to M and do the same exposure for both and look at the resulting images. Brightness should be the same.
For example, it might be 1/100 at ISO 100 f/7.1 the resulting image should be the same brightness on both cameras.
In terms of equivalence if you want truly similar photos:
18mm f/3.5 1/100 at ISO 100 on the 5N should look like:
28mm f/5.6 1/100 at ISO 250 on the A7.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
ksarkar77
In reply to viking79, Jun 25, 2014
viking79 wrote:
ksarkar77 wrote:
Hi Andrew,
Eric
Thank you both to Eric and Andrew. I will do the test and post the result here.
Elandreth
Regular MemberPosts: 185Gear list
In reply to viking79, Jun 26, 2014
Eric
Why is the ISO different between the two cameras in your equivalence example?  Is it based on pixel density?
 Elandreth's gear list:Elandreth's gear list
Sony Alpha NEX-5N Sony E 18-55mm F3.5-5.6 OSS Leica Elmar-M 24mm f/3.8 ASPH Carl Zeiss Distagon T* 4/18 ZM Voigtlander 12mm F5.6 Ultra Wide Heliar +24 more
AlphaLux
Forum MemberPosts: 64
In reply to Elandreth, Jun 26, 2014
Guys, you don't calculate crop factor and equivalency of f-stops when it comes to light gathering capabilities. Only in depth of field comparisons. As far as exposures go, the f-stops will be the same
Brand new Tumblr dedicated to my life through the Sony a7
http://alphaetlux.tumblr.com/
ksarkar77
In reply to AlphaLux, Jun 26, 2014
AlphaLux, I do not get it. Is it not that light gathering ability is more on full frame, hence should get higher shutter speed ?
I did some test today as per the suggestion from the other posters. Manual mode, F 3.5, ISO 3200, Spot Metering, straight JPEG out of camera. Still A7 is registering slower shutter speed compared to 5N.  What is going on here guys???
A7, ISO 3200, F 3.5, Shutter Speed is 1/8
5N, ISO 3200, F 3.5, Shutter Speed is 1/10
forpetessake
Senior MemberPosts: 4,775
That is incorrect, the DOF and amount of light are affected to the same degree by cropping. You need to multiply f-stop by the crop factor to get equivalent settings on both cameras. The ISO can be set on auto, it doesn't really matter.
ksarkar77
In reply to ksarkar77, Jun 26, 2014
I am posting it on the main thread although I have posted the result on the child thread.
A7: Shutter speed is 1/8
5N: Shutter speed is 1/10
SQLGuy
That's a pretty good comparison, but you should also match the white balance between the two.
andrewD2
You should get the same exposure times.
Full frame does gather more total light per second at the same aperture but the same light PER AREA.
They are not far off, ISO rating slightly different, lens vignetting, T stop of the lens are possible reasons but they need to be shot at the same white balance first (raw might be better).
Andrew
D Cox
Forum ProPosts: 12,505
That would tell you if the shutter speeds and f stops are matching.
My advice would be to stop worrying about it. The question is whether both cameras can take good photos.
Vignetting will be the same for all lenses of the same design. It doesn't vary from copy to copy as decentring does.
D Cox
What is going on is that you are fretting over trivial differences. There is no practical difference between 1/8 and 1/10.
If it was 1/8 and 1/100, then it would be interesting.
Bear in mind that lenses of different design transmit slightly different amounts of light at the same f number. This is why cinematographers use T stops. I doubt if T stops are necessary now we have digital photography, which allows easy adjustment of exposures in post processing.
ksarkar77
In reply to D Cox, Jun 26, 2014
Hi D Cox,
I was thinking that I would get double the shutter speed compared to 5 N because full frame
supposed to have 1 stop advantage over APSC. So, whatever shutter speed I am getting is pretty much correct?
Kuntal
